Jan 30, 2008, 03:46 PM
Personal Sales Rating: ( 8)
Drives: 03 Evo, FP RED + METH = :D
Green w/out Meth Green w/ Meth
The only change between the Red graph and Blue graph is Meth and 24PSI compared to 30PSI Both done on 93 pump
I've seen a lot of requests for before and after meth so enjoy
BTW: Aquamist HFS-5
Before meth:
24PSI
After 100% Meth:
30 PSI taper down 28psi
I think the gain is impressive again only difference is Meth and no Meth.
WHP peak: 27.46 gain
WTQ peak: 83.87 gain
I should be able to get higher numbers, my rings are gapped wrong (rimes with uven) and I burn oil, this will be fixed in April by the Master Sean at Iveytune. I also currently run 264/272
3rd gear 3k-5k RPM pull
http://s219.photobucket.com/albums/c...000rpmpull.flv
2nd gear 3k pull
Reason: uploaded pictures of install
Offline
Jan 30, 2008, 04:01 PM
Silver Sponsor
Personal Sales Rating: ( 5)
Drives: Citreon Xsara
It appeared the cam is retricting some high RPM flow. Stopping the engine from breathing in more air. I am sure the new cam will take you over 400.
The mid range gain is impressive.
__________________
richard@aquamist.co.uk
Offline
Jan 30, 2008, 04:05 PM
yes that is what Sean said...
Offline
Jan 30, 2008, 04:40 PM
Personal Sales Rating: ( 6)
Drives: 05 Evo8 SSL
Nice torque spike man, that is insane! +100wtq in one spot!
Online
Jan 30, 2008, 04:59 PM
Silver Sponsor
Personal Sales Rating: ( 13)
Drives: Ford F150HD Supercharged, R35 GTR 2010, 9 sec Fullweight evo8.
I think the BOV might be opening will finish it tommorow.
Engine has over 20% leakdown in some cylinders but we will still try with it.
Sean
__________________
WWW.IVEYTUNE.COM
DYNOJET AWD ON PREMISES!!!
2003 EVO8 9.17@159.6 MPH 3055 lb NO NITROUS! Full street!
1992 Talon AWD 9.41@151MPH (Oct 2005) Full exhaust, full glass 3122lb
1993.5 Supra 9.6@148 (Stock Auto, drag radials) 9.73@153mph 6 Speed!
Brandon's 1993.5 Supra 8.78@157.17 Slicks and BL400
HKS PRO DEALER!
Cobb Protuner "Live Data!"
Ecutek dealer, reflashes available for all yrs of evos.
Factory Trained Tuner FCON V-PRO, AEM EMS, Haltech, Motec, Autronic.
Offline
Jan 30, 2008, 05:02 PM
Personal Sales Rating: ( 4)
Drives: 2006 Evo Ix Mr
correct me if im wrong, but those numbers seem beyond weak on a dynojet
__________________
Pecision Psi
Glen burnie, maryland
Offline
Jan 30, 2008, 05:11 PM
Personal Sales Rating: ( 0)
Drives: Lightning Yellow Evo VIII
Great results. Very similar to mine.
Here is my sheet with straight 272s - same snail, meth, same tuner of course...
__________________
Mike - Evo-NY Crew #083
TSE: The Tri-State Metropolitan Area Evo Club
See my mods HERE
Quote:
Originally Posted by Basalix
I am pretty non-partial. Punani is punani. As long as it doesn't look like someone drug an axe between her legs, I will generally bury my face in it.
Online
Jan 30, 2008, 05:14 PM
Offline
Jan 30, 2008, 05:16 PM
Personal Sales Rating: ( 3)
Drives: '03 EVO VIII, '04 Prius
Quote:
Originally Posted by Evo11V
The only change between the Red graph and Blue graph is Meth. Both done on 93 pump
Great gains, but I'm confused. You state the "only difference is Meth and no Meth", but it looks to me like the difference is Meth plus 6psi of boost.
A true apples to apples comparo would be at the same boost level me thinks.
__________________
\\ IX Turbo \\ Walbro FP \\ HKS 264/264 \\ RC 1,000cc injectors \\
\\ Helix DP \\ Helix TP \\ Greddy EVO2 (modified to 3") \\ APS BOV/DV \\
\\ ETS 3" FMIC \\ Nisei LICP \\ PPI ported exhaust manifold \\ SS eBay O2 \\
\\ BR cone filter \\ BR MAF pipe \\ Hallman MBC \\ E85 \\ 394whp/418trq \\
E85 Hints and Tips
Offline
Jan 30, 2008, 05:20 PM
Yes you are correct I'm guilty lol... Besides the boost being different yes everything is the same.
I understand... I meant if you run meth compared to not running meth. I was not doing an apple to apple match up. Guys always look for the benefits of running Meth so I posted what I found. Sorry to disappoint you.
I corrected what I said so it is clear.
Offline
Jan 30, 2008, 05:55 PM
Simple enough to explain - it's the meth that allows the extra boost without knock, hence the extra power.
__________________
See my mods HERE
Online
Jan 30, 2008, 08:33 PM
Drives: 2006 GG IX MR
Quote:
Exactly. You need to crank up the boost, lean the AFR, and up the timing to take advantage of meth.
To the OP- looks awesome, that much torque must be fun as hell.
Kinda hard to tell on the scanned dyno , what RPM do you reach full boost?
Online
Jan 30, 2008, 08:38 PM
Personal Sales Rating: ( 11)
Drives: Silver EVO IX SE
those are some good tq gains the power isn't much though. The car is not making much power for a dynojet.
__________________
2006 EVO IX SE
Mods:
Intake, Hallman mbc @24psi, Megan o2 housing, Megan dp w/cutout, Ebay FMIC, Nisei LICP, SW 30/40 vac/boost gauge, AEM wideband, Megan Racing Coilovers, Greddy shift knob, Perrin shorty
4 Wheel Slide tune on 93 oct!!!!
363whp/354wtq
Offline
Jan 30, 2008, 09:04 PM
Drives: 03' EVO8, 92' MR2 Turbo
Great gains indeed. I love Meth - or rather - my car loves it!
__________________
03' EVOVIII - exhaust+meth+boost@25psi
92' MR2 TURBO - exhaust+boost@17psi
Offline
Jan 31, 2008, 04:18 PM
Silver Sponsor
Personal Sales Rating: ( 9)
Drives: 3000GT VR-4
EVO11V -
Do you know what A/F you are at and how much timing? With 30psi you should be over 400hp.
Here is a run on an EVO8 we did during development of our VCS3G controller. Everything was stock on the car except the MBC.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
