Feb 25, 2008, 09:08 AM
Personal Sales Rating: ( 8)
Drives: Mitsubishi Mirage
meth line
Can I use regular gas line that goes from the pump to the nozzle? If not then which line should I get.
Thanks in advance.
Offline
Feb 25, 2008, 10:18 AM
Help anyone!!!
Offline
Feb 25, 2008, 11:12 AM
Silver Sponsor
Personal Sales Rating: ( 5)
Drives: Citreon Xsara
Gas lines are made of mild steel?
__________________
richard@aquamist.co.uk
Offline
Feb 25, 2008, 11:14 AM
I'm talking about rubber hose that you can buy at any auto parts store. What lines do you guys use?
Offline
Feb 25, 2008, 11:32 AM
Personal Sales Rating: ( 11)
Drives: 05 Pum Pum Rider
1/4" Vinyl tubing.
__________________
No sig....sighhh
Offline
Feb 25, 2008, 12:03 PM
Thanks alot!!!
Offline
Feb 25, 2008, 12:05 PM
Personal Sales Rating: ( 7)
Drives: Evo VIII WW 05
or -4 or -6 steel braided line depending on the size nozzle.
__________________
Tri State Evo (SLWBOY)NY Regional Captain
Evolution VIII 05 GSR Weightless White
Fcon Vpro (Ivey Tune FTW)
2.3L Built by Racing Results
GSC 280 In/Ex
Cusco Twin Disk
HKS DLI-II
HTA3582 A/R .82
BR Ported Intake Manifold
Full Blown Twin Daddy assembly
Perrin Fuel Rail with PE 1000cc inj
Turbo XS FMIC
Tial Q BOV
Tial 44mm W/G
Apex-i AVCR EBC
500whp+ on 93 Shell Gas (Only)
Offline
Feb 25, 2008, 01:04 PM
thanks but vinyl tubing should do just right.
Offline
Feb 25, 2008, 01:16 PM
And what line are you guys using from the tank and to the pump?
Thanks again.
Offline
Feb 25, 2008, 02:20 PM
Silver Sponsor
Generally Nylon, good strength and pressure and temperature rating is rated higher than most plastic or rubber hose of the same diameter. Just one step below PTFE (teflon).
__________________
Offline
Feb 25, 2008, 02:49 PM
So I can use same line from the tank to the pump to the nozzle? thanks.
Offline
Feb 26, 2008, 01:26 AM
Silver Sponsor
That is what most people are using.
__________________
Offline
Feb 26, 2008, 07:12 AM
Quote:
Thanks Richard.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
