Aug 14, 2007, 12:08 PM
Personal Sales Rating: ( 1)
Drives: 05 EVO VIII MR in circles
Loud Snow Performance Pump
I just installed a snow performance kit and the pump is very loud when it turns on. Is that normal? I have it mounted under the stock washer tank.
Also my safe injection module in leaking with just 50/50 meth and water. I can see the drips on the tranny. Is it defective? Also when is the light for the safe injection supposed to come on?
__________________
Injen intake, Uicp, APS twin vent bov, Turboxs fmic, Apex catback exhaust, Apex downpipe, UR tp, MR manifold, MR O2, GSC S-1 Cams, Headstuds, 780 Injectors, Walbro pump, Hallman manual boost controller. ACT street clutch and streetlite flywheel, Snow meth kit , John Shepperd built case, Green Turbo @ 30 PSI
Offline
Aug 14, 2007, 12:50 PM
Personal Sales Rating: ( 4)
Drives: a drunken IX
is it loud from the on-demand switch switching the pump on and off...or is it running noisy?
viscosity of goes down from water to methanol ie more methanol in the solution, the more likely it will leak if there is a leak.
dont all snow kits come with a tube of GOOP?
Offline
Aug 14, 2007, 01:32 PM
It is running noisy. It is really loud when the pump engages under boost. It almost sounds like a loud fuel pump. The leak is from the one line on the safe injection comming from the pump. Should I just put goop on it and call it a day?
__________________
Offline
Aug 14, 2007, 01:36 PM
Also I have the vc25 controller set at 8psi start and 25psi max. It is all the way up. Should I turn down the max a little. My boost is set at 28. It seems like it running through the meth very fast.
__________________
Offline
Aug 17, 2007, 11:05 PM
Personal Sales Rating: ( 122)
Drives: 1983 Chevrolet K10 Stepside Pickup
hey,
are you still having the issues? if you are getting leaks make sure the lines are perfectly straight going into the SI as if they aren't it could be your problem...
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
