Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 16, 2007, 09:56 AM   #1
Personal Sales Rating: (25)
silex's Avatar
Drives: The DRK*IXT
Send a message via ICQ to silex Send a message via AIM to silex Send a message via MSN to silex Send a message via Yahoo to silex
Priming/Testing Pump for Alky Injection Setup
I have the Stage 2 Coolingmist kit.
http://coolingmist.com/detailpage.as...controllerkits
I put everything together right according to the documentation and everything powers up. The only issue I see I'm having is the pump. I can't seem to power it up. I tried connecting a 12v source to it in order to make sure the pump turns on and all it does is sit there, no sound, no sucking. How do I go about testing that everything works? I didn't hook up the controller nor have the inject connected for the test. Would this matter? Please help as I have yet to use the system and I'm hoping nothing is wrong
Offline
Old May 16, 2007, 11:57 AM   #2
Personal Sales Rating: (1)
Drives: 06 Elise. 09 BMW 135I
Take the pump out of the box and hook the red wire to your car battery. Hook the black wire to the battery ground. When you do that the pump will vibrate/turn on.
I have never seen a shurflo pump that doesn't work. All pumps are tested before they leave shurflo facility.
Thats for testing the pump.
CM
Offline
Old May 16, 2007, 01:08 PM   #3
silex's Avatar
Drives: The DRK*IXT
Thanks for the update. I will test it later today the instant I have access to a car battery.
Offline
Old May 18, 2007, 09:24 AM   #4
silex's Avatar
Drives: The DRK*IXT
Wanted to post our convo from PM since it might help somebody else in the future. Also had a couple more questions.
Quote:
Originally Posted by coolingmist
Quote:
Originally Posted by silex
I'm the guy you responded the thread to as well as the guy who sent an email with the exact same paragraph explaining the problem, lol.
Anyways, I tested it out and it works great! Pump primed and water started squirting out the other end. So mechanically everything is working which means ther emust be an electrical issue. This is good news, so now I'm wondering this still...
My vari-cool progressive controller keeps blinking green and never goes solid. Is there a reason it would do this?
If your controller is older it will only blink. If its newer it will go solid when it injects. If your boost port is Silver it will just blink, if its brass colored it will go solid.
CM.
Oh!!! My boost port is silver! It blinks slowly for 2s upon startup and then continues to blink fast for as long as it is on. I guess that's why there is a LED for the Status Monitor and Clog Detector. So at least we can see when fluid flows or clogs that way. Is it supposed to light up when it injects and flash when there is a clog? Guess we pinpointed the problem. I will have to check those electrical connections to the LEDs as they obviously are not turning on at the right time.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
