Good luck finding one without having to purchace 50 ea
Spartan scientific caries them in any combo of valve and material but depending on finding a distributer to let you buy one is the question. Have you checked snow yet?
Good luck
Series 3800 Technical Data
Voltages:
6, 12, 24 VDC
12, 24, 120, 220, 240 VAC 50/60 Hz
Pressure Range:
Vacuum - 250 psi depending on orifice size and function
Temp. Range:
60° C Ambient temperature
Voltage Tolerance:+/-10%
Cycle Rate:
12 ms
Coil:
Glass filled nylon encapsulation
(Class F, continuous duty)
Environment Protection:
Dust-tight and water resistant to IP65
(with electrical connector)
Wattage Available:
5 watt standard. 2.5 watt and other wattages available on request.
Materials:Operator: AISI 400 and Brass, or 300 Series Stainless Steel
Shading Ring: Copper standard
Nut: Nylon
Seals: Viton, Nitrile, EPDM standard (Chemraz® available on request)
Mounting Plate: Zinc plated steel
