Jan 23, 2008, 07:13 PM
Personal Sales Rating: ( 17)
Drives: IX GSR
Why you should use a restrictor pill with an Aquamist HFS-5
One of the final steps in installing the HFS-5 is to install the restrictor pill. The pill is used to smooth out the operation of the HSV and controll the meth or water flow more precisely. Make sure you do not overlook this step.
The bright yellow line is the flow of the meth without a pill
Here you will see the meth flow with the largest of the restrictors in place. Notice the bright red line is the injector duty cycle, look how accurately the meth flow follows this line, simply amazing.
Notice how the initial turn on point is no longer a huge spike and the flow is WAY more constant. This makes tunning much easier and has even helped me eliminate some knock due to what I believe was inconsistent meth flow.
This is where the pill goes
Offline
Jan 23, 2008, 07:18 PM
Personal Sales Rating: ( 11)
Drives: Silver EVO IX SE
So a restrictor pill makes it flow better, is that correct? Or maybe i misunderstand this.
__________________
2006 EVO IX SE
Mods:
Intake, Hallman mbc @24psi, Megan o2 housing, Megan dp w/cutout, Ebay FMIC, Nisei LICP, SW 30/40 vac/boost gauge, AEM wideband, Megan Racing Coilovers, Greddy shift knob, Perrin shorty
4 Wheel Slide tune on 93 oct!!!!
363whp/354wtq
Offline
Jan 23, 2008, 07:25 PM
Drives: 04 VW r32
so i guess the size of the restrictor depends on what nozzle(s) you install correct?
like if you install the .9mm and the 1.0 mm nozzles, you would put the bigger size restrictor.. right?
Offline
Jan 23, 2008, 10:10 PM
Drives: IX GSR
Quote:
A very simple answer is yes. It makes the flow more constant and smoother to be more specific.
Offline
Jan 23, 2008, 10:11 PM
Drives: IX GSR
Basically. You want to add up the flow of all your nozzles and then check the flow of the 3 provided restrictor. Which ever restrictor most closely matches the flow of your nozzles is the best choice. I use a .9 and a 1.0 mm nozzle so I use the biggest restrictor.
Offline
Jan 23, 2008, 10:44 PM
Personal Sales Rating: ( 12)
Drives: 03 evo ,02 ws6 trans am
should i just use one 1.0 mm nozzle for stock turbo? if so what restricter should i use? i bought my kit used and i only have one restricter. can i buy replacement restricters?if so where do i get them from
__________________
03 evo 8
turbo trix 50 trim turbo kit
1mm oversized valves
hks 272/272
aem ems
aem wideband
b&m short throw
soon to be kelford 280's with the new pte 5857..
Offline
Jan 24, 2008, 01:16 AM
Silver Sponsor
Personal Sales Rating: ( 5)
Drives: Citreon Xsara
Dudical, thanks for highlighting the importance of the pill.
In order to maintain a constant pressure across the valve and nozzle, a restrictor is used. It keeps the fluid flow linear to fuel injector duty cycle.
__________________
richard@aquamist.co.uk
Offline
Jan 24, 2008, 01:21 AM
Silver Sponsor
Is it possible for you to log another chart with the trip point at 12% DC and higher gear? It won't affect the flow at high DC. This will show up the linearity of the HFS-5 system better.
__________________
Offline
Jan 24, 2008, 07:18 AM
Personal Sales Rating: ( 6)
Drives: SRT4
Quote:
Send me a PM will you're email address. I'm in short supply of many replacement components but I'm sure I have these. And should be to put into the mail to you by Monday.
Offline
Jan 24, 2008, 07:40 AM
Drives: IX GSR
Quote:
Yea I can do that.
Offline
Jan 24, 2008, 09:59 AM
Drives: IX GSR
Here is another graph. This one shows the trigger point set at the lowest possible point of IDC = 12%. Again you can see the yellow line of the meth flow following the red line of the injector flow.
On a side note - It is awesome to be able to run 33psi with almost zero knock, METH ROCKS!
Offline
Jan 24, 2008, 03:01 PM
Silver Sponsor
Thank you , I am very glad I see the system is working well on a car as well as on the test bench.
__________________
Offline
Jan 24, 2008, 05:05 PM
Drives: IX GSR
Richard - are there any other logs you would like to see?
Offline
Jan 24, 2008, 06:54 PM
Drives: SRT4
See the part I like about this how the PCM is the W/A controller, no need to reinvent the wheel, the graphs show this fact..............the PCM/EMS/ECM is the best W/A controller and everyone already has it installed along with the needed sensors.
Offline
Jan 25, 2008, 01:09 AM
Silver Sponsor
Quote:
Yes please! I would love to see a logged continuous pull from low gears upwards. It will show how the system is responding to transients.
Can you rescale various channels to give a more detail viewing? Perhaps x10 the AFR etc.
I like to focus on the IDC, DDS3 and AFR. It will certainly makes an interesting chart.
Lastly, can you post it as .png, .jpeg or .gif rather .bmp, the file size is huge.
__________________
Offline
Tags
aquamist, choosing, duty, excel, hfs2, hfs5, injection, injector, installation, jet, manual, methanol, nozzle, size, sizing  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
