Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 10, 2007, 05:19 PM   #1
Personal Sales Rating: (1)
cpoevo's Avatar
Drives: no more Evo
Snow install help
I have the Snow STG 2 (MAP type) with the old Safe Injection and the Zeitronix ZT-2 with the ZAVT-1 alarm/trigger. I am trying to figure out how to connect both to a bypass solenoid for the boost controller. I know I have to use a relay for the ZAVT-1.
here is a diagram I drew that I believe will work I just need someone's expertise to approve my diagram.
the diagram is attached
Offline
Old Aug 10, 2007, 06:34 PM   #2
Personal Sales Rating: (4)
SlowCar's Avatar
Drives: a drunken IX
feed the output of the SI into the zeitronix AUX, use a resistor to reduce 12VDC to 5VDC. Trigger the failsafe using AUX/afr and boost.
or since you got the zeitronix, leave the SI out as the zeitronix is a far superior failsafe than the SI
__________________
6 injectors, 3 fuel tanks and 2 fuel pumps
Aquamist HFS-6 install: ......:)
Aquamist HFS-1 install: http://forums.evolutionm.net/water-a...n-project.html
Aquamist 2D/DDS3 install: http://forums.evolutionm.net/water-a...tion-pics.html
Offline
Old Aug 11, 2007, 12:26 AM   #3
cpoevo's Avatar
Drives: no more Evo
You cant wire it that way. If you are using the ZAVT-1 it is conected to the AUX Input. You cant have the AUX input and the ZAVT-1 according to the instructions.
Offline
Old Aug 11, 2007, 05:56 AM   #4
SlowCar's Avatar
is your zeitronix the newer or the older version? the older one will only allow if AUX (voltage > X volts, trigger). The newer version allows both AUX < or >, trigger.
__________________
Offline
Old Aug 11, 2007, 09:31 AM   #5
cpoevo's Avatar
Drives: no more Evo
I have the newest version. Its only about 2 months old. I think I understand what you are saying now about the SI to the AUX input. I have to figure out the resisitor size.
Offline
Old Aug 11, 2007, 03:44 PM   #6
SlowCar's Avatar
what jet size will you be using and what is the trigger point for the SI?
__________________
Offline
Old Aug 11, 2007, 05:45 PM   #7
cpoevo's Avatar
Drives: no more Evo
I will be using the 375ml/min jet and I think the SI trigger is when flow is <180 ml/min.
I just got home from getting my IC installed and the mounting bung for the nozzle welded in. I am gonna run the wires to the pump and everything and see what voltage the SI puts out when triggered so I can find the correct resistor to put inline.
Thanks Abner I never thought of using a resistor to trigger the ZT-2. I suck at electronics too, if its mechanical I can figure it out.
Offline
Old Aug 11, 2007, 11:02 PM   #8
SlowCar's Avatar
one more thing.....can you check with zeitronix or scott@ttp if the ZT2 can perform such a complex trigger:
If (boost >10psig) -and- (afr > 12.0) -or- (aux < 5VDC), trigger
dont remember if you can mix (-and-) and (-or-) because in the scenario that there is a partial clog where flow is below 375 but above 180, and you have:
If (boost >10psig) -and- (afr > 12.0) -and- (aux < 5VDC), it will not trigger....
__________________
Offline
Old Aug 12, 2007, 09:36 PM   #9
Personal Sales Rating: (122)
Ultimate CC's Avatar
Drives: 1983 Chevrolet K10 Stepside Pickup
Send a message via AIM to Ultimate CC
i believe we spoke in pms but if you need help still please let me know...
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
