Sep 15, 2009, 12:24 AM
Personal Sales Rating: ( 3)
Drives: WW EvoX GSR
Can you explain in my projectX thread? I will repost the Q
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Sep 15, 2009, 01:14 AM
Silver Sponsor
Personal Sales Rating: ( 5)
Drives: Citreon Xsara
Done
__________________
richard@aquamist.co.uk
Offline
Sep 15, 2009, 07:19 AM
Drives: WW EvoX GSR
I think this calculator is wrong  lol - i must be reading it wrong...
ok
Enter:
560
results in 2240 cc/min
now choose 10% Desired % of Fuel to be Injected
results in 224 cc/min (10% of the above) The worksheet calls this "Calulated TOTAL WATER FLOW"
Next:
enter 50% meth mix (I presume this means a 50/50 Water/meth mix)
results in 336 cc/min "Calculated TOTAL FLOW REQUIRED".
however that's not right!
if the water flow is 224 cc/min and your using a 50/50 meth/water mix, then you SHOULD be seeing 224 cc/min of water AND 224 cc/min of Meth - not 50% of 224 cc/min Meth
ie a TOTAL FLOW of 448 cc/min (224 cc/min * 2)
Anyone think something is funny here?
__________________
Offline
Sep 15, 2009, 10:19 AM
Personal Sales Rating: ( 8)
Drives: WW IX RS
The amount needed of water/meth also greatly depends on the climate you live in.
PS I don't really use the calculator. So many things can vary the amount needed.
Evan Smith
Offline
Sep 15, 2009, 05:56 PM
Personal Sales Rating: ( 6)
Drives: 05 Evo8 SSL
tephra, I believe methanol flows different than water, so that is why your calculations are off. Anyone have more specific info on this?
Offline
Sep 19, 2009, 02:59 PM
Personal Sales Rating: ( 0)
Drives: 06 IX GSR GG / 06 IX SE TB
Meth flows faster then water.
The vid got removed by the author but on youtube there was a college student the showed the surface traction loss was 2x higher in the nylon line with water then meth for a project in school (nothing to do with cars) it was for RC planes.
He was using distilled water and 67-56-1 meth.
He also noted when mixing the two that you had to let the mix sit for over 4 hours for the water molecules to absorb the meth fully giving his mix a 1.2x surface traction loss vs the orig. 2x.
So yes meth does move faster in the line and at the nozzle I am sure, pump design might even play a role in meth vs water vs mix setups.
__________________
IX - Dejontool 3" Intake, Dejontool MAFT UICP, AMS LICP, AMS FMIC, 3" GM MAF, GEN 2 Trans, AEM wideband, PTE 880's, Walbro 255, Tial BOV, HKS Downpipe, test pipe, Greddy Ti C Catback, Hallman MBC, SNOW Stage 2 Meth Kit, JIC Magic FLT-TAR Hard setup, Nitto NT01's 235-45-17, Batt in da trunk, C-west front, JDM Rear, Carbon Hood / trunk, and Gauges N' S$%#
Offline
Tags
alcohol, calculator, e85, evo, fuel, guidelines, injection, injector, jet, methanol, mms, size, snow performance, viii, water  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
