Jun 23, 2007, 12:59 PM
Personal Sales Rating: ( 2)
Another HFS-5 install
few quick pics
pump mounted in the driver's side rear trunk well. pump head down and well below the tanks. there is also a grommet down there for running the hose under the car.
tanks
HSV and flow sensor mounted on aluminum brackets on the firewall.
gauge in a-pillar
nozzle location in uicp.. could have put it lower right after the IC, but i wanted to be able to change nozzles without getting under the car.
modules all wired up.
wiring for DDS3
wiring for AEM
i have set the AEM NOS trigger and HI/LO boost trigger to 'Switch #4 GND=ON'... this tells the AEM to use those maps as long as the DDS3 doesn't report any failures.
the flow is triggered by MAP pressure at around 11psi.
Offline
Jun 23, 2007, 01:02 PM
Personal Sales Rating: ( 3)
Drives: Evo IX MR Apex Silver
Very clean install,nice.
Offline
Jun 23, 2007, 10:44 PM
Personal Sales Rating: ( 4)
Drives: a drunken IX
very nice spot for the mighty aquamist/shurflo pump!
Offline
Jun 23, 2007, 11:19 PM
Personal Sales Rating: ( 17)
Drives: IX GSR
Nice looking install, I was also thinking of installing the pump in that location. My only concern was what would happen if some one hit me in that corner (smashing metal and 125psi methanol). Have you given that any thought, just wanna make sure you consider safety risks.
Offline
Jun 24, 2007, 08:22 AM
Personal Sales Rating: ( 6)
Drives: SRT4
Ryan, I have sent fittings and other small odds and ends out to different people over the past couple of weeks. Are you waiting on one from me?
If not get me an email with your shipping info and exactly what you need to:
jackblalock(AT)gmail.com
Offline
Jun 24, 2007, 07:50 PM
Quote:
never even thought about it.. im running pure water and would never run over 50/50 anyway.
Offline
Jun 24, 2007, 07:51 PM
thanks jack.. just sent you a few emails.
bump for extra pics.
Offline
Jun 25, 2007, 07:45 AM
Drives: IX GSR
With your nozzle mounted before you BOV you will be recirculation air/water mix back into your turbo and IC. That’s not really a problem but there is some evidence that spraying water or meth into your turbo may lead to premature wear of the turbo. It might not matter as your water should be completely atomized by that point but it is something worth considering.
Offline
Jun 25, 2007, 02:04 PM
Drives: SRT4
Ryan I sent the needed extra parts today via USPS priority mail. When you get things fitted up please repost revised images. Threads like these are very helpful to other installers.
Theres a HFS-1 group buy going on right now with some users selecting dual tanks....images help the next person doing an Aquamist install....thanks.
Offline
Jun 26, 2007, 02:48 PM
Silver Sponsor
Personal Sales Rating: ( 5)
Drives: Citreon Xsara
Excellent pictures!!!
The pump location is very clever especially the bracket. Look forward ot more pictures.
__________________
richard@aquamist.co.uk
Offline
Jun 28, 2007, 07:40 PM
got my extra fittings today.. will get them installed and get a write up on my interfacing with the AEM EMS.
thanks again!
PS. I suggest an extra meter of 6mm hose and the 4mm to 4mm quick disconnect for changing nozzles.
I used every inch of 6mm and have cut my 4mm 4 different times to change nozzles.. heh
Offline
Jul 2, 2007, 10:11 AM
bumped for complete pics.
Offline
Jul 3, 2007, 10:03 AM
Personal Sales Rating: ( 24)
Drives: 07 JGC SRT8
great install pics. i'll be doing dual tanks, but on the HFS-1 and you've given me some great ideas as far as install. thanks!
Offline
Jul 3, 2007, 04:19 PM
Drives: SRT4
Hello Ryan, updated pics look nice......this kind of stuff helps everyone.......great stuff
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
