Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 16, 2008, 04:31 PM   #16
Personal Sales Rating: (48)
2005 Mitsubishi Lancer Evolution
My Garage
zbomb's Avatar
Drives: GG Voltex 8 / 05 Duc 999S / 08 Ford F150 5.4 / Mazda 323 GTX
Quote:
Originally Posted by Jack_of_Trades View Post
It reacts instantly. About 3milliseconds I believe is what Tephra stated.
You are the man, I only somewhat remember asking the question it was so long ago. Thanks for the definitive answer.
__________________
572HP@34PSI C16
506HP@29PSI 93/Alky
BR2.3/BR HTA35R
Tuned By Matt Koestner @ DSG W/Autronic Management on a Dyno Dynamics
Dressed in Voltex
DSG....
Offline
Old Jun 18, 2008, 04:11 PM   #17
Personal Sales Rating: (0)
So you can only tune for ECU boost if you use the Tephra hack w/ meth?
Offline
Old Jun 18, 2008, 04:33 PM   #18
Personal Sales Rating: (16)
Jack_of_Trades's Avatar
Drives: '03 evo VIII BBY(sold!), '95 Talon ESI-Turbo'd, '90 Mirage 4g63
Quote:
No you can tune your boost levels with ECUFlash regardless if you use his patch or not. His patch allows you to basically have two sets of settings for your boost level, fuel maps and ignition timing maps. You can also have two settings for your duel injector scaling too which is handly for people who tune for E85 gas or regular pump gas.
__________________
New VDR 5.71 Launched on 9/04/2009!! Now can be used for ANY vehicle, presets for all Evo 7,8,9,10 models!
CLICK HERE TO DOWNLOAD 'Virtual Dyno Room v5.71' !
'90 Mirage hatchback 4g63 and Evo8 ECU powered!
VDR 5.71 (EvoM Mode)=300whp/268wtq (thru stock 1.5" exhaust!)
'03 BBY Evo 8 (sold)
VDR 5.71 (EvoM Mode)=339whp/335wtq
Best 1/4 Mile: 12.2@113mph
'95 Eagle Talon non-turbo ATX......turbo'd
Best 1/4 Mile: 13.99@101mph
Offline
Old Jul 1, 2008, 10:59 AM   #19
Personal Sales Rating: (1)
Drives: Evo IX
Quote:
Originally Posted by Richard L View Post
It appeared to me this failsafe interface is extremely cost effective, no MBC or splicing is necessary.
Do you have an updated wiring diagram for the HFS-5 to illustrate how this setup is done for those running your kit and the v5 patch?
__________________
Current hardware :
EvoRed turbo with BB conversion
2.2L stage 4 shortblock + stage 3 head
Kelford 272 cams
3.5" Bar and Plate FMIC
Motec M800 fully optioned
Ohlins Flag L with Swift springs
Swift swaybars
18" RE30 and 265/35R18 semi slicks
Alcon BBK
Coming soon :
Dual denso supra pumps in custom fuel surge tank
HFS-5 meth kit
CF driveshaft
Titanium catback exhaust system
Offline
Old Jul 2, 2008, 10:54 PM   #20
Personal Sales Rating: (17)
dudical26's Avatar
Drives: IX GSR
Found this diagram on Jack's website, but I had a question about it.
Jack-now that the v9 DDS3 board is able to output a 5v single directly do you really need to use a harness. Assuming you don't want the LED couldn't you just run a wire from the output of the DDS3 directly to the ECU?
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Jul 3, 2008, 05:02 AM   #21
Yes the DDS3v9 can output the 5v signal but it requires some modifying to the circuit board, it not like that from the factory. The harness is useful for anyone who doesn't want to mess with the DDS3v9's circuitry or for owners with the previous version controller. Also, I don't know if the v9's 5v output ever exceeds 5.00 volts but Tephra really preferred that the voltage stayed below 5.00 volts so my harnesses were designed to be in the 4.5-4.9v range. Just for safety sake.
__________________
Offline
Old Jul 3, 2008, 07:40 AM   #22
dudical26's Avatar
Drives: IX GSR
Jack - thanks for the info, I will ask Richard if there is a chance for the voltage to exceed 5v. I imagine if it did that would be dangerous to the ECU.
