Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 9, 2006, 06:32 AM   #1
Personal Sales Rating: (8)
Drives: goggles and a speedo
Updated info on personal result of running MeOH untuned
I won't be able to tune my car right after installing an alcohol inj system. My ultimate plan is to run straight methyl and get tuned for it .
Would it be safe to go ahead and install and activate the kit and run straight H2O in the meantime until I do get tuned. Boost will remain at it's existing 22psi.
I would think it would'nt effect anything that much - the only change would be the tempertures and pressures - because H2O will not behave like a fuel. So if I keep all parameters the same, i.e., boost, timing, afr, then would'nt it be OK temporary for say, 3 months
Thanks
Offline
Old Jan 9, 2006, 02:06 PM   #2
EvoTio's Avatar
Drives: 2003 Evolution VIII, 1974 Chevy LUV/Small Block V-8, 1966 Chevy Nova SS
In my experience plain water injection works the best if you are running lean A/F ratios. I have found that just injecting a very small amount of water was enough to keep my timing from being pulled back on my previous set up. In other words unless you are experiencing some form of detonation or are having timing issues, you will not be able to take advantage of the water injection. Slowcar has had the best experience with running pure water so far that I know of.
Offline
Old Jan 9, 2006, 02:08 PM   #3
EvoTio's Avatar
Oh and if you do run water make sure it is distilled. The plain tap water can clog your nozzle with deposits.
Offline
Old Jan 9, 2006, 03:01 PM   #4
Personal Sales Rating: (17)
EvilBlueEvo8's Avatar
Drives: '03 BBY CT9A GSR Vishnu V390
Send a message via AIM to EvilBlueEvo8
i think he means is it safe to just install the kit with it operational using water until he has a chance to get it tuned for meth. i dont think he is planning on tuning it for water and just wants to know if he have water injected without any tuning and site effects till then. anyone?
__________________
2003 BBY CT9A Evolution GSR Vishnu V390 - Made in October 2003. Bought March 25, 2004.
2004 MS CS6A OZ Rally - Stock
2002 Durango SLT 5.9L - Stock with 3" lift and K&N
My Page:
http://www.cardomain.com/ride/709068
Offline
Old Jan 9, 2006, 03:14 PM   #5
EvoTio's Avatar
Quote:
I would need to know if he is experiencing any detonation or is his timing being pulled back because of his present tune. Otherwise if he isn't experiencing any of these issues I wouldn't run anything at all until he is ready to be tuned on alcohol. I've found out that you will actually lose power if you inject water when it is not needed.
Offline
Old Jan 9, 2006, 04:58 PM   #6
It's not knocking
I want to instal a kit early so I wont rush into it if an opportunity for a tune arises.
I'm not quite sure if an installed kit that isn't operating (off) is safe, like in boost and also want to do a few operational checks afterwards.
Offline
Old Jan 9, 2006, 06:32 PM   #7
EvoTio's Avatar
Quote:
Originally Posted by C6C6CH3vo
It's not knocking
You could install your kit and use water to make sure everything is working like it should. You can then deactivate it and make it functional again when you are ready to be tuned with the alcohol. Just keep your boost down to a reasonable level in the meantime. I had my Aquamist water injection system deactivated until I was ready to start using it. I hope that this answers your questions.
Offline
Old Jan 9, 2006, 07:02 PM   #8
Quote:
Originally Posted by EvoTio
.... I hope that this answers your questions.
Yep, you answered my question>
I do however fear I might get anxious and turn the boost up a little and test it then too.
Offline
Old Jan 9, 2006, 07:08 PM   #9
Personal Sales Rating: (6)
gaulrich2003's Avatar
C6C6 What is up? Did u install the 10.5 hotside? I was wondering if I could take a look at your alky kit. What kind did u buy? I would like to find someone in Charleston, SC to pay and install my kit if I can't figureout.
Offline
Old Jan 10, 2006, 07:14 AM   #10
Quote:
gaulrich2003 PM'd
I don't have a WI/MeOH inj setup installed or even a brand decided on, but I do have a plan in works and I am gathering all the facts here so when everything is ready, I won't hook it up backwards or grenade my the engine through the hood.
I do know I will take my time and make sure it's functional early before the tuning even if it meant driving around for months as is, and is why I'm asking questions now. The car takes my kids to school and me to work
Offline
Old Jan 10, 2006, 07:16 AM   #11
Personal Sales Rating: (35)
BADEVO's Avatar
Drives: 2003 EVO
Send a message via AIM to BADEVO Send a message via Yahoo to BADEVO
Look at you two ploting with out me........
Slow up, I'll be home in under a week..................LMAO
__________________
Quote:
Originally Posted by AlwaysinBoost View Post
the reason is because you can make as many stipulations as you want in order to hold the record. For example I can say I have the quickest/fastest stock turbo 04 WW GSR w/SSL on 93 pump gas & 22psi w/blizzaks driven on a Sunday.
Quote:
Originally Posted by DynoFlash View Post
When you watch a car on the dyno with a Buschur exhuast the velocity of the flow throuh the exhaust is so fast and powerful that the smoke shoots out and back like a rocket
Offline
Old Jan 10, 2006, 08:43 AM   #12
Silver Sponsor +1
Personal Sales Rating: (445)
TTP Engineering's Avatar
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Send a message via AIM to TTP Engineering
You could run water only, no prob. The water will cool the intake charge, make the air more dense and stuff more in the cylinder. Max power will take backing fuel and raising timing a bit, however it will work on just water for the time being. Jet size and kit is unknown however.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Old Jan 10, 2006, 12:28 PM   #13
Thanks TTP, thats what I thought, that running DI H2O untuned at normal boost will not hurt anything and will infact provide a more solid boost - colder more dense air
Offline
Old May 18, 2006, 09:51 PM   #14
I'll give untuned results now I finally finished the instal
Thought I should provide my results of untuned alcohol since I spent the past time planning and installing the alchol kit since I posted this thread.
Anyhow, instead of using water at 22 psi I'm using the following:
  • 80% methyl - 10% isopropyl - 10% H2O mix
  • 24 psi boost
  • Snow 2D Kit with flow monitoring WG sol failsafe
  • 375ml/min (@100psi) nozzle under 150 psi pump
Allthough untuned, I do have to say that by the butt, the car has gained more than what I got from cams, hotside, and whatnot all together. I expected less than half this from just cooler intake charge . Cant wait to get tuned to tap the other half of fun it holds.
Offline
Old May 19, 2006, 10:35 PM   #15
Personal Sales Rating: (13)
i totally agree with u on this......when i had alky with no tune....it feels amazing fast,,,it was giving me the most power than anything like cams etc,,,,, i boost it up like 26psi with alky no tune........of course later i got tune...but didnt notice a much in power difference between before and after the tune.....\
like al said, tunning only helps .....because with alky kit u wanna run rich condition , and alky likes to run rich without hurting the power performance...maybe loss of a few hp.but .better be safe than sorry just incase when it fails
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
