Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Dec 31, 2007, 04:59 PM   #1
Personal Sales Rating: (4)
SlowCar's Avatar
Drives: a drunken IX
checkvalve to solenoid valve on a progressive pump speed kit
How can one put a solenoid valve in a progressive pump speed system w/o running the SV pulsing itself to death? Anyone...
__________________
6 injectors, 3 fuel tanks and 2 fuel pumps
Aquamist HFS-6 install: ......:)
Aquamist HFS-1 install: http://forums.evolutionm.net/water-a...n-project.html
Aquamist 2D/DDS3 install: http://forums.evolutionm.net/water-a...tion-pics.html
Offline
Old Dec 31, 2007, 05:15 PM   #2
Personal Sales Rating: (1)
Drives: 06 Elise. 09 BMW 135I
All of our Vari-Cool kits with the Smart Injection unit have a solenoid. Failsafe and Solenoid control is done through the Failsafe. This includes all of our 2D Kits, stage 3D and Universal Vari-Cool Smart Injection Kits.
David
Offline
Old Dec 31, 2007, 06:57 PM   #3
SlowCar's Avatar
Quote:
David
can your system work with a non-coolingmist injection kit?
__________________
Offline
Old Dec 31, 2007, 07:01 PM   #4
yes, it functions on several levels
1) its a fixed rate controller. Can activate based on many types of inputs
2) It can create a 2D map and send it to any 0-5V based progressive controller
3) Its a complete, user configurable failsafe to use with any system.
4) It has 5 programmable on/off outputs for devices
5) its a datalogger.
Its platform independent. If you were using it as a failsafe for an on/off kit, you may as well use it as the controller as well.
Offline
Old Dec 31, 2007, 07:05 PM   #5
SlowCar's Avatar
what would the integration say with a SMC pps kit involve - if someone already has a smc kit.
__________________
Offline
Old Dec 31, 2007, 07:13 PM   #6
I must say I know nothing of the SMC kit, its not one of the kits sitting on my test bench. However, its all the same.
If the SMC kit has a 0-5V input instead of its own MAP sensor, you can use this device to create a 2D Map on any 2 inputs you want (MAP, TPS, EGT, AIR TEMP, RPM, MAF, ETC, ETC). You program a 0-5V output to send to the controller. IF you dont care to do a 2D table based map, you can do a single input as well.
The SMC controller would then be only a pump speed controller with the Mapping from the Smart Injection.
If the SMC has a boost port and no 0-5V input, again its pretty simple. Assume for a moment that you set the SMC kit to turn on at 6 PSI. You would connect your MAP sensor to one of the 0-5 inputs and tell it to open one of the outputs at 6 PSI. Connect the solenoid to that output.
What ever signal you use to activate the controller, you can use to activate the solenoid through Smart Injection.
There are a million other ways to do it, but it will work with any system.
Offline
Old Dec 31, 2007, 07:53 PM   #7
SlowCar's Avatar
confusing! at least it can be done
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
