Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 8, 2008, 12:24 PM   #1
Personal Sales Rating: (33)
EVO8LTW's Avatar
Drives: 04 RS and 08 GSR
Upgraded the tank for my Aquamist kit
Before:
After:
I originally installed my Aquamist HFS-5 kit with a tank that was vented through the cap threads. I also installed my pickup on the side of the tank. It looked nice, but there were some key flaws once I hit the road course. First, in high-G cornering, the alcohol would slosh so much that I would find it on my trunk floor when I came into the pits (it leaked out through the cap threads). Also, I mounted the level sensor a little bit too high so that in high-G corners, it would flicker even when the tank was between 1/3 to 1/2 full. Finally, in normal street driving the alcohol fumes (denatured then) really bothered me. I could smell it and sometimes it even irritated my eyes (my eyes are particularly sensitive for some reason). Now that I'm running methanol, I really don't want any fumes in the car since they are highly toxic and carcinogenic.
This fuel cell has a number of advantages over my old setup. First, it's externally vented under the car, so all of the fumes go out of the passenger compartment. And even if the car flips, the methanol will not leak out. With my old thread-vented cap, if I turned the tank upside down, the fluid would leak out fairly quickly. Also, when I am in a racing situation where I'm not using the methanol (SCCA events for example where alcohol injection isn't allowed), I can easily drain the tank using the petcock/barb. This will also come in handy when the car is parked for an extended period in the winter time. This time around I mounted the pickup on the bottom so that there would be less chance of starvation in cornering. I also mounted the low level sensor lower. If it still gives me problems, I'll probably just disable it. Finally, the cell is much easier to fill because the cap is much bigger in diameter.
The tank cost about $90 from Summit Racing (Jr. Dragster tank) and I installed it using Home Depot supplies. Considering the added safety of this setup (especially if you are running 100% alky/methanol), I think it's worth the cost and a good thing to consider for anyone installing a kit.
Thanks for reading
__________________
RichJ
2004 RS - FP Red, stock ECU w/SD, 464 whp on 93 oct (BR dyno)
Redline TA Summit Point track record - Street Class
Many thanks to Buschur Racing, tephra, jcsbanks, mrfred, l2r99gst and my wife!
Last edited by EVO8LTW; May 13, 2008 at 08:09 PM. Reason: replaced photo with a better one
Offline
Old Mar 9, 2008, 07:58 AM   #2
Personal Sales Rating: (4)
SlowCar's Avatar
Drives: a drunken IX
very nice! is there baffles or open cell foam in the container to minimise sloshing?
__________________
6 injectors, 3 fuel tanks and 2 fuel pumps
Aquamist HFS-6 install: ......:)
Aquamist HFS-1 install: http://forums.evolutionm.net/water-a...n-project.html
Aquamist 2D/DDS3 install: http://forums.evolutionm.net/water-a...tion-pics.html
Offline
Old Mar 9, 2008, 08:02 AM   #3
EVO8LTW's Avatar
Quote:
The cell came with foam, which I took out because I'm not confident in its ability to withstand methanol. If I still have sloshing issues, I'll probably look into methanol-safe foam. I worry that any foam could potentially start to break down and clog the filter.
__________________
RichJ
Offline
Old Mar 9, 2008, 08:06 AM   #4
Personal Sales Rating: (1)
Drives: Mazda
Looks great!
Offline
Old Mar 9, 2008, 08:12 AM   #5
Silver Sponsor
Personal Sales Rating: (5)
Drives: Citreon Xsara
I believe methonal was used extensively in recing until Indy cars switched to ethanol. The chemical properties between methanol and ethanol is very close, so if a foam is compatible with ethanol, it should be OK with methanol. Drop a small piece in bottle filled with methanol and see what happen after few months.
Less-than-pure Ethanol is readily available in the form of denaturared alcohol - try to avoid until you know what the dnaturant used is.
The new tank arrangement is very nice.
__________________
richard@aquamist.co.uk
Offline
Old Mar 15, 2008, 08:51 AM   #6
wesside's Avatar
Drives: WW 05 Evo VIII RS(gone) 99 e36 M3
Send a message via AIM to wesside Send a message via MSN to wesside
Quote:
Originally Posted by EVO8LTW View Post
Before:
After:
Thanks for reading
I like it...Very Nice
ps you should take another shot of it cuz its kinda dark ..damn shadows lol
__________________
V/// RS
Pimp Mode / Jdm ix rear / pump & 720cc/ Aquamist
Invidia / Cusco / Whiteline / Buschur Racing / Exedy
Defi / Greddy / Vishnu / Hks 272 / Fp Green /Mustang Dyno #'s 398whp 405tq :)
www.cardomain.com/id/wesside
PARTS FOR SALE!!!!
