I don't think you are going to be able to solve your afr problem that easily.
If your progressive system is manifold pressure driven and made no reference to RPM and Gear position, you won't be able to get a consistant afr in all gears.
Assuming you have all the above inputs, if the water pump speed is not responding fast enough to your load change, you will always have a afr gap.
I suggest tuning your progressive kit over-rich at 4th gear and hope the lean condition disappears at 1st, 2nd, 3rd gear pull.
I have mentioned this problem tuning a progressive system before on this forum
and I suggested the a fix delivery rate (on/off) system gave less tuning problems.
This is just my opinion of your present situation and I am not bashing the concept of a progressive kits against an on/off system. Please do not take it as such.
Richard L
PS Before abandoning the system for an on/off system, you can consider the following setup:
http://forums.evolutionm.net/showthr...51#post2691951
hi-res download:
http://www.aquamist.co.uk/forum/plus-2d.pdf
