May 31, 2007, 07:05 PM
Personal Sales Rating: ( 0)
Smc not spraying, supposed to get tuned tomorrow.
I just added a SMC kit to my car and can not get it to spray. The kit is the one that replaces the intercooler sprayer, i bought it off a member on here a few weeks ago. I hooked the power straight to the battery with a relay inbetween to give me a clean power source. I butt connected the four wires from the control to the pump. The boost line was t-ed right after the boost controller goin to the wastegate. The two wires comming off the tank were on one O shaped terminal and figured that was a ground so i did. The control shows a strong green light for power, a strong red light when the tank was empty, but when i press the test button for the spray the orange light is very dim. I also tried boosting the car and watched my air/fuel ratio to see if it got richer but it didnt. I didnt get any instructions when i bought the kit, and Im suppoed to be getting a flash tomorrow so any help would be great.
Offline
May 31, 2007, 07:09 PM
Personal Sales Rating: ( 17)
Drives: 09 MB C63 AMG, 07 VW GLI Turbo(DSG),06 Evo IX SE. 95 Eclipse GSX... Evos gone!
Cheack your ground. Is the controller showing two lights (green and Amber)simultaneously?
Please respond. I will try to assist you the best I can.
Carlos
__________________
Celebrating my 5th anniversary on this forum. Also 5 years now since I first picked my first Evo (Evo 8 MR), 4 years since I picked my new (second) GG Evo 9 and now 5 years later enjoying my third Evo(Evo IX SE with only 14000 miles) ..again!
Offline
May 31, 2007, 07:16 PM
the amber only comes on when i press the test button and its very dim
Offline
May 31, 2007, 07:18 PM
the green has never went off. ( dunno if it is supposed to when spraying or not)
Offline
May 31, 2007, 07:24 PM
So the Green is always on right?, if the green is always on at least you are getting power to the controller via red wire with inline fuse. The weak amber light perhaps reveals a weak ground.
When you press the test button what happens? do you hear any noise? We are looking at a pump noise.
Get back with me.
Carlos
__________________
Offline
May 31, 2007, 07:30 PM
Personal Sales Rating: ( 116)
Drives: 04 Evo 8
mine did the very same thing, it the yellow light was showing very very dim. when i had someone spray it, the gauge would not read more than 40 psi. i called smc and he told me that it was the diaphragm. i sent it to him and he replaced it free of charge.
again, check to see the pressure on the gauge and try to hear the pump.
__________________
9.0 wiseco/crower motor, FP green, PPI ported 10.5 hotside/exhaust/intake manifolds, PPI 65mm TB, S2 cams, SMC meth, intake, exhaust, ETS FMIC, O2 housing, Forge MBC.
Tons of suspension mods!!
Faisal (586) 610-2830
Offline
Yeah green is def always on. When i press the test button i dont hear anything. The amber light is barly visable even at night.
Offline
May 31, 2007, 07:32 PM
Are the wires comming from the top of the tank itself also grounds?
Offline
May 31, 2007, 07:33 PM
It looks like the pump is not working at all: No amber light, no pumping noise.
Do you have a couple of extra wires laying around your garage? if you do so we might try to wire the pump straight to the battery just to test operationalbility.
Also, just keep in mind that the gauge is another indication of no flow from the pump.
Hit me back.
Carlos
__________________
Offline
May 31, 2007, 07:41 PM
yeah i got some wire laying around but i guess it will have to wait till tomorrow morning now. I dont have a pressure gauge on it but i def dont hear a pump and had my ear by it while a friend pressed the test button.
Offline
May 31, 2007, 07:58 PM
Running the pump directly from a DC power source will rule out many other components like:
Bad test button
bad ground on the pump
bad/faulty all weather harness wiring
We need to do that basic test.
Carlos
__________________
Offline
May 31, 2007, 08:05 PM
Are those wires from the tank grounds too?
Offline
May 31, 2007, 08:09 PM
Any pics?
Carlos
__________________
Offline
May 31, 2007, 08:11 PM
No i could get some tomorrow but i cant tonight. They are on the top side of the tank. Not far from where you fill it. All the other wires are down bottom by the pump.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
