Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 13, 2008, 12:04 PM   #1
Personal Sales Rating: (0)
BOOSTEZ's Avatar
Drives: 03' EVO8, 92' MR2 Turbo
Snow Performance Boost Solenoid Problem..
All:
I've had my Meth kit for about 4 months now. I never really drove the car hard (racing it) until a month ago. I've noticed that when I hit it hard and switch gears, that the boost only goes to 15psi for a second or so inbetween shifts until I get full boost (25psi). I've troubleshot it down to the fact that the boost control solenoid (from the Safe Injection Kit) must not be working properly and opening the solenoid inbetween shifts, allowing the wastegate to open, then closes and I get all my boost again. I've disabled the solenoid (breaking ground) for now until I figure out if the Safe Injection Kit was installed properly.
Any suggestions on how it should've been hooked up? I'm not even sure if I have the upgraded solenoid that allows flow to stop instantly (even though my tank was installed in the trunk). I went to the webpage but there are no instructions on installing the Safe Injection Kit. The original Meth kit appears to be working but I doubt the Safe Injection was installed properly. Also, when the boost solenoid bleeds back boost, the orange light doesn't illuminate (which it should).
-M
__________________
03' EVOVIII - exhaust+meth+boost@25psi
92' MR2 TURBO - exhaust+boost@17psi
Offline
Old Jan 13, 2008, 12:07 PM   #2
Personal Sales Rating: (122)
Ultimate CC's Avatar
Drives: 1983 Chevrolet K10 Stepside Pickup
Send a message via AIM to Ultimate CC
when does your kit turn on boost wise... what safeinjection do you have the si05 or the si10?
Offline
Old Jan 13, 2008, 12:12 PM   #3
BOOSTEZ's Avatar
Quote:
The kit starts to spray when boost is at 11psi. I'm not sure which Safe Injection kit I have. The module which accepts the flow line is near my battery, what should I look for?
If I punch it in one gear and let out, it's fine. Acceleration is smooth and there is no knock.
-M
__________________
Offline
Old Jan 13, 2008, 02:29 PM   #4
Do you know what nozzle you are running...is it a 375ml/min
Offline
Old Jan 13, 2008, 07:23 PM   #5
BOOSTEZ's Avatar
Not sure what nozzle. I know it's not the larger sizes that came with the kit. My tuner told me that those were too much for my stock turbo.
-M
__________________
Offline
Old Jan 13, 2008, 07:31 PM   #6
Well what I am thinking is that you have a 375 nozzle and a si10 unit and the nozzle isn't flowing enough to keep the si10 from triggering...it could be other things though...
Offline
Old Jan 13, 2008, 10:14 PM   #7
Personal Sales Rating: (8)
Drives: goggles and a speedo
Sensor is seeing no flow for a split second while pump is getting first voltage, the SI sol is energized. Your only option, if sensitivity is already backed up, would be to widen your start and full margin's or find a solenoid withgreater resistance coil (3 port)
Offline
Old Jan 14, 2008, 11:53 AM   #8
BOOSTEZ's Avatar
Quote:
That's what I figured. Is there such a solenoid from Snow? How come noone else is seeing this?
__________________
Offline
Old Jan 14, 2008, 11:58 AM   #9
BOOSTEZ's Avatar
If that was the case, I'd see the problem on full throttle in any gear without switching gears. It would've been noticed on the dyno right away.
__________________
Offline
Old Jan 18, 2008, 12:36 PM   #10
Drives: Evo
Quote:
You can try turning the actiavation delay all the way up. Adjust the delay potentiometer fully counter-clockwise.
Offline
Old Jan 22, 2008, 08:10 PM   #11
Silver Sponsor
Personal Sales Rating: (9)
Labonte MotorSports's Avatar
Drives: 3000GT VR-4
Send a message via Yahoo to Labonte MotorSports
SnowTech - when did you buy an Evo? I thought you both drove jettas?
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
