Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 13, 2006, 02:18 PM   #1
Personal Sales Rating: (0)
Emperor 4g63's Avatar
Drives: 05 RR Evolution GSR
What PSI of boost are you guys running with MEth/Alch?
State your turbo and psi.
Just want to compare with others. Im running 27-28 on 05 stock turbo on 93 +meth.
__________________
369whp/388wtq
Brand New RR EVO 9 Front Bumper For Sale
Offline
Old Jun 13, 2006, 02:24 PM   #2
Personal Sales Rating: (11)
Ev0ikon's Avatar
Drives: Evo803Yello
30 PSI spike and fall to wherever :P Stock 03 turbo. 93 octane + Meth.
__________________
He who said that there is no replacement for displacement didn't know pkZIP. :p
Offline
Old Jun 13, 2006, 02:29 PM   #3
Personal Sales Rating: (24)
lexat20's Avatar
Drives: 300+ yards
27lbs 16g w/10.5 100%meth
__________________
Kuniiizzzeee Dial-IN
stock and aftermarket parts 4 sale:
http://forums.evolutionm.net/sale-part-outs/183121-need-help-cleaning-out-my-garage-sale.html
This forum requires that you wait 15 seconds between searches. Please try again in 47 seconds....wtf?
MY EVO FOR SALE: http://forums.evolutionm.net/sale-ca...52k-miles.html
Offline
Old Jun 13, 2006, 02:29 PM   #4
Personal Sales Rating: (29)
Creamo3's Avatar
Drives: '03 CT9A / '06 MDX / '07 CBR600RR
28-30 psi / 05' turbo / 100% meth
__________________
Shearer HTA3582 / Magnus V5 / GSC S2 Cams / PPI 65mm TB / Dejon 4" Intake / AMSoil 4090 Filter
FIC 1450cc Injectors / Perrin Fuel Rail / BR Dual Pumps / TiAL Q BOV / APS Catback
ETS UICP / Nisei FMIC / HKS DLI2 / Hallman MBC / E85
Speed Density via EcuFlash
Next: Wiseco 1400HD Pistons / Howards Rods / MAP Stage 4 Head / A1 L19 Studs / ACT 6-Puck
Offline
Old Jun 13, 2006, 02:35 PM   #5
Personal Sales Rating: (17)
fromWRXtoEVO's Avatar
Drives: 09 MB C63 AMG, 07 VW GLI Turbo(DSG),06 Evo IX SE. 95 Eclipse GSX... Evos gone!
Spikes up to 31psi and keeps a steady 28psi in 4th,5th and 6th gear. Maintains 20psi all the way to 8000 rpm and 23psi plus above 7000rpm.
Stock turbo,,methanol injection,number #10 nozzle,Dynoflash custom tuned on 91oct, car runs at 3100feet elevation all the time.
Carlos
__________________
Celebrating my 5th anniversary on this forum. Also 5 years now since I first picked my first Evo (Evo 8 MR), 4 years since I picked my new (second) GG Evo 9 and now 5 years later enjoying my third Evo(Evo IX SE with only 14000 miles) ..again!
Offline
Old Jun 13, 2006, 03:58 PM   #6
Personal Sales Rating: (8)
Drives: goggles and a speedo
I am currently untuned so now I run 23 psi using 60% Methanol,40% Isopropanol (70%), (that is 60% methanol/28%isopropanol/12%H2O)
The isopropanol broadens the surface cooling range of the mix (fractional vaporization) and the H2O to lower the boiling point of the mix
After I get tuned I plan to run the same concentrations but 28 psi
Offline
Old Jun 13, 2006, 04:10 PM   #7
Personal Sales Rating: (4)
EVIL_EV0's Avatar
Drives: 2006 EVO 9 SE
I would like to know if any of you do NOT have ARP head studs.
30PSI seems like alot to run on the stock head gasket.
Offline
Old Jun 13, 2006, 04:41 PM   #8
Correct me if I'm off but the 30 psi itself isn't going to exceed the stock headgsket/bolts limits.
But Adding timing for peak torque in conjunction with the high boost is factor in overloading it, especially with detonation.
Offline
Old Jun 13, 2006, 06:53 PM   #9
Personal Sales Rating: (3)
dubIX's Avatar
Drives: Evo IX
I noticed everyone is running meth. What psi should I run if I want 50/50 (water/alky) or does it matter? 28psi good?
__________________
Tuned by Precision R
Mods that equal 11.81@114
Offline
Old Jun 13, 2006, 06:59 PM   #10
denolloyd's Avatar
Drives: 03 Evo
32PSI GT35R 100% Meth... Holds as long as I do... No ARP head studs. Running this way for over 10K miles hard...
Offline
Old Jun 13, 2006, 07:15 PM   #11
EvilBlueEvo8's Avatar
Drives: '03 BBY CT9A GSR Vishnu V390
Send a message via AIM to EvilBlueEvo8
Quote:
me too
__________________
2003 BBY CT9A Evolution GSR Vishnu V390 - Made in October 2003. Bought March 25, 2004.
2004 MS CS6A OZ Rally - Stock
2002 Durango SLT 5.9L - Stock with 3" lift and K&N
My Page:
http://www.cardomain.com/ride/709068
Offline
Old Jun 13, 2006, 09:53 PM   #12
Personal Sales Rating: (42)
Jeff_Jeske's Avatar
Drives: the racing line
I would guess that at 30PSI bad things could happen at anytime. I certainly wouldn't want to run that high with stock head bolts. But if it works for some of you then by all means .... good luck. I know some people mess up the HG by doing the ARP (one at a time) stud swap. So I guess if its not broke you may not have to fix it.
__________________
TARMAC BLACK 2006 EVOLUTION 9 SPECIAL EDITION
OHLINS DFV /// ETS FMIC /// ZEITRONIX WB & MAP /// JDM REAR /// PERRIN REAR SWAY BAR
JEFFJESKE@JEFFJESKE.COM
Offline
Old Jun 14, 2006, 03:06 PM   #13
Quote:
I think people use the pure methyl becAuse is easier to tune for.
From what I gathered so far, bottom line is run whatever psi and timing you can without detonation and be a tad rich for even a little more
Offline
Old Jun 14, 2006, 03:28 PM   #14
fre
fre's Avatar
Drives: 04 Black Evolution
30psi on a boost gauge could be quite a bit off from the truth. I prefer to go off of my MAP sensor. Generally boost gauges read at least 2 psi high and then at higher boost it can get worse. My friend runs 32-33psi according to his MAP sensor, but his boost gauge reads like 37psi.
BTW I run 30-31psi on a 35R. It does drop off by 2 psi or so after the initial spike, but holds steady after that all the way to 8500rpm. These readings are from my MAP sensor so it would probably be like 33-35psi on a boost gauge depending on the quality.
__________________
Stock block, Lots of mods.
11.1 @ 131mph
Offline
Old Jun 14, 2006, 04:06 PM   #15
denolloyd's Avatar
Drives: 03 Evo
Quote:
You are correct... I have heard bad things with and without stock headbolts regardless of the PSI... 10K miles later all is well, and I drive hard! I just keep my fingers crossed...
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
