Apr 17, 2006, 09:18 AM
Personal Sales Rating: ( 0)
Drives: 04 EVO 8, 95 honda del sol
how does it all work
did a search with no good results. but just wondering how meth injection works and what it does.
Offline
Apr 17, 2006, 09:52 AM
Personal Sales Rating: ( 6)
Drives: 03 Blue Evo
i dont know if you have seen this thread or not but it is explained really well IMO
http://www.evolutionm.net/forums/sho...=120030&page=1
Offline
Apr 17, 2006, 10:23 AM
thanks alot i will check it out
Offline
Apr 20, 2006, 10:31 AM
Water-methanol injection serves 2 major purposes on a gasoline forced induction engine.
It cools (and therefore condenses) the intake charge by 60-100 degrees F. This is a huge temperature drop with no pressure loss due to larger intercooler volume or plumbing, etc.
It also bumps the effective octane of 91 pump gas to about 116, or C16 race gas. This makes for huge detonation suppression which means a lot more room for timing advance and more power.
That is the thumbnail version - more questions feel free to ask.
Offline
Apr 20, 2006, 10:47 AM
Personal Sales Rating: ( 2)
Drives: IX MR
^ yes.
Water/alcohol/methanol injection all serve the same purpose. It doesn't act as a fuel, it acts to change how the fuel is burned into a smoother and more controlled "burn" like race gas.
Some are very wary of it however, and rightfully so. If it's tuned (for maximum results) and you run out of fluid, it's like dropping your fuel's octane rating like it's your job. you'll find yourself with loads of detonation. Some systems have checks and balances and sensors so there's a constant monitoring of clogged nozzles or low reservoirs, so you're notified immediately if something isn't working right. Some even go farther than that by connecting to the ECU and monitoring EGT's (or AFR's or something similar) so if something DOES go wrong and it detects the mixture is lacking, it corrects the ECU immediately to save your engine if you're not paying attention.
I think with a good injection kit, keeping it filled, and doing preventive maintenance every 6mo, you should be just fine without the expensive ECU-linked systems.
Offline
Apr 20, 2006, 11:28 AM
ok very helpful guys
thanks again.
Offline
Apr 20, 2006, 02:53 PM
Quote:
Yep, if you take advantage of the potential to tune for water/alcohol and the flow quits, you do stand a danger of detonation - UNLESS -
You use our Safe Injection. This is a fail-safe option we offer for any of our Boost Cooler injection kits. It actually measures fluid flow (through the Safe Injection unit) and if it ever drops below a preset level, due to some sort of clog or running out of fluid, etc. it triggers an output that can be used to immediately bleed off boost, retard timing, have a standalone do something else, etc. Not really trying to product plug as much as I am to inform people about the option, as it is relatively new. It is a really valid concern that we have tried to completely eliminate.
Offline
Apr 22, 2006, 02:03 PM
Personal Sales Rating: ( 1)
Drives: 06 Elise. 09 BMW 135I
I think this thread sums the answers to your question pretty well. Methanol injection works great on all turbo/supercharged vehicles. The EVOs tend to do exceptional with meth/water injection. Our latest system the Vari-Cool Controller units have software ability to allow you to configure all params of the system. It can run in single or 2d mode and has many advanced features that you will only find on our unit. Inn-Tune, Import Image, Precision Dyno Tune are vendors on this forum that have our kits in stock.
Offline
Jul 23, 2009, 10:39 PM
Drives: *9 MR SE* ivey tuned.........sold: k7 gixxer 600, 03 350z stock, 04 evo8 cbe, 05 evo8 cbe, 06 sti cobb stg2 300whp
is it ok to use in the winter with very cold weather?
i'm considering installing a system just need a little more info, thanks guys
__________________
PERRIN TBE W/TEST >< BUSCHUR CONE FILTER >< ETS INTERCOOLER KIT >< HALLMAN PRO MBC >< WALBRO 255 PUMP >< KELFORD 272's >< BEEHIVE SPRINGS >< INVIDIA EXHAUST MANIFOLD >< INVIDIA 02 HOUSING >< HDSS W/ACT STREETLITE FLYWHEEL >< FLUIDAMPR CRANK PULLEY >< ARP HEAD STUDS >< STIFF SHIFTER BUSHINGS >< SS CLUTCH LINE >< DUNLOP TIRES >< AEM WIDEBAND >< AUTOMETER BOOST GAUGE >< KOYO RAD >< KEVLAR BELTS >< ///IVEY TUNED - 350whp 352whq///
Offline
Jul 24, 2009, 08:43 AM
Personal Sales Rating: ( 4)
Drives: a drunken IX
Offline
Aug 31, 2009, 08:57 AM
How often does the meth tank run out with spirited daily driving? Wondering if a meth system would pose issues on cross country roadtrips etc.
Offline
Oct 2, 2009, 07:46 PM
Drives: '06 AS IX MR SE
Quote:
Originally Posted by gt3921
how often does the meth tank run out with spirited daily driving? Wondering if a meth system would pose issues on cross country roadtrips etc.
+1
__________________
EVOLUTION IX MR hks intake | hks ssqv bov | cusco oil catch can | apex'i elctronic boost control | prosport gauges | aem o2 wideband | megan exhaust manifold | helix downpipe | megan catback exhaust | chargespeed bottom line | jdm rear | voltex exhaust heat shield | voltex rear diffuser | apr front splitter
Tri-State Evo
Offline
Tags
alcohol, evo, evolutionm, evos, injection, kit, mehtanol, meth, methanol, methinjection, system, water, watermeth, work, works  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
