Apr 14, 2006, 07:19 PM
Personal Sales Rating: ( 1)
Drives: 2003 Mitsu Evo
Quote:
Originally Posted by Fast Frank
I have decided at this point to not rush into anything, so I'm not going methanol right now-Looking into other options race gas, bigger turbo etc...
Thanks for the SNOW info i'll check into it!
go with a NON-PROGRESSIVE system and add the Aquamist DDS3. Nothing out there can touch this combo!
Offline
Apr 14, 2006, 07:47 PM
Personal Sales Rating: ( 16)
Drives: 01 Audi S4 (DD) 04 WW VIII RS (project/fun/track) 06 TB IX GSR (sold) 05 AS VIII GSR (sold)
Yes.
I think the best way of running Alky is Shiv's new "lean protection" feature.
A quote from Shiv's post
1) Lean Run Protect
You define the leanest allowable on-boost AFR curve (5 RPM points) and decide how long it needs to be triggered for (0.5 sec is long enough to not induce false triggers caused by sensor lag) and let the XEDE do the rest. By "rest" I mean a sudden boost drop. If it still remains leaner than that threshold at the lower boost (say another 1 second), it'll do a hard fuel cut. The user can change the conditional logic (allowable time durations, actions, etc,.) This is critical for Methanol use where a pump failor or a jet clogging will destroy a motor in no time. Also good for protection in the case of fuel pump failure or anything else that could induce leanrun.
here's the link...
New Features
Offline
Apr 19, 2006, 01:28 PM
I'll have to rethink my Xede now hmmmm........
Offline
Apr 19, 2006, 04:16 PM
Personal Sales Rating: ( 122)
Drives: 1983 Chevrolet K10 Stepside Pickup
If you need any info on snow just let me know...
Offline
Apr 20, 2006, 12:31 AM
Personal Sales Rating: ( 4)
Drives: a drunken IX
Quote:
Originally Posted by Evo_Kid
Yes.
1) Lean Run Protect
here's the link...
New Features
Plus either snows or aquamist failsafe. makes it a "safer" system.
Offline
Apr 20, 2006, 09:22 AM
Personal Sales Rating: ( 0)
Our Safe Injection upgrade actually measures fluid flow and if it drops below a preset level, it triggers an output that can be used to operate a wastegate solenoid/boost controller or ignition retard etc. on a standalone.
Offline
Apr 20, 2006, 07:13 PM
Personal Sales Rating: ( 10)
Drives: '05 V/// GSR
Quote:
Very Nice
Offline
Apr 20, 2006, 07:18 PM
When im not so busy I will post up a video of the failsafe in action
Offline
Apr 21, 2006, 07:46 AM
Now were talking Failsafe! Awesome info  -Keep it comin'!
Offline
Apr 22, 2006, 03:15 AM
I am building a Shurflo based 100% methanol injection system for a friend, will be using a 15GPH - 945cc/min jet and considering using the SI-10 unit.
What happens when the injector has a partial clog or a pump that is semi-working and the flow of injectant falls in the range somewhere between (6GPH - 378cc/min) and (15GPH - 945cc/min)?
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
