aquamist bracket
here is a neat little mounting system for an aquamist set up. Aquamist has this bracket under development and may, at some time offer it as a purchasable piece.
granted finding space in an evo motor compartment is difficult, I managed to fine a good space once the air cleaner box was removed. So if you are considering any WI system and are not going to convert to speed density, you would just about have to place the system in the trunk.
In my case I have an aftermarket emc, so I removed the stock air box and the intercooler water jug. Mounting the Pump on the bit of frame left showing. I found a three gallon plastic fuel tank that is nearly flat so it can mount against the back of the trunk. Once it is in, it will have a washer sprayer motor pump the water up to the WI motor in the engine compartment
