Aug 27, 2007, 02:20 AM
Personal Sales Rating: ( 0)
Drives: Evo VIII
aquamist system Q
so ive got the System 2d http://www.aquamist.co.uk/cp/806-009/806-009.html
and the DDS3 (50mm gauge http://www.aquamist.co.uk/cp/806-425/806-425.html
is this system going to be good, or should i be trying to get the HFS?
mods - 10.5, Forge Actuator, HKS Silent Hi-Power, HKS DP, HKS 02 Housing, Greddy uicp, licp, GSC 264/272, 255 walbro, hks drop in filter, cam gears, Blitz SBC-id, Blitz FattDC, Wideband commander...
Offline
Aug 27, 2007, 04:05 AM
Silver Sponsor
Personal Sales Rating: ( 5)
Drives: Citreon Xsara
The system is still the best - the fail safe is the most advanced to date. The only drawback is water limitation. without a priming pump, it can only up to 330cc/min.
It will depend on you engine power output and what fluid you will be injecting. For 100% methanol, you need to inject twice as much as water.
__________________
richard@aquamist.co.uk
Offline
Aug 27, 2007, 04:17 AM
Drives: Evo VIII
im aiming for 235kw on the wheels.. (still stock turbo), might upgrade to a FPGreen at some stage
ive been advised to use a 50/50, meth/water mix?
Offline
Aug 27, 2007, 04:26 AM
Silver Sponsor
If you have already bought the system, invest ion a priming pump relay driver ~$20.00 to boost the flow capacity of the 2d system.
You are very close to the limit of the 2d flow when using 50/50 methanol.
__________________
Offline
Aug 27, 2007, 05:12 AM
Drives: Evo VIII
im in South Africa, i got the system from Brandon Leech our local agent, i will ask him for the priming pump relay..
what would your advise on %mix be? i have the DDS3 as well.. i am running a Blitz SBCid would it be possible to connect the failsafe to the Blitz to cut boost in case of failure?
Thanks for you help so far!
Offline
Aug 27, 2007, 05:35 AM
Silver Sponsor
25-50% is good.
Say hello to Brandon for me. There couldn't be that many EVO in SA?
__________________
Offline
Aug 28, 2007, 01:24 AM
Drives: Evo VIII
Quote:
Originally Posted by Richard L
25-50% is good.
nope not too many.. will do.
__________________
Offline
Aug 28, 2007, 01:25 AM
Drives: Evo VIII
__________________
Offline
Aug 28, 2007, 02:33 AM
Silver Sponsor
As long as the Blitz uses a solenoid valve, the DDS3 can cut boost.
__________________
Offline
Aug 28, 2007, 02:52 AM
Drives: Evo VIII
awesome! thx..
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
