Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 23, 2007, 12:13 PM   #1
Personal Sales Rating: (21)
Drives: 05 element, 03 evo (mutating)
jet location
currently injecting about six inches in front of the throttle body and am able to tune afr above 12.5 (if I wanted) without knock.
so it seems I have plenty of water injected for this purpose, since I am happy with that its time to make other refinements.
now I am wondering if I can inject water with another jet located right after the intercooler while still getting the adequate water through the downstream jet.
set up is:
number 8 jet six inches before throttle body, hfs 5 system
if I were to run a 7 before the throttle body would the hfs have the capacity to flow another jet?
what size jet would be suitable for simple charge cooling given the additional jet downstream?
in my application I don't need more power necessarily just looking for optimum running. Last time at the road course I was disappointed to find an increased boost pressure did not equate with better driving. iow 3 additional psi had no positive results
thanks
Online
Old Jun 24, 2007, 08:48 AM   #2
Personal Sales Rating: (6)
aqmist's Avatar
Drives: SRT4
You can mount another jet without any supply issues, the pump is up to the task.
With jet selection I use a ratio of water to fuel. You will have no issues running 2 jets unless they are way over sized for needs = flood the combustion chamber with too much cooling. I have ran two jets similar to as what you described. I think this is a fantastic way to make the most of water injection. Typically jet location was a trade off, closer to the IC exit tank the better for intake air charge cooling, the closer to the combustion chamber the better knock suppression. With two jets you can tackle both of these.
Heres a link to help with jet selection.
http://www.srtforums.com/forums/showthread.php?t=306782
Now for which jet where, by using the jet adapters you can easily experiment with jet locations or easily swap jets around while doing a dyno or road tune. I found out that my best results were with two jets, the bigger of the two was located near the TB and the smaller was nearer the IC.......one jet was 0.7 and the other was 0.9 using the Aquamist race pump.
With my two jet system I slightly violated the 10%-15% rule and had about 20% - 25% of water.......I had some fuel tuning going on so it worked for me.
If I were you I would get another jet adapter fitting located near the IC exit tank and then add in the second jet and use the "Y" fitting connecting the two to the HSV. Do some runs and then swap jets around and do some additional runs to see what works best for you.
Contact me if you need additional hardware or jets.
Offline
Old Jun 24, 2007, 08:57 AM   #3
got one of the hfs restricters in the line now, with the two jets the restricter would be a hindrance?
Online
Old Jun 24, 2007, 10:30 AM   #4
aqmist's Avatar
Drives: SRT4
HMMM, very good question. Let me review this with Richard so I do not inadvertently mislead you.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
