Jun 26, 2007, 07:03 AM
Personal Sales Rating: ( 52)
Drives: 03 Evolution 8
what's the best jet to spray meth????
Hey all. Ok I got meth injecton. Coolingmist meth kit.. I'm going for 500hp.. ( yes bigger turbo) What I'm wondering is what is the best jet to spray meth and what size is recommended.. I know all different jets spray a different patern and what not. What one is the best and why?? Plus again what size will I need.... thanks for the help
__________________
JESTR TUNING - FULL-RACE - SPARK TECH - NISEI ENGINEERING - DRIVEN INNOVATIONS - DOG BOX RACING - MPFab
NEW JERSEY EVO OWNERS *THREAD*
My F/S thread STOCK & AFTERMARKET *CLICK HERE*
WTBWTBWTBWTB : Evo RS door handles
Offline
Jun 26, 2007, 07:22 AM
Personal Sales Rating: ( 17)
Drives: IX GSR
How big are your injectors?
What duty cycle do you typically see throughout your rev range?
Are you going to run 100% meth, water, etc...?
Offline
Jun 26, 2007, 07:27 AM
Personal Sales Rating: ( 3)
Drives: 530whp WRX sold to secret squirl
Coolingmist will tell you what is best for your application. Just give em a call.
__________________
Now I drive the IX!
Offline
Jun 26, 2007, 08:38 AM
Oops my bad..
100% meth
1000cc RC injectors
Stock ecu
Duty sycle I don't know because I'm building the car up now. It will have a 3076 or like tubro on it... going for 500hp around that ballpark..
__________________
Offline
Jun 26, 2007, 08:52 AM
Quote:
Ok that's cooling mists recommendation... many companys make many kinda of jets. Big small and with different spray paterns. My question is what spray patern is best and what company makes it.. And what size do I need.
__________________
Offline
Jun 26, 2007, 11:01 AM
Drives: IX GSR
I think every company provide jets that have a cone shaped spray pattern. Some might have a wider angle cone but I think most companies provide fairly similar jets. Your best bet is to use Coolingmist jets as they will probably hook up to your system easily.
Offline
Jun 26, 2007, 12:54 PM
Personal Sales Rating: ( 4)
Drives: a drunken IX
use 2 smaller jets spaced apart than 1 big one. distribution and better atomization can be achieved
Offline
Jun 26, 2007, 06:43 PM
Quote:
where do you recommend putting each jet?? i was thinking insted of putting it on the uicp can we tap it into the top of the intake manifold???
what size jets do we use for a dual spray 500hp car??
__________________
Offline
Jun 27, 2007, 12:28 AM
space the meth injectors ~intake manifold width apart.
as to jet size for high powered/boost evo, scott@ttp or 94awdcoupe are the gurus at that
Offline
Jun 27, 2007, 03:11 AM
Ok so put on at the bend on the uicp like spraying into the t/b and the other about 1 foot down from the top jet into the mid piont of the uicp??? Thanks man
__________________
Offline
Jun 27, 2007, 07:58 AM
Also I recerc my bov. Not sure if it matters but should I put the second jet befor or after where the bov tube meets the uicp
__________________
Offline
Jun 27, 2007, 07:53 PM
bump for more info?
__________________
Offline
Jun 28, 2007, 05:19 AM
Bump
__________________
Offline
Jun 29, 2007, 04:58 AM
Bump
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
