Mar 12, 2006, 11:55 PM
Personal Sales Rating: ( 5)
Drives: Very Black Evo, Very Black JEEP SRT 8
How to prevent BLOW if alky fails!
I got dilemma. I Have AEM standalaone, GM boost controller for AEM to control & Buschur 20G9 turbo with the High boost actuator that would not let boost fall below 25PSI.
Now I am planning on installing Alky system and yet to figure out how to prevent overboost and engine failure if it stop spraying????
Please advise as my car runs without boost controller now to prevent overboost.
__________________
-Stock turbo e-85 449WHP / 422TQ :)
:) there's an a$$ for every seat :)
:) I don't trust enything I read, unless its online :)
Mods: Include but not limited to:)
HKS Exhaust, DP, O2, Cams, Gears, Intercooler, Up/low pipe, Standalone or two, Shinny Turbo, BLing BLing:) Look Slow GO Fast :)
Offline
Mar 13, 2006, 03:55 AM
Silver Sponsor
Drives: Citreon Xsara
You can install a DDS3 flow sensor to activate the GM boost controller to obtain high boost in the event of alky flow.
You can set thestock watsegate pressure a few psi below the boost controller (25psi). No alky flow = wastegate pressure only.
There are similar failsafe system out there, read the "there is failsafe , failsafe ... thread on this forum.
Richard
Offline
Mar 13, 2006, 09:25 AM
If I understand correctly DDS3 sensor would artificially bring the pressure up to open the actuator & wastegate, eventhough the real boost that turbo makes is different?
If that is correct i am intereste, because running wastegate actuator presure is the minimum of 25PSI thorugh GM solenoid (due to it adding little resttriction to the flow, and 23-24PSI running Wastegate actuator to the boost source)
-Alex
Quote:
Originally Posted by Richard L
You can install a DDS3 flow sensor to active the GM boost controller to obtain high boost in the event of alky flow.
There are similar fialsafe system out there, read the "thre is failsafe , failsafe ... thread on this forum.
Richard
__________________
Offline
Mar 13, 2006, 10:54 AM
Silver Sponsor
-Alex
I need to get this right before I can be sure I am offering the setup.
If you disconnect one of the wires to the GM solenoid, will the pressure drop lower than 23-24 psi?
What is the orifice of the inline restrictor? If the restrictor is removed, what will the wastegate pressure drop down to?
There are a few ways to by-pass the restrictor if disconnecting the GM solenoid does drop boost. The DDS3 can do most things - it has two dedicated control output to manage your boost.
Richard
Offline
Mar 13, 2006, 04:45 PM
If i disconet it it does not matter because GM boost solenoid is a restricter of sort, i can feel it by blowing in the input part of it and it feels it restricts flow a little.
The ofrice of Boost solenoid as the same as the wastegate actuator1/8 or 3/16.
IF no Boost solenoid used then the pressure will go to 1.7 Bar 24.5 PSI If used then I will have 25+ psi weven ithout it being on.
Does this help to solve the problem?
Alex
Richard
__________________
Offline
Mar 13, 2006, 05:23 PM
Silver Sponsor
It appears that your wastegate adjustment rod is fully retracated.
It this not the case, your wastegate valve diameter may be too restrictive to by-pass enough gas to lower the turbine speed, hence the boost pressure remains high.
If you have a 1/8" or 3/16" restricted port, it shouldn't be your problem because thise dimensions are too huge to be restrictive. I am sure you have another hidden restrictor somewhere in the rubber hose. Try blow throught the kuttke rubber hose between the turbo and the solenoid.
Or, cut a fresh new piece of hose to replace the mentioned hose just to check.
Until you have sorted out your wastegate, the DDS3 will not help you at all.
Richard
Offline
Mar 13, 2006, 05:30 PM
Personal Sales Rating: ( 8)
Drives: Boxer Cup
He is running a high pressure wastegate actuator. The lowest boost (spring pressure) is 24.5psi.
Offline
Mar 13, 2006, 05:46 PM
Silver Sponsor
In that case, perhaps a weaker spring?
Richard
Offline
Mar 13, 2006, 05:54 PM
Personal Sales Rating: ( 10)
Drives: 2006 Evolution SE
With the HP actuator at 25 psi, you're asking for trouble if the alky stops spraying. The only safety net you would have is to be running race gas all the time. I'd put a lower pressure actuator in and use the EMS with a boost solenoid.
Offline
Mar 13, 2006, 07:23 PM
Silver Sponsor +1
Personal Sales Rating: ( 445)
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
There is no way to safely create a failsafe system with a 25psi min actuator.
You could knock on pump gas 11's a/f let alone the 12+ AFR's you should be running on injection.
Get rid of the actuator.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Mar 13, 2006, 09:05 PM
Personal Sales Rating: ( 20)
Drives: AMS Equipped EVO VIII
^^^^^^^^ The above statement and
--->> AEM Safegaurds for Alky/Meth Instructions
is the answer to your needs.
__________________
EVO VIII
Offline
Mar 13, 2006, 10:55 PM
Thank you guys, will call buschur tomorrow to change it for a stock 9 one.
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
