Apr 21, 2006, 03:37 PM
Personal Sales Rating: ( 0)
Drives: Evo 9
Water Injection????
Ok, I here everyone talkin about Alky/Water injection, i am thinkin about water injection for my ix, could anyone explain to me how water injection works, the cost and what kind of results to expect.
Offline
Apr 21, 2006, 04:03 PM
Personal Sales Rating: ( 29)
Drives: '03 CT9A / '06 MDX / '07 CBR600RR
__________________
Shearer HTA3582 / Magnus V5 / GSC S2 Cams / PPI 65mm TB / Dejon 4" Intake / AMSoil 4090 Filter
FIC 1450cc Injectors / Perrin Fuel Rail / BR Dual Pumps / TiAL Q BOV / APS Catback
ETS UICP / Nisei FMIC / HKS DLI2 / Hallman MBC / E85
Speed Density via EcuFlash
Next: Wiseco 1400HD Pistons / Howards Rods / MAP Stage 4 Head / A1 L19 Studs / ACT 6-Puck
Offline
Apr 21, 2006, 04:04 PM
if your looking for a cheap route to go on injection i heard this but im not to sure so you might want to look it up.
Windsheild washer fluid is 54% methanol and the rest is water with color dye.
Srt-4 owners have tried it and i guess it works.
Id like to see someone on these forums do it.
Offline
Apr 22, 2006, 01:15 PM
Drives: Evo 9
i'd didn't even know there had a section on water injection, sorry
Offline
Apr 22, 2006, 01:17 PM
Drives: Evo 9
let make this thread interesting, i only want to use water injection alone, how hp will i gain, and what are the dangers, and what if the tank runs out of water, and i don't want to get tuned
Offline
Apr 23, 2006, 05:38 AM
water injection alone will not give you any power gains! but there are BIG advantages to using water injection. what the water actually does is slow the flame front in the combustion chamber down! what this means is you can run the engine hard on the same fuel and not get any det! effectively its like running on race gas but a lot cheaper!
the reason a lot of people are running alky is the alky helps reduce inlet temps and adds a little bit more octane to the mix aswell! these both help to reduce det even further letting you run the engine even harder!
the disadvantage to both water injection and alky injection is to get the most out of them you need to tune the car with them running! now this is fine while the tanks are full but when they are empty its another story! this, in my eyes is why water injection alone is better as you can carry a bottle of distiled water around in the car incase you do run out!
water injection alone is damn good stuff! take a look at what the WRC teams do and you can see! they run direct water injection into each cyclinder so they can modualte the water in each cylinder!
thanks Chris.
Offline
Apr 23, 2006, 11:26 AM
Personal Sales Rating: ( 8)
Drives: 2003 Evolution VIII, 1974 Chevy LUV/Small Block V-8, 1966 Chevy Nova SS
Chris, I couldn't have said it any better  .
Offline
Apr 23, 2006, 02:44 PM
Drives: in the bike lane.
Quote:
Injecting straight water won't increase your knock-threshold very much. The Alky mix will act more like race gas. Straight water allows you to run a little more power, but allows you to run a LOT leaner since you no-longer need to run excess fuel to cool things down.
Also, water injection doesn't slow down the flame front. It simply delays the start of the combustion process with little effect on overall flame speeds. (The technical term is "Flame Development Angle".)
Here's an interesting read on WI courtesy of NASA and some old research they did into "internal coolants": http://naca.larc.nasa.gov/reports/1945/naca-report-812/
And a graph showing knock-limited performance of an engine with fuel only, with water + fuel and with meth/water + fuel:
Also, here's the reference on flame development angle and water injection. It's long, and the WI stuff is towards the end, but feel free to read if you want: http://www.vehicular.isy.liu.se/Publ...PhD_580_LE.pdf
A couple of the relevant images from that dissertation:
Mass-fraction burned profile showing flame development angle and rapid burn angle:
This image is interesting, but somewhat hard to understand out of context. Basically, they were under cruise conditions and testing an ionization feedback technique on controlling spark advance for use with Water Injection. The image shows the initial fixed spark advance values and the controlled feedback values as well as torque, manifold pressure, etc. When the WI is first turned on, there is a drop in torque concurrent with the deviation from MBT, but when the controller is turned on and allowed to maintain a proper PPP, the torque goes up above the initial values, showing a decrease in pumping losses for the engine!
Ok enough of that.
__________________
Hello, you have reached an imaginary signature.
Please rotate your screen 90 degrees and try again.
(Joke hint: roots of unity.)
Ahh, electronics- the field of study where, though the voltage is sometimes imaginary, the pain is always real.
Offline
Apr 23, 2006, 04:00 PM
Drives: Evo 9
thx for the info i think i going with water injection alone, any suggestion on a kit, and mail-in can tune for WI right??
Offline
Apr 23, 2006, 04:05 PM
Quote:
Aquamist all the way  .
Offline
Apr 23, 2006, 04:08 PM
Drives: Evo 9
have a link to there website EvoTio
Offline
Apr 23, 2006, 04:17 PM
Sure here you go: http://www.aquamist.co.uk/. Richard Lamb is the owner of Aquamist and one of the originators of the water/alcohol forums here on Evom, is a wealth of knowledge. He would be willing to help in any way with your installation questions. Here's a link to my Aquamist installation on my 03 Evo if you're interested: My Aquamist 2D Installation.
Offline
Apr 23, 2006, 04:32 PM
I also re-read your post about a "mail in". Do you mean a mail in flash? If so that answer would be no. You would have to be custom tuned to take advantage of water injection.
Offline
Apr 23, 2006, 05:25 PM
Personal Sales Rating: ( 36)
Drives: EVO METH MACHINE
make sure it's distilled water.
__________________
TEMEVO
"I'm addicted to 100% Methanol : ) "
MACHINES GONE WILD
FOR SALE: FORGE WASTGATE/PERRIN INTAKE CLICK ME
Offline
Apr 23, 2006, 10:19 PM
Personal Sales Rating: ( 15)
Drives: 01 Audi S4 (DD) 04 WW VIII RS (project/fun/track) 06 TB IX GSR (sold) 05 AS VIII GSR (sold)
Saab Tuner, you always have good info, a true guru.
Offline
Tags
2d, advantages, aquamist, direct, evo, gains, give, goon, hp, injection, kit, naca, pdf, srt4, water  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
