Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 30, 2007, 10:02 AM   #1
Personal Sales Rating: (8)
Drives: Evo8
Question Tuning H2O Injection Basics
I should have my HFS-5 aquamist kit installed shortly and would like to know if anyone has established some basics for tuning water injection.
Currently, I am tuned on 93 pump and target the following values:
AFR - During ramp up goes from 12.8 to 11.5 and then holds to redline
Timing - 6deg peak torque to 18deg 7250
Boost - 22psi tapering to 21psi at 7250
EGT - 1525 F at top of fourth
With this setup I am getting about 320 hp 280 ft-lb torque, I think that I maybe able to get more out of this setup and I am going to try and bump up the timing some.
With Water Injecting at 14% water to fuel what should I do first? Here are my thoughts please comment:
1) lean fuel to target - ramp up goes from 12.8 to 12.5 holds to redline
2) Increase timing throughout till limited by knock, this should bring down EGT
3) Back off timing from new limit 2 degrees
4) Increase boost till EGT exceeds 1550 F
5) Back off boost 1 psi
Edit: This is for 100% H2O
__________________
Mods: 3" TBE w/High Flow CAT, 264+ Comp Cams, Walbro 255 pump, 650cc Fuel Injectors, Perrin Fuel Rail, Aquamist HFS-5 kit, Megan Street Coilovers, Hard Intercooler Piping, GM BCS, Defi Boost, EGT, and Fuel Pressure Gauges, StopTech Stage 2 brake kit, 18" Volk GTUs Gunmetal
Offline
Old Jul 30, 2007, 11:47 AM   #2
Silver Sponsor
Personal Sales Rating: (5)
Drives: Citreon Xsara
Are you going to run pure water or methanol mix? if so , at what percentage?
__________________
richard@aquamist.co.uk
Offline
Old Jul 30, 2007, 01:42 PM   #3
Drives: Evo8
I will be running pure H2O initially.
Additionally, it maybe helpful to discuss the differences with tuning H2O vs. 50/50 water methanol mix, vs. 100% methanol.
__________________
Offline
Old Jul 30, 2007, 01:57 PM   #4
Personal Sales Rating: (2)
ryan0's Avatar
i found that running about 26psi, keeping afr around 11.8-12and adding more timing makes the car very happy compared to leaning it out even more.
__________________
'05 MR
27 NOS, GREEDY and AEM Stickers
http://twitter.com/ryan_race
Offline
Old Jul 30, 2007, 01:59 PM   #5
Personal Sales Rating: (17)
dudical26's Avatar
Drives: IX GSR
I have recently started to play around with my HFS-5 kit. I have an Evo 9 so my timing can not be as aggressive but other than that I have a similar tune to you.
running 100% water and using 2x .7mm nozzles I initially increased my boost from 21-22 to 24-25. I have left my fuel and timing the same for now as I plan on running meth and I am just using water to test. I notice occasional 1 or 2 counts of knock at an equal or lesser occurrence than before the water.
Your philosophy sounds pretty good. Personally I would target an AFR of about 12.0 rather than 12.5 on only water but to each his own.
Keep us updated on how it goes.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Jul 30, 2007, 02:17 PM   #6
Drives: Evo8
What is your reasoning for increasing boost first? Here is my reasoning behind the strategy I posted;
lean afr to 12.5:
From what I have read 12.5 is the best afr for making the most power, it is on the lean side for the Evo's best operating window. Using pure water should allow this lean afr due to its higher latent heat capacity than say methanol.
increase timing:
By increasing timing you create a faster (more complete) burn in the cylinder and will reduce the EGT values. This can be achieved to some extent with using water, but would be greater if using pure methanol due to its octane boost characteristics. By reducing the EGT values now it provides head room to increase boost in the next step.
increase boost:
This is where the real increase in power and torque should be seen. The use of water injection negates to some extent the fact that we are pushing the turbo outside of this efficiency window. Additionally, the in cylinder cooling effect of the water keeps hot spots from developing. Basically, in theory you should now be only knock limited by the octane of the fuel/water mixture.
I am trying to work through the reasoning behind my tuning strategy. Please if I am stating anything incorrect or if it is debatable comment. I have never tuned for water injection before and would like to educate myself and others about to attempt this.
