Mar 1, 2008, 02:47 AM
Personal Sales Rating: ( 5)
Drives: 06 TB Evo 9 MR SE
Pump Placement?
i'm installing my 5 qt tank in the left side of my trunk (the opposite side of the windshield wiper fluid) and i was wondering where the best place to install the pump would be. i wanna keep everything hidden so it looks stock after i reinstall my trunk liner. i have the Snow Performance meth kit. give me some ideas. thanks.
__________________
2006 GG Evo IX MR SE
R.I.P.
2006 TB Evo IX MR SE
Offline
Mar 1, 2008, 10:23 AM
Silver Sponsor
Personal Sales Rating: ( 0)
I would suggest right next to the tank. The pump works better as a pusher rather than a puller. All you'll have to do is run the lines through the cabin like audio wire. We did an install on a Subi with the tank and pump mounted in the trunk. It was actually quite simple.
Best regards,
Lucas
Offline
Mar 1, 2008, 11:00 AM
Personal Sales Rating: ( 9)
or you could have just answered you own question by searching
__________________
Quote:
Originally Posted by Asmodeus6
Stab the clutch pedal like you're kicking a midget in the head when you shift?
Offline
Mar 1, 2008, 12:31 PM
Quote:
really now? i actually did search and found one other member on here that installed the tank in the same spot and i PMed him about it, but he hasn't responded and i need an answer now so i can install it already. i hate people that post useless responses...
__________________
R.I.P.
Offline
Mar 1, 2008, 12:42 PM
Quote:
Best regards,
Lucas
He means electrical lines not your methanol line of course. It is not recommended to run methanol through the inside of your car!
Offline
Mar 1, 2008, 01:34 PM
i dunno if the pump will have enough space to mount beside the tank. i was thinking about installing it under the tank, but the space is pretty tight.
__________________
R.I.P.
Offline
Mar 1, 2008, 02:03 PM
damn still didnt search? any install instructions work with any kit. with the 5 qt tank you wont be able to mount the pump underneath it. if you do you can rub against the fender from the inside causing a dimple on the outside.
__________________
Offline
Mar 1, 2008, 02:33 PM
Silver Sponsor
Quote:
We actually ran all lines underneath the door sills and through the firewall. No problems so far. He doesn't run 100% methanol, though.
Offline
Mar 1, 2008, 02:44 PM
you dont think there is a need to still run them underneath the car? or are they braided? just wonderin, im in the market for a kit
__________________
Offline
Mar 1, 2008, 02:54 PM
Silver Sponsor
Personal Sales Rating: ( 66)
Drives: Faster Than A Cheetah On Cocaine
I've been able to fit a tank and pump back there... its just a really tight squeeze.. Make sure you use some wire loom around the hose, the trunk has a lot of sharp parts that could eventually cause a leak...
Cheers!
Online
Mar 1, 2008, 02:55 PM
Personal Sales Rating: ( 4)
Drives: a drunken IX
keep the lines in the car - go with a chemical/abrasion resistant tubing like nylon6 and you'll be ok
Offline
Mar 1, 2008, 04:03 PM
Silver Sponsor
Yep, all our lines are nylon. Good to go. If I remember correctly, there was plenty of room underneath the door sills to have all lines in wire loom. We wire loomed them coming out of the firewall and into the engine bay.
Offline
Mar 1, 2008, 04:48 PM
Quote:
Cheers!
i dont think you did 5qt and pump on the drivers side?
__________________
Offline
Mar 1, 2008, 10:07 PM
Silver Sponsor
Personal Sales Rating: ( 40)
2003 Mitsubishi Lancer Evolution My Garage
Drives: '04 evo8 daily driver, '03 evo8 time attack car, 08 outlander
i've fit the 5qt tank in the cubby hole but it is to tight to try again. the pump needs to be mounted quite a ways down there to let the tank sit as low as possible to not hit the fender. with the 4 qt tank it fits easily. the bracket i make for the pump allows you to mount it in about 1 minute taking your time. it utilizes two existing nuts welded into the frame (check the forward edge of the cubby, you'll see what i'm talking about). the third bolt holding it together is one that comes with the kit through one of the existing holes along the bottom edge of the cubby. so no drilling is required to mount the pump either.
Online
Mar 2, 2008, 01:00 PM
Personal Sales Rating: ( 8)
Drives: 03 Evo, FP RED + METH = :D
I have a 6qt but its not totally in there. I cut the door away, pump is hidden and you can see a part of the tank. Its not that bad a lot of meth and most is tucked away.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
