Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 5, 2006, 04:09 PM   #1
Silver Sponsor
Personal Sales Rating: (4)
Drives: Citreon Xsara
There are failsafes, failsafes and failsafes...
I think we have discussed most of the systems available and their capabilties. It is a good moment to see what failsafe mechanisms are available from the simpest to the most complex. I will update the list when more contributions are posted, if any.
Direct detection:
1. Fluid tank level sensor :
Advance warning but only good for early warning but little use for system power failure or blocked nozzle.
2. Loss of system power:
If power is interrupted to the WIA system, it will de-engergise a relay and performs "Plan B", will not detect blocked jet or cut pipe or no fluid flow.
3. Inline pressure gauge:
This is very cost effective but require user paying attention.
4. Inline single pressure switch:
If the system looses fliud pressure during activation, an inline preset pressure switch can action a boost drop etc.
5. Two inline pressure switches:
Detects blocked nozzle (over pressure) and "lost of fluid pressure" (under pressure). This method is quite cost effective and within DIY capability.
6. Flow switch:
In inline flow switch, comprised of spring-load magnetic plunger inside a tube where the water flows through. The rate of spring determines the promixity of a reed switch again the pluger deflectiion. Output: on/off. - cost: low
7. Turbine flow sensor:
Good for progressive system but requires complex electronics circuitry to report a differnce between the "actual" and "planned" flow in real time.
More..?
In-direct detection:
1. Knock detection:
2. AFR tracking:
3. EGT tracking:
4. Inlet temperature tracking:
I leave it as it is until the this topic attracts more interest. It is important to know what how "safe" is a "failsafe" .
Richard
Offline
Old Jan 5, 2006, 04:57 PM   #2
Personal Sales Rating: (8)
Drives: goggles and a speedo
I would be hesitant to rely on some indicator to tell me to ease up on the throttle. At 27 psi my attention would be on trying to avoid running into the back of the Cobras in front of me. The engine damage may have already started.
With flow, the system would have to be fast - the WG act would need a solid air command with quick solenoid actuation inline of perhaps short as possible tubing, not to flexible either. Yanking timing in respect to underflow conditions or both (timing/WG act) would be best but too expensive for me.
If safed by venting boost, I assume that the flow monitoring system should require periodic ops checks to make sure the flow sensors, solenoids, and works are in working order. Can easily be done with a pressurized system (use leak test procedure that includes nipple to the sol.) while blocking flow and looking for WG act movement from up top, but depending on the kit complexity, you may have to find additional ways to fool the system of thinking your driving spiritually - I dont know yet.
Offline
Old Jan 5, 2006, 07:05 PM   #3
Personal Sales Rating: (17)
EvilBlueEvo8's Avatar
Drives: '03 BBY CT9A GSR Vishnu V390
Send a message via AIM to EvilBlueEvo8
wouldn't number 5 be the best?
__________________
2003 BBY CT9A Evolution GSR Vishnu V390 - Made in October 2003. Bought March 25, 2004.
2004 MS CS6A OZ Rally - Stock
2002 Durango SLT 5.9L - Stock with 3" lift and K&N
My Page:
http://www.cardomain.com/ride/709068
Offline
Old Jan 6, 2006, 01:12 PM   #4
fromWRXtoEVO's Avatar
Drives: 09 MB C63 AMG, 07 VW GLI Turbo(DSG),06 Evo IX SE. 95 Eclipse GSX... Evos gone!
I concur with his statements. When you are WOT and boosting 26-28PSI there is virtually no time to fix nothing, we are talking about a couple of seconds, you are already in charge of having to read boost gauge, RPM and by the time you realize there is a problem then your engine is gone.
I think people want to hear or a mechanism that you plug in and forget that is there and that it would shut down boost or would minimize damage by other means but without the human factor.
__________________
Celebrating my 5th anniversary on this forum. Also 5 years now since I first picked my first Evo (Evo 8 MR), 4 years since I picked my new (second) GG Evo 9 and now 5 years later enjoying my third Evo(Evo IX SE with only 14000 miles) ..again!
Offline
Old Jan 7, 2006, 05:16 AM   #5
Silver Sponsor
Number 5 is good for am on/off system but may be a bit vague for a progressive system.
