Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 8, 2008, 10:40 PM   #1
Personal Sales Rating: (0)
Vigman's Avatar
Drives: EVO IX MR
Recirculate BOV with WI
Hi guys,
I know everybody is thinking different with this question but is someone already tried to recirculate with WI? (supposing WI nozzle is installed just after IC)
I am a bit desperate cause of the VTA bug in 5th & 6th gear and I dont plan to go MAP already...
Thank you for your replies.
Cheers.
__________________
6000 miles of happiness so far...
Offline
Old Oct 9, 2008, 06:42 AM   #2
Personal Sales Rating: (4)
SlowCar's Avatar
Drives: a drunken IX
i got one big nozzle before and after the diverter valve
http://www.putfile.com/pic/4549579
http://www.putfile.com/pic/4543240
a valved system stops unecessary jetting of injectant when injection event is over.
left = valved, right = no valve
__________________
6 injectors, 3 fuel tanks and 2 fuel pumps
Aquamist HFS-6 install: ......:)
Aquamist HFS-1 install: http://forums.evolutionm.net/water-a...n-project.html
Aquamist 2D/DDS3 install: http://forums.evolutionm.net/water-a...tion-pics.html
Offline
Old Oct 9, 2008, 07:52 AM   #3
Personal Sales Rating: (17)
dudical26's Avatar
Drives: IX GSR
Someone tested this a while back on the waterinjection.info boards.
They stumbled accross the data when measuring how different jet placements effect cooling.
Anyway they found that it operates somewhat like pre turbo injection....because it pretty much is. The extra meth gets sucked back into the turbo. It cooled the charge air such that the temps recorded at the turbo outlet were significantly lower.
However, with that being said I'm not sure what danger it posses to the compressor blades on the turbo as pre turbo injection is known to be potentially damaging.
I don't recall if the person who conducted those tests was using a aquamist system with valve.
Abner - how many miles do you have on your car since setting up meth injection? I imagine it can't be doing much damage if your still going strong for this long. Have you inpected the trubo impeller since install?
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Oct 10, 2008, 08:06 PM   #4
Vigman's Avatar
Drives: EVO IX MR
Thank you guys for your help.
I am not sure about the "sandblast" effect... For some who knew and remember the old Renault 5 Alpine Turbo, engine was boosted thru a T3 with aspirated carburetor...so it could not be "that bad"... I have seen those cars with 120,000 kms and running good.
I know, it was just 0.42 bar but....
I tried to find some R5AT info in english to share but it's very hard...
Have a nice WE.
__________________
Offline
Old Oct 10, 2008, 08:32 PM   #5
Vigman's Avatar
Drives: EVO IX MR
Here is another crazy example...
It's a turbo BUG...(VW flat 4)
It is not exactly the kind of work I like but the guy get 200HP @ 1.3 bar!!!
Check the run vs a Golf VR6 !!!! That's fun....
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
