Jun 7, 2007, 06:32 PM
Personal Sales Rating: ( 42)
Drives: the racing line
High load timing with alchy
When you fellas are hitting 260-280 load levels what kind of timing are you aiming for? I am attaching my alchy timing map. I normally see 7* at peak and 16* at redline. I've been increasing my boost and now I'm starting to see loads nearing 280. I'm curious if the timing in my 260 cells are to aggressive to simply rename that load cell to 280.
__________________
TARMAC BLACK 2006 EVOLUTION 9 SPECIAL EDITION
OHLINS DFV /// ETS FMIC /// ZEITRONIX WB & MAP /// JDM REAR /// PERRIN REAR SWAY BAR
JEFFJESKE@JEFFJESKE.COM
Offline
Jun 7, 2007, 06:33 PM
Personal Sales Rating: ( 10)
Drives: 2006 EVO IX
Redo that link, cant see the pic .... just thumbnail
Offline
Jun 7, 2007, 06:37 PM
The following is not my alchy map but another members. I'm wondering which map more closely matches what other folks are doing.
__________________
Offline
Jun 14, 2007, 09:01 PM
Silver Sponsor +1
Personal Sales Rating: ( 445)
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Your timing needs to be rescaled.
There is likely a little too much timing at peak tq depending on boost level.
You should not be tuning without knocksums data.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Jun 14, 2007, 09:26 PM
I'm tuning with a wideband and evo scan. I see no knock at all. I was thinking my timing is to tame. I have rescaled my maps to 300 load (jumps from 260 to 300). When logging with 2 byte load I am seeing 285 falling to 260 loads. For the most part I see 7* through most of the midrange then it rapidly climbs to 16*.
From what I hear alot of people run 10* at peak and 20-22* at readline.
__________________
Offline
Jun 15, 2007, 06:17 AM
Personal Sales Rating: ( 17)
Drives: IX GSR
I dont know how much boost your running or what your AFR might be but its possible that your timing is a little conservative. But rather then setting your timing based on what others have done you can just try increaseing it slowly untill you develop some knock, then back it off a degree or two. If you really have no knock as you said and assuming your boost and fuel are where they should be I would try bumping up the timing a bit.
Offline
Jun 15, 2007, 07:39 AM
Boost is at 26psi then if falls to where it falls. Its different in every gear. Afr's are 11.5:1 because this is primarily an open track car.
__________________
Offline
Jun 15, 2007, 07:47 AM
Drives: IX GSR
I am no expert but that seems fairly conservative to me. However, is you are tunning this for road racing then the margin of saftey you want to have is up to you. You could almost certainly make mroe power by leaning it out a bit more and upping the timing, but then you will have a smaller margin of saftey. As it is now, it seems your tune is pretty safe and would probably be great for road racing, if you are willing to have a smaller margin of saftey then lean it out a bit and up the timing.
Offline
Jun 15, 2007, 11:51 AM
I guess the reason I ask is.... to me it seems fairly aggressive when compared to the stock map. I know I am adding octane with the alchy but still, on average for 100 octane, most people say add 2-3* timing and lean out the mixture to 12:1.
If you compare the stock 260 load cells to my 260 load cells the thing is MUCH more aggressive. Take a look at the attached JPG.
My peak timing is +8* +10* from the stock map. I am carrying that time through to a 300 load.
I wonder what the bigger turbos tune for timing wise at 320-340 load cells. Are we to simply stick with the 6* at peak 16* at redline train of thought regardless of load?
__________________
Offline
Jun 15, 2007, 11:12 PM
Personal Sales Rating: ( 5)
Drives: '08 Triumph Daytona 675 SE
IMO, I wouldn't worry about comparing to the stock 260 load cell timing values. It almost looks as if Mitsu set it ultra conservative in the event of an overboost situation, e.g., boost hose coming off the wastegate or someone with no clue cranking up their mbc.
__________________
'03 Evo VIII- 11.5@125mph- SOLD :(
Offline
Jun 27, 2007, 12:08 PM
Drives: Curzio's mom
Well man, best way to tell is on the dyno, baring that, find a single stretch of road to test on and do timed accel runs. It is possible that you can run more than the optimum timing without the knock sensor getting upset. Best way to tell is on a good dyno so you can keep adding timing till you see no return in power or a decrease in power then back it off a degree or two.
__________________
Wicked White GSR SSS 93pump - 363 awhp @ DYNO4MANCE Dyno Dynamics with 1.0 C.F. (448 hp shootout) Blouch Dominator 1 | Cosworth MX1's | HKS EVC VI | Ultimate Racing 02 Back | RC 750cc | DYNO4MANCE EcuTek Tune Old Whip: 93pump 21psi - 340 awhp @ DYNO4MANCE Dyno Dynamics with 1.0 C.F. (~392 dynojet) L.Y. VIII | DYNO4MANCE Tuned AEM EMS | HKS 272's | FPGreen | Cusco Twin | Shep Stg2 TC | KW V3's | TE-37's
Offline
Jul 3, 2007, 06:01 PM
Personal Sales Rating: ( 2)
Drives: Lancer Evolution SST
Really it depends on which school you belong to
Use alky as fuel substitute and lean out the fuel while running lower timing ..
OR
Use alky as knock suppressant and run as high timing as possible ..
Had a friend with whom I helped tune on the dyno with alky ..his timings had to be +6-9* above stock before it recovered some of the lost power .. ended up with almost +12-15* across to be about 30whp on top of his original hp.. .. yes .. at the 240-260 load site I've 25-26*  scary **** ..
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