My Vboy Evo photHo Sh00t 2
Vboy photHoSh00t n Vid
http://www.myspace.com/wesside514
Offline
Old May 13, 2008, 08:11 PM   #7
EVO8LTW's Avatar
I finally got a chance to take another picture -- this time with a much nicer (borrowed) camera. Of course the tank is all dirty now since it's been in there a while and a lot of dust was stirred up during the roll bar install, but at least you can see the new tank better now.
__________________
RichJ
Offline
Old May 13, 2008, 08:16 PM   #8
Personal Sales Rating: (36)
Evoryder's Avatar
Drives: EVO METH MACHINE
SICK...LOVE seeing nice meth setups
__________________
TEMEVO
"I'm addicted to 100% Methanol : ) "
MACHINES GONE WILD
FOR SALE: FORGE WASTGATE/PERRIN INTAKE CLICK ME
Offline
Old May 14, 2008, 10:08 PM   #9
Personal Sales Rating: (17)
dudical26's Avatar
Drives: IX GSR
Did it come with the petcock drain?
Can you show the vent and how you routed the hose?
Is that 1 Gallon?
Is there a slot in the side, or a way to see how full the tank is?
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old May 15, 2008, 04:33 AM   #10
EVO8LTW's Avatar
Is that 1 Gallon?
Yes, petcock came with it. Very convenient.
The vent hose is routed out through the bumper vent and tied up with a loop inside the rear bumper cover. This is what Jaz advised.
Yes, 1 gallon.
To check the level, open the cap and look inside or wait for the low level light to come on. Yeah...that's a downside.
__________________
RichJ
Offline
Old May 15, 2008, 10:08 PM   #11
dudical26's Avatar
Drives: IX GSR
Yes, 1 gallon.
Hmm... I'm thinking about getting one of these as well. I don't have any issues with the way mine is set up now (sloshing, fumes, etc...) but for safety sake I think I really should do this. I run methanol and I don't run an external vent, which is perhaps a bit foolish. Also its nice to now that in the event of an accident, the meth wont leak out.
I really wish there was a way to see the level though. Do you know if they make one with a view slot?
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old May 16, 2008, 06:06 AM   #12
EVO8LTW's Avatar
I don't know of one with a view slot. Maybe a second level sensor would work, which doesn't trigger the failsafe but lights an LED when the level gets below 1/3 or so?
__________________
RichJ
Offline
Old May 16, 2008, 10:16 AM   #13
Personal Sales Rating: (3)
2003 Mazda Mazdaspeed Protege
My Garage
Pirana's Avatar
Drives: 06 Evo IX MR
that is very nice iam also looking at changing my bottle.
__________________
www.eleven5.com
AMS Powered IX MR
EvolutionDynamics
Offline
Old May 16, 2008, 11:28 AM   #14
Personal Sales Rating: (11)
FastAzzEvo's Avatar
Drives: 2006 Evo IX GSR/SSL
can u elaborate on what u used "home depot supplie" and maybe a possible how-to on the changes you made?
__________________
06 WW Evo IX SSL
FOR SALE: 25K
http://forums.evolutionm.net/sale-ca...te-evo-ix.html
AMS GT850R
523whp/402tq pump 93 @ 30psi
AMS GT850R, Cosworth M2's, AMS DP, AMS Test Pipe, Megan catback, AMS Intercooler, AMS LICP, AMS UICP, AMS mini battery, APS Twin BOV, PTE 1000cc, walbro single, Greddy EBC, Shep built tranny, Exedy HD Twin, zeintronix zt-2, prosport boost/oil/volt gauges, AMS MM inserts, Works clutchline, Works shifter bushings.
Tuned by Mellon
Offline
Old May 16, 2008, 12:19 PM   #15
dudical26's Avatar
Drives: IX GSR
I have already disabled my sensor from tripping the failsafe. Currently if it hits the low level it just turn on the lights on the gauge but it will still spray. I wonder how I might wire up another low level sensor without having to add a lot of wiring or extra LED's
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Tags
aquamist, cap, injection, methanol, tank
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