Also, with the LED, that simply lights up when power is being provided to the ECU correct? It doesn't actually indicate that the maps have switched but just that voltage is being sent to the ECU, right? I'm just trying to think if I would want that if I have the HFS-5. Reason being that if the system already has a light saying when it is on and when the flow is inside the failsafe window.
Thanks
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Jul 3, 2008, 09:27 AM   #23
Personal Sales Rating: (3)
Drives: 06 evoIX SE
Thanks
i thought the LED lights up once it has changed to the safer map...
__________________
mah EvoIx pix
Tuned by:
AWD Motorsports
4WD Tuning
Offline
Old Jul 3, 2008, 11:04 AM   #24
The LED lights up when the "alky" maps are engaged. And you are correct that the LED only tells you that the ECU is indeed getting the 4.5-4.9 volts on the ADC input wire. Any Evo8 or 9 equipped with the factory ICS setup can use the ICS indicator in the instrument cluster to tell you if the ECU did in FACT switch maps. Sadly, since not all Evo's have the ICS configuartion I was not able to have a design which turned the LED on when the ECU did in fact switch to the "alky" maps internally.
The LED is good insurance that the DDS3 and/or the Alt Map Harness are doing their job. Good for troubleshooting too if you were having an issue with the ECU not switching between maps.
__________________
Offline
Old Jul 3, 2008, 11:09 AM   #25
dudical26's Avatar
Drives: IX GSR
Quote:
Yes this is true, but I don't believe the ECU is actually sending any signal to the LED telling it to turn on, rather the LED turns on when voltage is sent to the ECU. In effect it is the same thing, but for some reason if the ECU did not change maps even though the voltage was sent to the ECU to change, we would not know about it.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Jul 3, 2008, 11:13 AM   #26
dudical26's Avatar
Drives: IX GSR
thanks for the info. I am still waiting to hear back from Richard about the voltage of the DDS3 being stable at 5volts.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Jul 3, 2008, 11:14 AM   #27
Personal Sales Rating: (19)
evo_rc's Avatar
Drives: WW Evo 8,Honda Civic Hx
Is it better to run 100% meth? Im worried of not keeping the mix consistent if your mixing it with water. What do most people use with aquamist kit using 1.0 jet and .9 on stock injectors?
__________________
Tuned by Magnumpsi (Mitch @ vivid).......
new whp#s coming soon after aquamist hfs-1 kit install...
Offline
Old Jul 3, 2008, 11:44 AM   #28
Quote:
Meth is hygroscopic, which means it absorbs water faster than you can imagine...right out of the air. To keep things consistent, find out how regularly you cycle through a tank and try not to let the same 'batch' sit in the car for more than a week or two. The longer meth sits, the more diluted it will become with the absorbed water, altering your meth percentage. Most people see the most gains with 100% meth.
__________________
Offline
Old Jul 7, 2008, 03:53 PM   #29
Personal Sales Rating: (7)
Boricua_Evo's Avatar
Drives: '05 AS Evo VIII (96940011)
Send a message via Yahoo to Boricua_Evo
Dudical, Did you ever get an answer for this, curious...
__________________
MODS
- CBRD BBK Full
- FIC 1050cc
- KELFORD 272 CAMS
- BC SPRINGS & Ti. RET.
- GATES
- AQUAMIST HSF-1
- SPEC Super Twin P-Trim
- INJEN A/I SYS w/Amsoil filter
- TIAL Q 50mm BOV
- 3" TURBO XS CATBACK
- eBay 3" TESTPIPE
- 3" MR DN PIPE
- MR HEADER
- ETS LICP
- ETS 3.5" FMIC
- EVODAVE HEADLIGHTS
- EVO 7 TAILS
- TEIN-S
- 255 F.PUMP
- Amsoil ATM 10w30
____________________________________________
4WSTuned!
R.I.P. Westley Hess (12/30/2008)
North West Evolution!!
Offline
Old Jul 7, 2008, 05:36 PM   #30
dudical26's Avatar
Drives: IX GSR
No not yet, Richard has been away for a bit and wont be back for another few days. Don't worry I will be sure to figure out the most simple way to wire in the alt map patch with the DDS3.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Tags
36aaaajdba1ba, 36aaaajdba1gd, 3port, 8, aquamist, bcs, buy, connect, control, evo, gm, harness, hfs, sale, tephra, tune
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
