Oct 15, 2008, 01:37 PM
Personal Sales Rating: ( 6)
Drives: 05 Evo8 SSL
Water Injection Calculator !
http://www.customperformancesolution...injectioncalc/
I'm running a single 1.0mm jet on my max'd out IX turbo and recently switched to E85 and saw some performance gains. This is a great tool to help you (and me) figure out what different jets should be used for optimal fuel percentages. I'm thinking of adding a 2nd jet (.5mm) to bring it over the top.
Offline
Oct 15, 2008, 01:43 PM
Personal Sales Rating: ( 17)
Drives: IX GSR
hey thats really neat.
nice find
Offline
Oct 15, 2008, 03:26 PM
Silver Sponsor
Personal Sales Rating: ( 89)
Drives: EVO 8|9|X, R35, 997TT, S2K, M3, C63 AMG,
Great find!
Offline
Oct 29, 2008, 10:00 PM
Personal Sales Rating: ( 0)
Drives: EVO IX MR
Hi guys,
If someone need an offline version, I made a replica in XLS format...
Hope you will envoy it...
Any improvement to original file will be appreciated!
Version 1 is HERE
Cheers!
__________________
6000 miles of happiness so far...
Offline
Nov 29, 2008, 11:53 AM
Drives: 05 Evo VIII
what is the fuel pressure at the fuel rail in an Evo VIII?
Offline
Dec 3, 2008, 10:41 PM
Personal Sales Rating: ( 8)
Drives: WW IX RS
^^^ About 4 bar or a little less... expect 45 psi or more on the stock evo.
According to that calc one of my customers is running a 56.121% to fuel ratio with 2 x 1.0mms!! lol. That car is just plain fast!!!
Evan Smith
Offline
Feb 24, 2009, 06:01 PM
Personal Sales Rating: ( 122)
Drives: 1983 Chevrolet K10 Stepside Pickup
excellent find...
Offline
Feb 26, 2009, 11:10 AM
Personal Sales Rating: ( 19)
Drives: 2003 evolution
+1
Offline
Mar 16, 2009, 10:21 AM
Drives: 350z
I have question on Fuel pressure.
My fuel press at Idle is 2.8 bar and 4.5 bar at wot.
Should I use 4.5 bar to calculate the injector size?
Offline
Mar 16, 2009, 02:07 PM
Personal Sales Rating: ( 2)
Drives: 2006 RR Evolution IX
i used the calculator and got some weird results...
It's saying i need about 1000cc of meth flow to have 20% MFR...
seems a bit high, don't u think?
__________________
Newton turns in his grave every time an Evo is started.
Offline
Mar 17, 2009, 02:59 PM
Drives: 05 Evo8 SSL
Nope, that's about right
2x 1.0mm nozzles should get you close!
These are ideal circumstances though, I think my setup only runs about 10-11% meth/water and I get great results. This is with a single 1.0mm jet.
Offline
Jun 21, 2009, 07:40 PM
Personal Sales Rating: ( 22)
Drives: 2003 EVO VIII
I have been reading thread after thread on selecting the correct Jet and restrictor size but don't seem to be getting it. I am running a IX turbo with stock injectors and will be setting up an HFS-6 system with a 50/50 mix. I am a little lost on how to know what my Injector/Fuel Rail pressure are and what the duty cycle will be? Can someone give me a how to determine jet and restrictor size for dummies?? Thanks for the help.
Offline
Jun 30, 2009, 10:20 AM
Drives: 05 Evo8 SSL
Most of those values you leave as-is. Stock injectors flow 560cc's and you have 4 of them. You need to log your car to see what your peak IDC is but if you have a walbro and all the mods listed in your sig, you're prolly running about 100% IDC peak pretty easily (not bad, I ran mine up to 127%  ).
Anyways, decide how much meth/water you want to inject and set that percentage, or guess at what jets you want to run and work your way backwards. Last week I switched from a single 1.0mm jet and added a second jet. I was going to add a .8mm, but all I had was a .9mm so I just went with it. That adds up to 967cc/min based on the chart listed on that page. I'm using 2 injectors, so divide that in half for 483.5cc/min per injector target (average). With my setup and some rough numbers, that gives me about 22% of my fuel ratio being water/meth. Since I'm going for max power out of the setup, this is a good % to be at
I attached a screenshot of the settings I used. Again, rough numbers but they work.
Offline
Sep 14, 2009, 09:46 PM
Personal Sales Rating: ( 3)
Drives: WW EvoX GSR
Hrmm...
So I entered my stats:
560/95%/4/20%/160/25
and it reckons I need 2x 0.8 jets...
But when I used the included chart from Aquamist it says I only need 1 jet?!?
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Sep 15, 2009, 12:22 AM
Silver Sponsor
Personal Sales Rating: ( 5)
Drives: Citreon Xsara
Tephra,
The chart on the HFS-6 is the maximum size jet without a tune. I don't think if will suit you.
__________________
richard@aquamist.co.uk
Offline
Tags
alcohol, calculator, e85, evo, fuel, guidelines, injection, injector, jet, methanol, mms, size, snow performance, viii, water  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
