Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 26, 2007, 11:38 PM   #1
Personal Sales Rating: (122)
Ultimate CC's Avatar
Drives: 1983 Chevrolet K10 Stepside Pickup
Send a message via AIM to Ultimate CC
Snow Performance Compare: Check Valves vs Solenoids
Take a look and see why Snow Performance uses a free flowing, full stainless steel constructed solenoid while our competitors use restrictive check valves.
Are you looking to install a Boost Cooler kit with a rear mounted reservoir? Does your application require that you use a solenoid to prevent siphoning? These questions are easily answered with our latest Solenoid Upgrade.
The new Snow Performance Solenoid Upgrade features full stainless steel construction for the ultimate in longevity and reliability. This new solenoid is so effective that it creates less than a 5 psi drop in line pressure! That means more pressure, more flow, better atomization, and more power!
Our competitors use extremely restrictive brass check valves in place of a solenoid. These check valves have opening thresholds of over 40 psi! Brass and other soft metals aren't even methanol resistant. Our competitors have designed failure into their systems!
Offline
Old Jul 27, 2007, 12:27 AM   #2
Personal Sales Rating: (4)
SlowCar's Avatar
Drives: a drunken IX
whats the Cv of these valve?
__________________
6 injectors, 3 fuel tanks and 2 fuel pumps
Aquamist HFS-6 install: ......:)
Aquamist HFS-1 install: http://forums.evolutionm.net/water-a...n-project.html
Aquamist 2D/DDS3 install: http://forums.evolutionm.net/water-a...tion-pics.html
Offline
Old Jul 27, 2007, 10:17 AM   #3
Personal Sales Rating: (1)
GOTBOOST1023's Avatar
Drives: 05 EVO VIII MR in circles
How do you know if you need the solenoid upgrade?
__________________
Injen intake, Uicp, APS twin vent bov, Turboxs fmic, Apex catback exhaust, Apex downpipe, UR tp, MR manifold, MR O2, GSC S-1 Cams, Headstuds, 780 Injectors, Walbro pump, Hallman manual boost controller. ACT street clutch and streetlite flywheel, Snow meth kit , John Shepperd built case, Green Turbo @ 30 PSI
Offline
Old Jul 28, 2007, 12:10 PM   #4
SlowCar's Avatar
when you run a progressive pump speed alky kit, you will always need a solenoid valve...the ~20psi cracking pressure on a check valve will further reduce the already limited range of flow...among other things
__________________
Offline
Old Jul 28, 2007, 12:17 PM   #5
Personal Sales Rating: (52)
evodan2004's Avatar
Drives: 03 Evolution 8
Send a message via AIM to evodan2004
ok how much...
__________________
JESTR TUNING - FULL-RACE - SPARK TECH - NISEI ENGINEERING - DRIVEN INNOVATIONS - DOG BOX RACING
NEW JERSEY EVO OWNERS *THREAD*
My F/S thread STOCK & AFTERMARKET *CLICK HERE*
WTBWTBWTBWTB : Evo RS door handles
Offline
Old Jul 29, 2007, 09:39 AM   #6
evodan2004's Avatar
bump for how much
__________________
Offline
Old Jul 29, 2007, 04:55 PM   #7
SlowCar's Avatar
injection nozzles need ~40psig behind them to get decent atomization
on a 150psig pump the effective range of operation would be 60psig (40psig from nozzle + 20psig from check valve) to 150
on a commonly used MW7 injection nozzle, flow@pressure is as follows: 7GPH@100psig, 8.57GPH@150psig and 5.42GPH@60psig
(8.57-5.42)/8.57=0.36
you get only 36% useful range for the MW7 nozzle
nozzle flow vs. line pressure info:
http://www.hagonozzles.com/documents...M%20&%20MW.pdf
__________________
Offline
Old Jul 29, 2007, 05:14 PM   #8
Personal Sales Rating: (17)
dudical26's Avatar
Drives: IX GSR
^^ Cool Info ^^
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
