Aug 10, 2007, 02:30 AM
Personal Sales Rating: ( 0)
Can three seven quart meth tanks be used with a snow meth kit on one pump?
Offline
Sep 2, 2007, 05:14 AM
Anybody ?
Offline
Sep 2, 2007, 06:18 AM
Personal Sales Rating: ( 4)
Drives: a drunken IX
you can use any tank size you want, thing to remember is to go for tall and narrow tanks so as to not draw gas bubbles into the pump intake when the injectant sloshes around.
here is an example of such a setup, triple 6 quarts
Offline
Sep 2, 2007, 09:50 AM
Personal Sales Rating: ( 122)
Drives: 1983 Chevrolet K10 Stepside Pickup
yea you certainly can...you can use just about any tank you can mock up to hold the meth but there is advantages of certain designs over others...if your interested in the 7qt tanks drop me a pm and i can get you a quote...
Offline
Sep 2, 2007, 11:03 PM
Is that your current setup? How much would it cost to buy three of those tanks? Where exactly did you buy them from? What equipment would I need mount the three tanks and to have them work properly on a daily basis Could I just use one 250 volt pump from smc or would the standard one just be fine for three of those tanks?
Offline
Sep 2, 2007, 11:25 PM
Personal Sales Rating: ( 22)
Drives: BBK powered EVO 8
^^that's a pretty sick hook up!! Sorry if this is a stupid question, but does the pump draw from all 3 tanks at the same time or one at a time until empty. I'm sure it would be all three at the same time.
Jason
Offline
Sep 3, 2007, 02:52 AM
Quote:
this is my setup
the 3 x 6 quarts setup is Milo's, more pics in the thread
Milo's 18 quart Aquamist HFS-5 methanol/water injection system + pics of car
Super Size It! - Aquamist HFS-5 Milo style
the 6 quart tank is ~$25 ea, more info on it here:
http://forums.evolutionm.net/showthr...10#post4568510
the mounting hardware are all bought from home depot
-1/8" x 1.5" x 36" aluminum strips
-5/16 bolts/nuts in 1" and 1.5" length
the schematics for hanging 2 or 3 of these 6 quart tanks
hanging twin 6 quart flambeau tanks
imo, this is the most well put together water/meth injection system available,
Offline
Sep 3, 2007, 02:55 AM
Quote:
Jason
they are all rigged to a common manifold, so injectant is drawn equally from the 3 tanks
Offline
Sep 5, 2007, 06:37 AM
What size pump are you using for the two tanks?
Offline
Sep 5, 2007, 06:47 AM
the both systems above share the same pump - Aquamist/Shurflo 150W by-pass pump
Offline
Sep 5, 2007, 06:52 AM
Would the pump that comes with the smc kit be enough to pump meth from lets say 3 6-7 quart tanks mounted like yours?
Offline
Feb 8, 2008, 08:20 AM
Personal Sales Rating: ( 21)
Drives: 2005 VIII
My inspiration...
Since I actually got my inspiration from this thread...I'll post up a pic of mine  YES, I know the thread is older and I'm bringing it back from the almost dead
I know the tanks are dirty (this was taken right after I did it and hadn't cleaned them). I also have cleaned up the wires so you really can't see them at all now.
The red stuff on the center tank has been cleaned off too.
I had to overlap the tanks because I wanted my full trunk space so the pump had to sit up there by them (the inner mounting holes of the two ouside tanks are shared by the mounting holes for the center tank). My old set-up was the pump screwed into a 5 gallon gas jug so this new set-up is much nicer hehe. I know about the height differences from the pump to the tanks but the pump has no problem pulling the juice. I had a similar set-up in my DSM and never had a problem with it. Enjoy
__________________
2005 EB VIII with everything except injectors and a bigger turbo!
Thanks to Evolution Dynamics for the great work!
Offline
Feb 8, 2008, 09:16 PM
looks great, thanks for the update...
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
