I was thinking that adding an extra nozzle (smaller than the one I am using) will increase the flow. Also, I wanted to know the purpose of the restricter pill and why it was suggested to me that I use the medium pill with the large nozzle. I understang that you can't increase the flow of one nozzle when your line pressure in constant. You can only get so many psi through any orfice at a constant pressure.
__________________
"Tuning without a wideband is like screwing without a rubber, sooner or later you'll get something you can't fix!"
Hellcat
