Feb 12, 2008, 07:30 PM
Personal Sales Rating: ( 2)
Drives: 88590715
No tune on meth
I was having a discussion with a coworker about meth injection. I was saying that I dont't want to go crazy with the boost/timing due to me being too cautious about my engine and failure. He said it would be OK to get my car dyno tuned to the max w/out the meth running (which it already is) and then just use the meth for the cooling capabilities. He said it would have the same effect on power as one of those intercooler sprayer things. Now this makes sense to me but I want some other opinions on this setup.
__________________
E85 duel tephra V7 map/ J O T switch/ Fast Freddie UEGO harness adapter/ GM 3 port and some other stuff
Attempting SD in a couple of weeks
Quote:
Originally Posted by leethaxor
My motors always were more tolerant to detonation when I ran with blown headgaskets. They were always faster.
Offline
Feb 12, 2008, 07:32 PM
Personal Sales Rating: ( 128)
Drives: MR
To be safe.. You NEED a tune for meth......
Online
Feb 12, 2008, 07:33 PM
Personal Sales Rating: ( 0)
Drives: Evo
If you run meth with no tune your just crazy!! Plez don't do that to your motor!!
Slowcar needs to chime in.
Offline
Feb 12, 2008, 07:36 PM
Silver Sponsor
Personal Sales Rating: ( 66)
Drives: Faster Than A Cheetah On Cocaine
if youre running a very small amount and just use boost to lean it out youll be okay... kinda like running 100 oct... but i would get it tuned and use a good amount to have some real fun.
Cheers!
Offline
Feb 12, 2008, 07:45 PM
Drives: 88590715
What parameters of the engine tune would change if I ran meth w/out a tune? What would constitute a mild tune- just advance timing and no boost or vice versa?
__________________
Offline
Feb 12, 2008, 09:28 PM
Personal Sales Rating: ( 6)
Drives: 2006 GG IX MR
Quote:
I think what they are saying is its alright to run meth injection and bump your boost up a couple psi to lean the AFR back out. But it would be wise to get a wideband and a quality tune and enjoy the true benefits of running meth.
BTW, You don't need to "go crazy with boost and timing" but you defiantly want to tune for meth injection, it willl be safer.
Online
Feb 12, 2008, 09:31 PM
Personal Sales Rating: ( 34)
Drives: like the Stig!
Chuckp explained well if your not going to get tune... atleast get wideband to monitor.. But please get TUNED..
Offline
Feb 13, 2008, 05:54 AM
Drives: 88590715
Another question for you guys. I'm already pushing 360whp and I don't have head studs installed. Do you thing I should get head studs installed before I do the meth? Is there a "limit" to power and boost before the head gasket takes a ****? Thanks for the advice on the tune, I will definitely get a tune done with the purchase of the meth kit. Now I just have that one more question to get answered.
__________________
Offline
Personal Sales Rating: ( 33)
Drives: 04 RS and 08 GSR
I think most of the folks responding to this are missing the point. The OP wants the tune to NOT be dependent on the meth, so tuning for it defeats the purpose of what he wants. It sounds like you would like to tune right to the edge of what is possible without the injection, and then just add it for reliability and consistency? If that's your goal, then yes you can do that. Don't expect to make additional power over and above what you have without the injection -- except to the extent that your tune is more maxed out than it would be if you didn't plan to have the extra insurance. Also, don't inject too much or it will actually slow you down by overcooling combustion.
Head studs would be a good idea at that power level. You don't need them if you never get any knock, but it's a lot easier to put in studs than pull the head to fix a blown head gasket.
__________________
RichJ
2004 RS - FP Red, stock ECU w/SD, 464 whp on 93 oct (BR dyno)
Redline TA Summit Point track record - Street Class
Many thanks to Buschur Racing, tephra, jcsbanks, mrfred, l2r99gst and my wife!
Offline
Feb 13, 2008, 07:40 AM
Personal Sales Rating: ( 8)
Drives: goggles and a speedo
Read some books and articles on tuning, it's all the same concept.
Here: http://www.scholar.google.com
About headstuds - *test have shown that boost pressure does not effect peak or average pressure nearly as much, if any, as timing (or knock).
*for nerds, as myself, insisting on documented results, see SAE technical paper 2007-01-3625, fig 6
Offline
Feb 13, 2008, 08:34 AM
Silver Sponsor
Personal Sales Rating: ( 9)
Drives: 3000GT VR-4
If you wanted just the cooling capabilities, you could tune without it and then add it in. You won't be gaining much hp from it, just the peace of mind. Plus, if you just wanted the cooling, you could just spray 100% water.
I would suggest tuning with it, though. You will then see the full capabilities of it. When tuning for it, you'll look at the AFR's, timing, and boost pressure. Those are the parameters you should be concerned with (in a nutshell).
However, you can use it any way you want. It won't hurt either way.
Offline
Feb 14, 2008, 09:59 AM
Personal Sales Rating: ( 4)
Drives: WW 05 Evo VIII RS(gone) 99 e36 M3
If your going to install meth injection then get a tune for it and use what map/boost levels you have now for when your not running it imo but once you get tuned I don't think you'll wanna do anything else. Labonte MotorSports said it best just run 100% water if you want for the cooling. But headstuds I just installed because I'm running high boost but for the cost of them its just cheap insurance so if you have the $ and time its never a bad thing
Offline
Feb 15, 2008, 07:27 PM
Personal Sales Rating: ( 122)
Drives: 1983 Chevrolet K10 Stepside Pickup
if you run a small nozzle and something like a 50% mix you will richen up the afr's a bit but you can counter that by raising boost slightly...you still won't make nearly the power you would if you had tuned the car though...
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