__________________
Offline
Old Jul 30, 2007, 02:25 PM   #7
Personal Sales Rating: (7)
shivaswrath's Avatar
Drives: a stock EVO, a rarity amongst all
Send a message via AIM to shivaswrath
this may sound like a noob question since I'm new and keenly interested in water injection, but how do you guys deal with the water freezing in the winter? do you progressively add more alcohol or HEET to the water as temp's cool off?
I would run 100% water at first as well since it's cheaper than methanol, and easier to obtain. . .
__________________
Driving an unconventionally fast car with unconventionally functional styling. . .
"Sleeper Tarmac Black". IVEY tuned September 2007:325awhp/345awtq-Dynojet
"If you haven't driven an Evo, it's hard to explain why this car evokes feelings of utter lust; the driving experience is simply that pure" Road and Track, Feb 2005 Long term test
Offline
Old Jul 30, 2007, 02:37 PM   #8
Personal Sales Rating: (4)
SlowCar's Avatar
Drives: a drunken IX
water-methanol mixture - freezing point
http://www.ashland.com/pdfs/technica...sh%20Point.pdf
__________________
6 injectors, 3 fuel tanks and 2 fuel pumps
Aquamist HFS-6 install: ......:)
Aquamist HFS-1 install: http://forums.evolutionm.net/water-a...n-project.html
Aquamist 2D/DDS3 install: http://forums.evolutionm.net/water-a...tion-pics.html
Offline
Old Jul 31, 2007, 05:04 AM   #9
Drives: Evo8
Slowcar,
You have been doing this for awhile. Can you share what works for you when tuning?
__________________
Offline
Old Jul 31, 2007, 06:16 AM   #10
dudical26's Avatar
Drives: IX GSR
I like to tune boost first since a change in boost can have a dramatic effect on AFR and the timing you can run. If you tune AFR and timing first you will have to go back and adjust them for each change in boost.
I like to get a safe AFR and timing setup, then dial in boost.
For the most part it seems with water or meth injection you will reach almost the same HP at 25psi as you will with 30psi on the stock turbo.
I would suggest you start at 25psi with your safe timing and AFR. Once you get a nice boost curve, then adjust your AFR to hit your target. Lastly tune timing.
You can always tune for 12.5 AFR and then tune for 12.0 AFR and see which makes better power for you.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Jul 31, 2007, 06:38 AM   #11
SlowCar's Avatar
water-methanol mix:
http://www.srtforums.com/forums/showthread.php?t=308693
__________________
Offline
Old Jul 31, 2007, 10:35 AM   #12
Drives: Evo8
Slowcar,
Thanks for the read. Actually read this allready but it was a good refresher. If you really dumb this down to a simple procedure it states:
keep adding boost till the EGT rises above 1600 F to produce power (or you hit knock).
So based on input so far I have my steps in the wrong order. They should really be:
1) Start with a map optimized for non-water injection
2) Raise boost till EGT exceeds 1650 F or limited by knock
3) Lean afr down to 12-12.5 stop when power stops increasing or knock
4) Tweak timing to gain the last bit of power back off when knock starts
5) increase water flow and repeat till no gains are made
On a side note: What MAF values are you guys seeing at ~ 25psi? I would like to have an estimate so that I can scale my load range correctly.
__________________
Offline
Old Aug 21, 2007, 10:02 AM   #13
Personal Sales Rating: (33)
EVO8LTW's Avatar
Drives: 04 RS and 08 GSR
I'm finally getting to installing my HFS-5 and wanted to start with straight water.
What nozzle size should I use? My car on pump is in the 350 whp range (at 22 psi) and I have 660 cc injectors.
Thanks!
Offline
Old Aug 21, 2007, 10:48 AM   #14
Drives: LANCER MR SE
This is some good info
Offline
Old Aug 21, 2007, 11:26 AM   #15
Drives: Evo8
I just got the hardware completely installed last weekend and now in the process of figuring out how to adjust all the settings.
Currently, I am using a .8mm nozzle and injecting pure water. Based on my calculations I should be injecting between 315 and 360 cc/min at the top of each gear. This puts me at ~ 17% water to fuel given that I am using 650cc injectors.
Whether or not this is the best combination only tuning will tell. I will definetly post more as I learn more about how the tuning side works.
__________________
Offline
Tags
100, aquamist, evolution, h20, injection
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
