Aug 18, 2008, 11:11 PM
#106
Personal Sales Rating: ( 1)
Drives: HENRY_ Rides in an 05 Apex Silver Evo VIII SSL-Original Owner
thanks richard for the pm.
__________________
Thanks to Mitsubishi's engineers for a great car.
EvolutionM.net as a great resource.
"Learning is the beginning of knowledge ...
knowledge is the beginning of understanding ...
understanding is the beginning of wisdom."
Offline
Aug 27, 2008, 08:27 AM
#107
Personal Sales Rating: ( 5)
Location: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Drives: 05 Apex Silver Version 8, 2001 GSX-R 1000
What if we want to run EBC? My EBC hold boost better then I have ever seen on a MBC or ECU controlled boost. How would one wire in a failsafe for that?
__________________
Stock Block and Head
FP Red 80mm
Kelford 272's
Beehive Springs
Precision 1k injectors
EPM 02 Dump
ETS 3.5" IC Kit
APS BOV
PPI Extreme Ported Hotside, Exhaust Mani, Intake Mani, and TB
469@28psi on 93
Junior Tuned
THE SHOP CT built
Old setup
Stock Evo 8 Turbo
322.7 whp 320tq 21.5 psi on 93 oct
355.8 whp 430tq 25 psi on c16
Offline
Aug 27, 2008, 10:07 AM
#108
Personal Sales Rating: ( 16)
Drives: '03 evo VIII BBY(sold!), '95 Talon ESI-Turbo'd, '90 Mirage 4g63
I replied to your PM DBallz. If you think that your EBC is better than a GM 3 port with JDM Map sensor combo, read up on Razorlabs research...you'll realize that EBC's aren't any more superior than that combo..though you can have better ECU control over the rpm/load range than you would with most EBC setups on the market.
__________________
New VDR 5.71 Launched on 9/04/2009!! Now can be used for ANY vehicle, presets for all Evo 7,8,9,10 models!
CLICK HERE TO DOWNLOAD 'Virtual Dyno Room v5.71' !
'90 Mirage hatchback 4g63 and Evo8 ECU powered!
VDR 5.71 (EvoM Mode)=300whp/268wtq (thru stock 1.5" exhaust!)
'03 BBY Evo 8 (sold)
VDR 5.71 (EvoM Mode)=339whp/335wtq
Best 1/4 Mile: 12.2@113mph
'95 Eagle Talon non-turbo ATX......turbo'd
Best 1/4 Mile: 13.99@101mph
Offline
Jan 23, 2009, 01:06 PM
#109
Personal Sales Rating: ( 4)
Drives: WW 05 Evo VIII RS(gone) 99 e36 M3
I think here within the next month I'm going to switch over from MBC with Mac valve for failsafe to ecu boost control with tephra patch and the harness I got from Jack last summer  I've heard of some ppl using the Mac valve for the ecu boost control with no jdm map sensor and tuned boost via load. Can anyone elaborate?
Offline
Feb 21, 2009, 10:31 AM
#110
Personal Sales Rating: ( 0)
Drives: Graphite Grey IX MR
Quote:
Originally Posted by Richard L
If you have a 3-port valve, you can get two MBCs, set you hi/lo boost accordingly.
+1
Has anyone tried this?
Looking at the schematics shown by Richard L, wouldn't the 3 port solenoid just bypass the MBC when alky is turned off? If another MBC was used, the solenoid could switch between them for the stock fuel map and alky map. I would have the low boost MBC connected to the de-energized port of the solenoid for safety.
__________________
Mods: TXS TBE w/ testpipe, Hallman MBC, Apexi intake, licp, Swift Spec-R springs, Prosport boost gauge
Ivey Tuned: 342 whp 346 wtq @ 24 psi
Offline
Feb 21, 2009, 12:24 PM
#111
This should work in theory:
Just have the duty cycle set to 100% across the board for one and 0% for the other.
__________________
Offline
Apr 20, 2009, 07:49 PM
#112
Drives: Evolution VI
is there any way to have map switching on the stock ecu and also have a path to ground for the AVCR scramble switch when flow is detected? I can figure out how to have one or the other but not for both. This is for HFS-6 in particular
Offline
Apr 27, 2009, 02:40 AM
#113
Silver Sponsor
Drives: Citreon Xsara
Yes, the H6 has three failsafe outputs.
1. Map switch ......... page 18.1
2. Relay output ........ page 18.2
3. Boost by-pass ....... pagew 19
Use "1" for for map switch, "2" for your AVCR. With white wire grounded (com) and brown wire to Scramble wire.
__________________
richard@aquamist.co.uk
Offline
Aug 17, 2009, 09:40 AM
#114
Quote:
So now I'm leaning towards doing ECU controlled boost next year and HFS-6. How does your alt-map switch harness work with the HFS-6?
__________________
FP Red 80mm
Kelford 272's
Beehive Springs
EPM 02 Dump
ETS 3.5" IC Kit
APS BOV
469@28psi on 93
Junior Tuned
THE SHOP CT built
Old setup
Stock Evo 8 Turbo
Offline
Aug 19, 2009, 03:36 AM
#115
Drives: 2005 GG Evo MR
subscribe
__________________
Sponsored by HBC and Doper then Dope Garage
Formally 2 Guys and a Garage Inc.
Tuned by the mad scientist KevinD
Mods: DD Stage 3 package
Future plans:
BBK Full turbo upgrade
CBRD FMIC, CBRD Radiator
Retune
Start my kids college fund again...lol
Offline
Aug 19, 2009, 04:35 AM
#116
Quote:
Just the same as it does with the HFS-1 and 5 but with different wire hook ups.
I will make a diagram shortly.
__________________
Offline
Aug 24, 2009, 11:46 AM
#117
__________________
FP Red 80mm
Kelford 272's
Beehive Springs
EPM 02 Dump
ETS 3.5" IC Kit
APS BOV
469@28psi on 93
Junior Tuned
THE SHOP CT built
Old setup
Stock Evo 8 Turbo
Offline
Tags
36aaaajdba1ba, 36aaaajdba1gd, 3port, 8, aquamist, bcs, buy, connect, control, evo, gm, harness, hfs, sale, tephra, tune  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
