Mar 28, 2006, 10:22 AM
Personal Sales Rating: ( 6)
anyone using 15gph nozzle
Is anyone on here using the 15gph nozzle?
Offline
Mar 28, 2006, 11:20 AM
Personal Sales Rating: ( 8)
Drives: goggles and a speedo
I will only be using 54K ml/d (100psi rated) nozzle, equivalent to (I forget) GPH @ 100psi.
If your running at 200 psi the flow is a lot more than at like - 150 psi
Reason: math
Offline
Mar 28, 2006, 11:23 AM
Silver Sponsor +1
Personal Sales Rating: ( 445)
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Of course we use the 15gph with our kit to 445tq 400+whp (est 430whp). The more the merrier.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Apr 9, 2006, 06:45 PM
I was trying to decide between the 15 and 7 since I have both.
Offline
Apr 12, 2006, 09:34 PM
Personal Sales Rating: ( 10)
Drives: gt35r evo @ 35psi daily!
you gonna have to pull a bunch of fuel out for the m15. i believe i had to pull a little over 30% out of my fuel map.
Offline
Apr 12, 2006, 09:37 PM
Silver Sponsor +1
Quote:
That is about right depending on pump pressure.
Remember that meth requires much more volume than gasoline.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Apr 13, 2006, 03:01 AM
Personal Sales Rating: ( 1)
Drives: 2003 Mitsu Evo
14.7 to 1 vs. ~6.5 to 1
Offline
May 14, 2006, 11:28 PM
Personal Sales Rating: ( 17)
Drives: 09 MB C63 AMG, 07 VW GLI Turbo(DSG),06 Evo IX SE. 95 Eclipse GSX... Evos gone!
Quote:
I have the 3 of them just in case. Stock SMC comes standard with the number # 7 and is more than plenty. If you have the supporting mods you can use the number #10 and that is more than plenty but if you want to go extreme and nuts go aheasd and get the 15.
With my mods the number # 10 is plenty for me. My suggestion is try number #10 before you go from #7 to #15.
Carlos
__________________
Celebrating my 5th anniversary on this forum. Also 5 years now since I first picked my first Evo (Evo 8 MR), 4 years since I picked my new (second) GG Evo 9 and now 5 years later enjoying my third Evo(Evo IX SE with only 14000 miles) ..again!
Offline
May 14, 2006, 11:29 PM
Personal Sales Rating: ( 122)
Drives: 1983 Chevrolet K10 Stepside Pickup
10 would get my vote for most modded stock turbo evos...
Offline
May 30, 2006, 11:03 AM
Personal Sales Rating: ( 33)
Quote:
+1. We use an 18gph nozzle with almost all our progressive kits.
edit: I don't know about the rest of you, but Meth is cheaper than 93 octane here...
__________________
Mike McGinnis
Offline
May 30, 2006, 01:17 PM
Personal Sales Rating: ( 4)
Drives: Evo VIII/SVO Mustang/BMW E30 M3
Quote:
Are you certain that '18gph' nozzle isn't actually an M15 nozzle with reported throughput at 150psi?
The only downside to using a large nozzle with a smaller turbo is if there should be a sudden failure of the methanol injection system. The resulting lean mixture may be enough to destroy the engine.
FYI
__________________
Ted B. Spec JAM Long Rod 2.0L - Headway Performance CNC Head & Valvetrain - DI Intake Manifold - 75mm Hypertune TB - HTA3582R Twin Scroll T4 - Machined 12mm lift Billet Cams - MPFab twinscroll T4 Manifold, TBE, UICP, LICP - MPFab Race FMIC - TiAl 44mm WG - Skunk2 Pro Cam Gears - FIC Bluemax 1250cc - FullBlown Dual 255lph - Synchronic BPV - Spark Tech COP Ignition - TRE Trans - Shep TC + LSD - SPEC Graphite Dual Disc
Offline
May 30, 2006, 01:21 PM
Silver Sponsor +1
FYI
Hence the reason why BR and SMC went to the 7gph at the cost of some whp.
You never know how these kits will be used and abused (run dry, etc).
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
May 30, 2006, 10:19 PM
Drives: a drunken IX
Offline
Jun 1, 2006, 12:20 PM
Personal Sales Rating: ( 28)
Drives: 2005 Electric Blue Evo 8
Used my M15 nozzle on a 2003 evo and now on my 2005. Works well, but pumps a lot of Alky through the system. I may downgrade to a smaller nozzle.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
