Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 30, 2007, 10:24 PM   #1
Personal Sales Rating: (4)
Drives: '94 Supra
HFS-5, one or two nozzles?
When I build a manifold in a couple of months for my new motor I plan on doing individual port injection, but in the meantime, assuming I'm going to place any and all nozzles right up by the throttle body, is there any advantage to 2 smaller nozzles vs. 1 bigger nozzle? I plan to run 50/50 water/meth, with about as much volume as I can push (around 1000cc/min I figure).
Thanks
Offline
Old Jul 31, 2007, 06:09 AM   #2
Personal Sales Rating: (17)
dudical26's Avatar
Drives: IX GSR
two smaller nozzles will have the advantage of being able to better atomize the water/meth mixture. It is always advisable to run several smaller nozzles than a single large nozzle.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Jul 31, 2007, 09:57 AM   #3
Personal Sales Rating: (2)
ryan0's Avatar
.. and my understanding is that you want them closer to the IC... something about more time to vaporize.
__________________
'05 MR
27 NOS, GREEDY and AEM Stickers
http://twitter.com/ryan_race
Offline
Old Jul 31, 2007, 10:05 AM   #4
dudical26's Avatar
Drives: IX GSR
Every location has its advantages and disadvantages.
You might not want a jet before the BOV as it will recirculat meth into the intake and turbo.
I put my jets as close to the BOV but still above it, and as close to the TB as possible.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Jul 31, 2007, 10:27 AM   #5
ryan0's Avatar
Quote:
did everyone ever come to a majority conclusion that misting a few CCs of meth vapor damages a 1000 degree metal wheel?
i mean its a sealed compartment of really hot metal, moving a lot of air volume through itself.. what could be damaged?
Offline
Old Jul 31, 2007, 10:49 AM   #6
Drives: '94 Supra
my understanding was that for water injection you want it close to the IC to give more time to remove heat, but for meth injection you wanted it close to the TB to minimize other problems (like blowing meth out the BOV, having meth come in to contact with more tubing (aluminum + meth = bad), etc...
Offline
Old Jul 31, 2007, 12:07 PM   #7
Personal Sales Rating: (1)
cpoevo's Avatar
Drives: no more Evo
If you mount it before the BOV when the BOV opens you have the possibility of water droplets hitting the compressor blades. Water hitting the blades will put excess wear on your thrust bearing and will erode the blades over time. I dont know how long a turbo will last with this setup but it is not ideal.
Offline
Old Jul 31, 2007, 01:26 PM   #8
SlowCar's Avatar
Drives: a drunken IX
Quote:
water works best in the cylinder where all the action is going on.
the methanol comes in contact witht he aluminum tubing only when sprayed, so its not an issue at all. When the nozzle is far from the TB, methanol having very low viscosity will wet the inside of the intake tract - with the HFS-5 or the HFS-1, you spray what is needed and the HSV/solenoid valve cuts it off when injection event is over...unlike valveless system where the excess pressure of methanol has to be "bled off" causing excess hosing down of the intake piping.
__________________
6 injectors, 3 fuel tanks and 2 fuel pumps
Aquamist HFS-6 install: ......:)
Aquamist HFS-1 install: http://forums.evolutionm.net/water-a...n-project.html
Aquamist 2D/DDS3 install: http://forums.evolutionm.net/water-a...tion-pics.html
Offline
Old Jul 31, 2007, 01:28 PM   #9
SlowCar's Avatar
Quote:
the wear from mist hitting the compressor blade will be very minimal compared to Pre Turbo Injection
__________________
Offline
Old Jul 31, 2007, 02:37 PM   #10
ryan0's Avatar
a mist hitting blades will put wear on a bearing?
whats your theory there?
the mist is so heavy it throws the assembly out of balance?
and a mist will erode the metal blades?
i can only think of "rain getting on your tires will wear out your hub bearings and eventually erode the tire."
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
