Apr 19, 2006, 04:35 PM
Personal Sales Rating: ( 10)
Drives: 03 Evo, 93 240sx
toulene or xylene?
can you use either of these in place of denatured alky or methanol? I have a pretty big supply of all of it but just wanted to know if we could use it with the alky kits that are out.
James
__________________
Coming soon!!!
Thanks to:
SP-ENGINEERING/ HORSEPOWERFREAKS/ ETS/ KURE INT.
Offline
Apr 19, 2006, 04:52 PM
Personal Sales Rating: ( 19)
Drives: evo 8
xylene and toluene is just like putting in race gas octane rating around 110.
I sometimes put xylene in my gas tank to raise octane rating. methanol is totally different substance. If you put xylene or toluene there, it will be like putting in the race gas. also, xylene toluene will melt the rubber parts and hoses of alky kit and possibly damage the pump.
__________________
05 Red Evo RS(weight loss: 180 lbs less than stock RS), HKS 264/272cams, (Megan down pipe+HFCat+Stock cat back), 65mm throttle body. ported ex mani and 02 housing,Blitz SUS,Walbro,MBC, E flash, E85
Offline
Apr 19, 2006, 05:19 PM
so run either of the two straight and there will be no problems but put into the alky kit then you have truoble. How often do you use these in your gas tank and what kind of gains are typical with some type of tuning? the same as putting any other race fuel?
Thanks
__________________
Coming soon!!!
Thanks to:
Offline
Apr 20, 2006, 01:28 AM
Personal Sales Rating: ( 4)
Drives: a drunken IX
Quote:
James
toluene/methyl benzene, xylene/dimethyl benzene will destroy santoprene, the diaphragm material used for majority of the pumps used for alky. You might be able to get away with it using a fuel pump like the "old style" smc injection kits. Also if a solenoid is used for a pressurised system, the seat material would have to be a fluoropolymer like viton and lines will have to be ~pfa, ptfe, ......
Also, you got to worry about distribution issues unless you go direct port inj. then there is the issue of failure thru injection.
Best bet, just pour the stuff into the gas tank...since you got lots of it.
Offline
Apr 20, 2006, 10:11 PM
Personal Sales Rating: ( 8)
Drives: goggles and a speedo
Most every non metallic part with the kit is at least moderately soluable in xylene or toluene or any other nonpolar solvent for that mater.
It will dissolve your kit and likely catch your car on fire.
Offline
Tags
benzene, car, fuel, gas, injection, octane, pumps, putting, race, raise, ratings, santoprene, tank, toulene, xylene  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
