Jul 24, 2007, 02:11 AM
Silver Sponsor
Personal Sales Rating: ( 5)
Drives: Citreon Xsara
these are great information - just what the doctor ordered
__________________
richard@aquamist.co.uk
Offline
Jul 24, 2007, 06:42 AM
Personal Sales Rating: ( 17)
Drives: IX GSR
I bought my MAC valve from
Matt Tierney
Action Automation
508-699-7411-EXT 330
mattt@actionauto.com
Great guy, I highly recommend.
Offline
Jul 30, 2007, 12:16 PM
Personal Sales Rating: ( 4)
Drives: a drunken IX
just installed a HFS-5 system last week using twin 6 quart flambeau tank. IMO they are a little too big and require some trimming of the mounting sides of the tank to mount properly. twin 5 quart tanks will be better.
Offline
Jul 31, 2007, 10:38 PM
Personal Sales Rating: ( 0)
Drives: 03 audi a4, 03 honda rc51
double post, sorry.
Offline
ok I am lost now. So before I ask If the mac valve is needed, I need to ask what exactly it does. It's a failsafe I understand, correct? how so?
Offline
Jul 31, 2007, 11:13 PM
when there is injection failure or when power to the system is off, the mac36 valve, which is put between the turbo nipple ( high pressure side) and the wastegate line (low pressure side), will send all the boost pressure to the wastegate, opening it up and prevent you from building boost above ~12psig on a stock setup
Offline
Jul 31, 2007, 11:16 PM
ah I see. makes sense now. so definitely something to have. thankyou very much for the explanation that was easy to understand.
Offline
Jul 31, 2007, 11:25 PM
this is a very nice diagram from Richard@aquamist for the mac36 failsafe solenoid
 [/quote]
Offline
Jul 31, 2007, 11:28 PM
Personal Sales Rating: ( 30)
Drives: 2006 EBP IX
Quote:
Any pics on the install? Also how did everything go? I will buy on of these kits someday soon. Your thoughts on the system?
Offline
Aug 1, 2007, 12:25 AM
Drives: 2006 EBP IX
Offline
Aug 1, 2007, 06:18 AM
Silver Sponsor
Before everyone rush to get a MAC valve, please note that if your car is fitted with a factory BC valve or any electronic boost valve, you don't need the MAC valve to action the failsafe.
You only need the MAC valve if you have a MBC valve (Manual Boost Control valve)
There are two types of MBC valve, I will make another drawing for that a bit later.
__________________
Offline
Aug 1, 2007, 06:32 AM
Personal Sales Rating: ( 18)
Drives: Evo8
How about a link for a hobbs switch for activating an hfs1 system?
__________________
*Quickest and Fastest stock turbo/cams VIII (2006)*
*Fastest Stock Turbo VIII on gas. (2007)*
*Quickest and Fastest BBK Full (2009)*
*2nd Place - Stock Appearing Class - BR Shootout (2009)*
*Rush Group Detailing*
____*Boost Rush*____
Offline
Aug 1, 2007, 09:31 AM
Quote:
owner will post pics in a few days
at the end of the install, i powered the system using a 12vdc unswitched-system stayed on, moved the power wire to a 12vdc switched and fixed problem
this system is extremely well engineered, very well thought out down to individual component level(pump, flow sensing failsafe, mode of injection delivery) The ultimate WAI technology
Offline
Aug 1, 2007, 09:33 AM
Drives: IX GSR
Abner - were the wiring pinouts I provided incorrect or did you just try wiring it to something else before hand?
Offline
Tags
062600, 36aaaajdba1ba, alcohol, boost, control, failure, flambeau, hfs1, injection, installation, kit, mac, meth, solenoid, tank, valve  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
