Quote:
Originally Posted by hellcat
Im running 100% m1 and i notice at peak boost if the afr is above 12.5 I start to see counts of knock. I keep it about half of a point lower than that for safety. My timing map has only increased 2 degrees at most through a small portion of my rpm range. With that little increase it "seemed" to pull better. I only road tune so its really hard to say. What works with me on my car is setting psi, then afr, then tweaking the timing a degree here or there, usually not much.
12.5 AFR for straight meth is too lean in my opinion. For straight meth I would tune to the same AFR as gas. With straight water you want a 12.5 AFR so you arent literally putting the fire out in the cylinder.
For Straight H2O I would tune to 12.5 AFR, 50/50 tune to 12.0AFR and straight meth tune to about 11.5AFR. These are the AFR's I use in CA where we run 91oct. If you have higher oct maybe go a little leaner. Straight meth will make more power than 50/50, but you are closer to knock with straight meth. The water cools better than meth does.
You can street tune and measure the results by looking at your logas and seeing how long it takes you to accelerate from a certain mph to a certain mph. For instance say you tune in 3rd gear and at 3000rpm you are going 30mph and at 7500rpm you are going 90mph. You look at your log and see how much time elapsed from 3000 to 7500 rpm. If the amount of time is less you are making power gains.
