Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 15, 2007, 08:09 PM   #1
Personal Sales Rating: (5)
Drives: 05 VIII
Send a message via AIM to APEX1
Aquamist
Why buy an hfs-5 over a hfs-1 kit???
Offline
Old Jul 16, 2007, 03:49 AM   #2
Drives: 05 VIII
Im just trying to get as much info as possible- cause Im calling Jack to buy today after work.
Offline
Old Jul 16, 2007, 06:48 AM   #3
Personal Sales Rating: (17)
dudical26's Avatar
Drives: IX GSR
the HFS-5 is progressive. The amount of meth/water it sprays will mirrors your injector duty cycle. This means that when the system first turns on only a very small amount will be injected and then as you use more fuel, more water/meth is injected. This is what progressive means.
The HFS-1 is not progressive; it is either full on or full off.
They both have the same failsafe technology, gauge readout, pump, etc...
The HFS-5 will be easier to tune and smoother in the delivery of meth.
The HFS-1 is mostly for people who want a very simple meth system but also want the added benefit of having a very high quality failsafe, and other kit components. In my opinion it makes more sense to get the HFS-5.
Or you can by the HFS-1 now and upgrade later for ~$275
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Jul 16, 2007, 08:05 PM   #4
Personal Sales Rating: (6)
aqmist's Avatar
Drives: SRT4
Thanks Alex. A little technical correction though. The HFS-5 is not progressive its linear to the flow of fuel. The HFS-5 uses the HSV (High Speed Valve) and the FIA2 to mirror you FIDC so that W/A injection is more or less a mirror of the fuel injection system = load is more accurately addressed with this system.
Offline
Old Sep 23, 2007, 11:55 PM   #5
Personal Sales Rating: (20)
Inprogress's Avatar
Drives: 2006 EVO IX
Send a message via AIM to Inprogress
Sorry to bring this back up...
Seeing as how the HFS-1 is on/off, why would the tuning of the HFS-1 be more difficult?
__________________
2006 Evo IX
GSC S1 Cams // Megan TBE // PTE 1000cc Injectors // Apexi Filter // Perrin FMIC // AMS LICP // ETS UICP // Walbro Pump // Hallman MBC // ACT HDG6 Clutch + ACT Streetlite Flywheel // BC Coilovers // Blox Front Mount
"We are what we repeatedly do. Excellence, therefore, is not an act, but a habit." -- Aristotle
Offline
Old Sep 24, 2007, 07:17 AM   #6
Silver Sponsor
Personal Sales Rating: (40)
2003 Mitsubishi Lancer Evolution
My Garage
KevinD's Avatar
Drives: '04 evo8 daily driver, '03 evo8 time attack car, 08 outlander
Send a message via AIM to KevinD
the turn on point where the methanol starts coming in causes a large change in the amount of gasoline that needs to be injected. its like instantly adding 20% more fuel, thus your injectors must inject about 20% less when the meth turns on. because tuning a car is done using lookup tables, this causes a problem where the table doesn't have the ability to fine tune a transition where the meth turns on (they only have so many fields where you can tune in the tables). you wind up having a lean spot before the meth turns on, or a rich spot immediately after. it takes quite a bit of work to balance the transition point.
__________________
EVOLUTION DYNAMICS LLC
Tuning, Custom Fabrication, and installs in the DFW area.
www.evodynamics.com
email: evokevin@gmail.com
Phone + Text messages: 817-776-2170
Kelford, mil.spec, ACT, Aquamist, FIC, ShepTrans, Zeitronix, + many others
Evo Dynamics Unlimited Time Attack Build
3-Port PnP Boost controllers for Evo 8/9/X and RA
Join us on FaceBook!
Offline
Old Sep 24, 2007, 07:18 AM   #7
Personal Sales Rating: (4)
SlowCar's Avatar
Drives: a drunken IX
the hfs-1 is just as predictable as the hfs-5. tuning is a breeze
__________________
6 injectors, 3 fuel tanks and 2 fuel pumps
Aquamist HFS-6 install: ......:)
Aquamist HFS-1 install: http://forums.evolutionm.net/water-a...n-project.html
Aquamist 2D/DDS3 install: http://forums.evolutionm.net/water-a...tion-pics.html
Offline
Old Sep 24, 2007, 08:56 AM   #8
Inprogress's Avatar
Drives: 2006 EVO IX
Quote:
After Jestr tuned your car, did it have any rough spots like the one suggested it might have?
Abner, do you have any partial throttle or partial boost issues?
__________________
2006 Evo IX
Offline
Old Sep 24, 2007, 11:57 AM   #9
SlowCar's Avatar
there are a few, which can be tuned out - KevinD is helping me out with that.
partial throttle sometimes trigger the injection, not an issue at all
__________________
Offline
Old Sep 24, 2007, 11:01 PM   #10
Personal Sales Rating: (91)
DynoFlash's Avatar
Drives: 9.50 @ 148 (no nos)
I agree - I have found the HFS-1 to be really easy to tune and a total delight
While the HFS - 4 is slightly smoother and easier to map - in the end the HFS-1 is a really neat kit and a total pleasure to work with
Al
Offline
Old Sep 24, 2007, 11:02 PM   #11
DynoFlash's Avatar
I have found that careful adjustment of the trigger can elminate a lot of issues with partial tps activation
Offline
Old Sep 24, 2007, 11:55 PM   #12
SlowCar's Avatar
Quote:
when i set up my system back in jan2007, i went with a boost trigger = 10psig. I was not sure of how things will work out then using idc trigger. The few hfs i have done since have been idc triggered and i like it better.
__________________
Offline
Old Sep 25, 2007, 06:12 AM   #13
Personal Sales Rating: (9)
deadbeatrec's Avatar
Drives: 04 Z06
so far the HSF-1 is a high quality kit and i have had nothing but support from AL and Richard L with any issues i have had.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
