Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 17, 2007, 03:06 PM   #1
Personal Sales Rating: (11)
Evo9tunerz's Avatar
Drives: you crazy..........
Setup on Nitrous?
What basic mods do i need to run nitrous? I have been thinking about it for a while now. The only thing i worry about is breaking something, but with a good tune i shouldn't worry, right? Have a couple of questions for you guys that run nitrous.
1. Where do you guys buy the kit?
2. Have you guys experienced any problems running a small 50 shot kit?
3. How does it work if i only spray sometimes on full throttle. Do i have just one map for spray and no spray? Or is there a way a different map is activated when i spray.
Thanks in advance........
__________________
Wife says "All the stuff you buy for your car sounds the same!"
Offline
Old Jun 17, 2007, 03:15 PM   #2
Personal Sales Rating: (16)
sekula's Avatar
Drives: Evo VIII, R6
Send a message via AIM to sekula
1. You can buy the kit from many places...such as slowboyracing.com...i've seen a couple kits there...
2. One of my buddies run a 75 shot on their 04 evo 8 and haven't experienced any problems....i tuned for their setup and in the end we took out about 2-3 degrees of timing at WOT and adjusted the fuel a little and so far 0 knock and pulling timing and the car feeels strong!
3. Usually, the kits come with microswitches that you mount on your throttle body or behind the pedal so when you go WOT, it clicks and activates the solenoids to spray at only WOT throttle...and before you spray, you have to arm it with a switch that they also give you....My buddy has the stock ecu and runs only one map that works for nitrous and pump for him...i set it up so its the most ideal setup for nitrous, and then when he feels like screwin around w/out nitrous, he just uses nitrous map and it still feels pretty strong since there's only about 2 degrees retarded...
__________________
Quote:
Originally Posted by morgantj13 View Post
lol, i hate when i have a dream where something bad happens(like my car breaks) or something good happens(like I win a lot of money) cause then I feel bad when I wake up because I thought my car was wrecked, or because I just realize Im poor lol
Offline
Old Jun 18, 2007, 01:33 PM   #3
Personal Sales Rating: (2)
pac74's Avatar
Drives: 2003 evo
see what i have in my mods. I had a 50 shot without tune, and was still pig rich 8.5 a/f now I'm about 11 a/f
__________________
03 evo 1.6 60ft/12.1/@117mph new!
also I need a stock hose that connects to thottle body!!![/color]
MODS: ecu flash/ 3" busher tbe / hallman in cabin mbc / 255 walbro fuel pump / zex wet kit / panasonic 7.5 touch screen / apc 30 psi boost gauge / new dash gauge kit /APC cold air intake /exedy stage 2 clutch
Offline
Old Jun 18, 2007, 03:40 PM   #4
Evo9tunerz's Avatar
Do you guys run wet or dry? Where do most people tap their nozzle?
__________________
Offline
Old Jun 19, 2007, 07:03 PM   #5
Personal Sales Rating: (0)
Drives: Evo 0
On a turbocharged engine, wet is the way to go. For a 50 shot I would go with spark plugs that are one heat range colder than stock. Some sort of datalogging device to monitor knock would be a good idea as well. What are you using for tuning?
Offline
Old Jun 20, 2007, 03:21 PM   #6
Evo9tunerz's Avatar
^^ evoscan and ecuflash.
__________________
Offline
Old Jul 13, 2007, 10:58 PM   #7
Personal Sales Rating: (15)
Drives: 05 EB EVO GSR 1996 Beater Civic
maybe someone can show us the safest way to hook it up with the stock ecu?
Offline
Old Jul 15, 2007, 04:45 PM   #8
Personal Sales Rating: (9)
Drives: 95 GSX, 05 Evo 8, 91 TSI AWD
I like the "wet" Zex kit made by Comp Cams. It is very simple to install and really doesn't need any other tuning. I use this on my car as well as have installed this kit on 3 other evo's. Cheapest & easiest .5 sec. et drop you can do! It comes with 35, 55, and 75 HP jets. Hope that helps!
Offline
Old Jul 16, 2007, 09:54 AM   #9
HOSTILE_EVO's Avatar
Drives: 2.3L EvoGreen
i have yet to instal mine, but... i went with a direct port system from nx. i feel that the even distribution of the direct port might save m some sleepless nights and also allow for a bit more accuracy when tuning. just my 2 cents.
__________________
ROBISPEC///
"...rotate a little!"
LIFE FEEDS ON LIFE... DEVOUR TO SURVIVE...
Offline
Old Jul 28, 2007, 07:00 PM   #10
Flyin EVO 2's Avatar
Drives: 1993 Mitsubishi Lancer Evo 2 (left hand drive conversion)
All turbo cars should use a wet set up. For a 50hp shot you should pull 2 degrees of timing out when the spray hits and thru the rest of the timing map where your spraying. The consertive rule of thumb is -2 degrees per 50 shot. You should also only spray with 110 octane or higher, and keep it around 11.5 to 1 on spray. Of course you can go more aggresive or use a cheaper fuel, but is it worth a busted motor?
__________________
9.99 @ 150.56 mph
On all season tires & straight E85
9.8 @ 147.8 mph
Low boost easy pass on slicks & straight E85
Second Place awd Dyno pull @ Shootout '09
First Place, Subaru vs. Mitsubishi Showdown '06
First Place, Import Wars # 6 '06
Second Place, NOPI St. Louis '06
Semi-finalist, NOPI Finals '06
Second Place, Shootout '05
Second Place, Subaru vs, Mitsubishi Showdown '05
Third Place, Shootout '07
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
