Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Feb 28, 2006, 09:52 AM   #1
Personal Sales Rating: (16)
EVOlutionary's Avatar
Drives: '04 EVO VIII, '06 EVO IX RS, '90 1JZ-TT Supra
Trunk Mount Water/Alcohol Tank
Does anyone make a tank that mounts in place of the spare tire? Like a round tank that fits right in there? Seems like it would be a good way to take a little weight off the front end and keep the CG as low as possible. Alternatively, how about a tank that fits up against the back seat that will fit in front of a rear strut tower bar?
EVOlutionary
__________________
Many thanks to:
Andy @ Showcase Mitsubishi
Keith @ Pure Tuning
David @ DHP Composites
Jon @ TRE
Wayne @ Paradigm Performance
Evan @Exedy Clutch
for your contributions to the EVOlutionary EVO9 Project:
2008 - one car - 20+ wins
2008 - Solo2 XPL National Champ
2008 - Solo2 SM National Champ
2009 - the sky's the limit!
Offline
Old Feb 28, 2006, 10:32 AM   #2
Personal Sales Rating: (53)
Steve@NoLimitmotors's Avatar
Drives: 2006 silver 9 W/SSL-2006 gsxr 1000
as far as I know, no one makes a specific kit that mounts in either of those places but the MSC kit could be mounted in the spare tire well, you'd just need to signify you wanted it that way and Steve could set up the pickup and low level sensor in the correct fashion. The only problem with the spare tire well is if the tank is wide and short, the meth/alky/H20 will slush around alot and cause the low level light to come on often. The pickup could also suck air if the fluid slushed away from it. I'm sorry but I cannot think of a better word then slush at the moment. What you'd really need is a tank thats wide and short but has a dip in the middle that goes down maybe 6-8 inches, but that probably wouldnt fit down there unless you cut a hole in the trunk floor.
Offline
Old Feb 28, 2006, 11:41 AM   #3
What about if it had baffles or foam in it similar to the stock gas tank? Do aftermarket fuel cells use foam or baffles?
Also, can an aluminum tank be used in methanol applications, or would it have to be specially coated on the inside to resist corrosion?
Thanks!
EVOlutionary
__________________
Many thanks to:
Keith @ Pure Tuning
Jon @ TRE
Evan @Exedy Clutch
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
