Feb 6, 2006, 11:21 AM
Personal Sales Rating: ( 1)
Drives: '91 MR2 T
Methanol Safe Pump
I recently decided to do a methanol injection system with 4 injectors.
I've got all the necessary stuff except for a fuel pump.
Aeromotive doesn't make "alcohol compatible" pumps as per their brochure, any recommendations as to where i can find one?
Many Thanks!
Offline
Feb 7, 2006, 05:13 AM
Silver Sponsor
Personal Sales Rating: ( 5)
Drives: Citreon Xsara
Many Thanks!
I think Shurflo or Flojet makes pump that can run methanol but not they don't recommended due to un-sealed motor/switching components (flash-point risk)
Offline
Feb 7, 2006, 05:21 AM
Drives: '91 MR2 T
Thanks Richard I'll check it out.
I did come across these, thouigh i don't know how good they are:
Mallory Comp Pump Series 140 Electric Fuel Pumps
Fuel Pump, Electric, Pro Comp 140 Series, External, Universal, Alcohol/ Methanol
Mallory Comp Pump Fuel Pumps
Fuel Pump, Electric, Comp, External, Gas/ Alcohol/ Methanol, 160 gph, -8 AN Female Threads
Holley Black Electric Fuel Pumps
Fuel Pump, Electric, Rotor/ Vane, Black, External, Gas/ Alcohol, Universal, Aluminum/ Polished
Edelbrock Electric Fuel Pumps
Fuel Pump, Electric, External, In-Line, Universal, Aluminum, -12AN Inlet/ OutletBlack Anodized
Offline
Feb 7, 2006, 01:18 PM
Silver Sponsor
They all look very good. Ensure picking the one that can run at high pressure - up to 100-150psi since most of the progressive alcohol controllers are pump speed controlled.
Richard
Offline
Feb 8, 2006, 04:19 AM
Drives: '91 MR2 T
Thanks Richard.
Looks like I'll be going with the:
Offline
Feb 14, 2006, 11:12 AM
Silver Sponsor
Thanks Richard.
How are you metering the flow? now that you have 90psi pressure at hand.
Richard
Offline
Feb 14, 2006, 02:15 PM
Drives: '91 MR2 T
Hi Richard!
Sorry but you're asking the wrong question to the wrong person, i don't know or understand what u mean by that. I just get what shop recommended taht i get, and since Edelbrock is the best one out there (I'm guessing) i went with it....
Offline
Feb 14, 2006, 02:41 PM
Silver Sponsor
Hi Richard!
I thought you are trying to make a alky injection system. I was curious to know how you go about from this point on.
The Pump is perfect for the job. Looks good and it runs methanol.
Richard
Offline
Feb 14, 2006, 02:52 PM
Drives: '91 MR2 T
Nope, using it for a methanol injection system.
Running 4 extra injectors for methanol.
Offline
Feb 14, 2006, 02:56 PM
Silver Sponsor +1
Personal Sales Rating: ( 445)
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Man good luck with that. I hope you know what you are getting into.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Feb 15, 2006, 04:42 AM
Drives: '91 MR2 T
 I hope so too
I'm just recommended and if i like the idea, i do it / get it....
Offline
Feb 16, 2006, 12:25 PM
Personal Sales Rating: ( 0)
Drives: 2001 Silvia Spec-R
Why are people so worried about using injection products still? The problems we had with it 5+ years ago are no more. It's a very safe route to go if you feel the need to. I felt the need, so I went that route. The kits now even have failsafes built in to where if the pressure of the methanol drops below a certain PSI than your boost instantly drops as well. I don't see the problem.
Offline
Feb 16, 2006, 12:34 PM
Silver Sponsor +1
I think you missed the point. He is trying to use methanol injection via fuel injectors and meth safe fuel pump. This has nothing to do with shurflo based pump, flow sensors.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Feb 16, 2006, 02:51 PM
Drives: '91 MR2 T
Yep. Initially I was aiming for one of those kit. But then i was suggested why not add 4 extra injectors to run on methanol and that is what me is doing....
Offline
Feb 18, 2006, 11:11 PM
Drives: Heavily Modded Pt Cruiser
Offline
Tags
alcohol, compatibility, electric, electrical, evo, filter, fuel, injection, inline, line, methanol, pump, pumps, safe, water  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
