Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 18, 2006, 11:23 AM   #1
Personal Sales Rating: (4)
itzwolf's Avatar
Drives: Yellow Evo VIII
Question SMC Dip Switch Settings for M10 Nozzle
Can't seem to find the information I am looking for. Kit didn't come with directions on which settings to use for different nozzles. Any one have the settings handy?
Also when test spraying, how much PSI should show up on the gauge @ the nozzle?
Offline
Old Jun 18, 2006, 12:35 PM   #2
Evotech8's Avatar
Drives: Tarmac Black Evo VIII 04'
M7=up/up (100psi)
M10=down/up (100psi)
M15=down/down (100psi)
Note:
I/ve seen some variance of pressure with smc kits with different size nozzles above.
Best thing to do is install the nozzle, flip the dip switch, and verify the psi at the gauge by pressing the 'test' button.
__________________
04' TB GSR EVO VIII
HKS 264's, 20G-9, Nisei IC, SMC 100% meth, Sparktech non-cdi, Helix O2/DP, Forge ix wga, ARP studs, RRE rally cat/RRE stealth cbe, AMS licp, GST 3-port BCS , Tomei Bov, Walbro, Tein Flex, Whiteline, Enkei RC-T4 18x9.5, Rexpeed, GST Ecuflash tune.
Offline
Old Jun 18, 2006, 12:38 PM   #3
itzwolf's Avatar
I don't seem to get to 100psi when pressing the test button. More like 40-60 hard to see it as it's at a hard to verify angle.
It definitely sprays as I primed the system with the hose disconnected, then installed and ran the engine to 3000rpm and it sends the AFR super rich, and motor stumbles a bit.
The min/max are untouched but roughly at 10/20.
Offline
Old Jun 18, 2006, 03:34 PM   #4
Evotech8's Avatar
Its easier just to remove your UICP with the mounted nozzle/gauge and just look straight down the pipe. Hold over a bucket and hold the 'test' button down 2-3 seconds. With a M10 nozzle the dipswitch should be "down(1)/up(2)" and read 100psi. If it still reads low, try flipping "down/down". If all else fails, you probably got a bad pump.
__________________
04' TB GSR EVO VIII
Offline
Old Jun 19, 2006, 09:36 PM   #5
Personal Sales Rating: (28)
Drives: 2005 Electric Blue Evo 8
What is the difference between the M10 nozzle setting and the M15 nozzle setting? Both are 100 psi?
__________________
BR parts (4WS Tuned) + E85
12.24 @ 112.0 (1.70 60') - 5/9/2008 (w/alky)
Midwest Evos
http://www.midwestevos.com
AMSOIL
http://www.amsoil.com
Offline
Old Aug 29, 2007, 01:53 AM   #6
Personal Sales Rating: (38)
Drives: 03' EVO VIII
Quote:
Originally Posted by Evotech8 View Post
M7=up/up (100psi)
Note:
What would be the best nozzle to use w/my BR3065 turbo?
Offline
Tags
alcohol, alky, m10, m15, meth, nozzle, settings, smc
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
