Feb 23, 2006, 07:34 PM
Personal Sales Rating: ( 4)
Drives: stroked for my pleasure
Breaking up really bad with meth
I was driving the other day and I came across a quick car, flipped the switch for the meth, got on it and pop pop pop pop! Im like ****. I switch it off and it runs fine. I changed the plugs same as they were before bpr8es gapped at .025. Any other suggestions? Should I clost the gap to .022? give me a bone here please.;
__________________
Fully built 2005 apex silver SSL 2.3, gt35r, aem ems, shep racing trans, exedy twin disc ++++ For sale.
$20,000.
Offline
Feb 24, 2006, 09:28 AM
Personal Sales Rating: ( 20)
Drives: AMS Equipped EVO VIII
Quote:
The first thing I would try is yes gap to .022 but be sure to use a feeler gauge and gap the entire strap to .022 not just one edge. You might need to change the plugs too but don't know. Run BPR7ES if possible.
__________________
EVO VIII
Offline
Feb 24, 2006, 09:42 AM
Personal Sales Rating: ( 7)
Drives: 03 evo VIII
Lower the gap to .022!! "8"'s. go look at my video "smokedmustangs misfire caught on tape!" Does it sound like that???? Let me know.
__________________
03 EVO: AMS 2.3L Stroker/Stock EvoIX turbo/Invida O2/HKS 280 cams/Mellon tune/Walbro 255 /RMR turbo back/cat-delete/QTP cutout/custom sidepipe/ Tanabe Sustec Pro SS II. Coilovers/PWR radiator & Intercooler/AMS lower IC pipe/Exedy HD Twin metallic/ Cusco 23mm rear sway bar/Perrin endlinks/stainless lines/B&M short thro/AEM UEGO guage/HKS DLI II/Team Dynamics rims/Forge BOV/Fidanza Cam gears/Team RIPP transfer case / Cusco trunk brace/C-west Full CF-GT wing. (Adj.)
Offline
Feb 26, 2006, 07:39 PM
sounds just like that.. regapped, problem solved. But i went to .20
__________________
$20,000.
Offline
Feb 28, 2006, 11:49 AM
Personal Sales Rating: ( 0)
Drives: My job to drive everything
If it's popping, bogging, etc, you probably have too much flow at activation. Gapping the plugs down can help, but it's a bad approach. Then you are reducing your ignition performance under every driving condition.
Activate it at higher boost if possible, or reduce your total flow by using a smaller nozzle.
Also, if it runs really rich already, and then you add methanol/water to that, it only gets worse. You need a proper AFR for it to work. Making a rich mixture richer will only hurt performance.
Offline
Feb 28, 2006, 08:46 PM
Silver Sponsor +1
Personal Sales Rating: ( 445)
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Thanks for the input, but Luke's car is already tuned. You can't give advice if you do not even know his tuning platform.
I spoke with Luke the day he described this and he was advised to go as low as .015 gap on the plugs.
Personally on stock ignition, we used .026 without a problem, but the mileage, age and condition of the coils will vary the gap you can use without misfires.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Feb 28, 2006, 08:52 PM
Personal Sales Rating: ( 36)
Drives: EVO METH MACHINE
misfires suck.
i gotta try a set of 8's again...7es are good...heard i should be running 8's.
__________________
TEMEVO
"I'm addicted to 100% Methanol : ) "
MACHINES GONE WILD
FOR SALE: FORGE WASTGATE/PERRIN INTAKE CLICK ME
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