Richard
Quote:
Offline
Old Jan 10, 2006, 08:48 AM   #6
Silver Sponsor +1
Personal Sales Rating: (445)
TTP Engineering's Avatar
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Send a message via AIM to TTP Engineering
We have #2, we plan on adding #1 & #6 as soon as we have time. This will likely become an option due to cost. At $299 for our kit, it is one of the most affordable options for those getting into A.I.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Old Feb 23, 2006, 08:31 PM   #7
Personal Sales Rating: (2)
Drives: evo
On my setup I have an air valve that directs complete boost presure to the wg in the event of low fluid level in tank. this drops the boost to 11psi instantly. cost about 20bucks to do and a easy install. also works with the should the system loose power. But how i really use it is in town i have the switch turned off, this means no alky and 11psi of boost. Gives me great gas milage. then when playing around turn switch on and alky is powered up and so is high boost. I would like to hook it to a presure sensor inline too. Hum.........problem is you only have alky pressure when the pump is running. Any ideas?
Offline
Old Feb 23, 2006, 09:18 PM   #8
snowperformance.net
safe injection $99
The unit will send dcv out to energize a solinoid ($39) t'd parallel with mbc in the event pump output flow goes below a certain ml/min
Offline
Old Feb 23, 2006, 10:09 PM   #9
Personal Sales Rating: (15)
Evo_Kid's Avatar
Drives: 01 Audi S4 (DD) 04 WW VIII RS (project/fun/track) 06 TB IX GSR (sold) 05 AS VIII GSR (sold)
Shiv is working on a function on the XEDE that would work as a great as a water/alky injection failsafe.
From Shivs post,
1) Lean Run Protect
You define the leanest allowable on-boost AFR curve (5 RPM points) and decide how long it needs to be triggered for (0.5 sec is long enough to not induce false triggers caused by sensor lag) and let the XEDE do the rest. By "rest" I mean a sudden boost drop. If it still remains leaner than that threshold at the lower boost (say another 1 second), it'll do a hard fuel cut. The user can change the conditional logic (allowable time durations, actions, etc,.) This is critical for Methanol use where a pump failor or a jet clogging will destroy a motor in no time. Also good for protection in the case of fuel pump failure or anything else that could induce leanrun.
Offline
Old Feb 24, 2006, 01:15 PM   #10
Personal Sales Rating: (0)
Drives: Heavily Modded Pt Cruiser
Along with the direct port injection, I also have added a safety feature. The engine, without a boost controller, boosts around 15 psi. In the last picture, you will see a bleed hooked up to a solenoid, that is t'd into the line running to the wga. When the water/meth injection activates, the nozzle pressure sensor between the water solenoid and the injectors will trigger, which in turn does a couple of things. The first is it will light a small led in the cabin that will be mounted in my gauge pod. The second, and most important, is that it will activate the solenoid with the bleed, instantly increasing my boost to 20-21 psi. The best part is, no pressure to the injectors, then the boost will stay at 15 (peak). But if the water injection system is working correctly, the boost will increase.
Offline
Old Feb 24, 2006, 01:43 PM   #11
If one of the four nozzles gets clogged the psi sensor wont notice.
The only way to have a system like that totally failsafe would be four separate flow sensors.
Nonetheless, very clean setup you have.
Offline
Old Feb 24, 2006, 02:54 PM   #12
Silver Sponsor +1
Good point. $400 worth of flow sensors.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Old Feb 24, 2006, 03:32 PM   #13
You are correct that the clogged nozzle feature gets lost, but truthfully, that has never even come close to being an issue. I have a 40 micron filter between the tank and the pump, and each individual injector has its own filter. I have never even had any of those come anywhere close to becoming clogged either, so I am not worried about losing that feature.
I haven't had a chance to dyno the new setup versus the old one (single injector mounted just after the intercooler), but the good ole butt dyno sure feels it. The nice part is, since the bleed only activates after the w/i activates, I don't have to deal with massive part throttle boost. I love when I punch it, it takes about 1 second for the boost to build, and once the boost passes through about 12 psi, the whole setup kicks in (w/i and ebc), and then I get another 5-6 psi. Makes it feel like a nitrous shot.
Offline
Old Feb 24, 2006, 04:30 PM   #14
Silver Sponsor +1
1 second is about a half second or more too long for an Evo 16g.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Old Feb 24, 2006, 06:27 PM   #15
Quote:
Impressive. So your saying from a stop, at idle, then punching it, you will reach peak boost in .5 seconds?
Offline
Tags
activate, alcohol, aquamist, boost, comp, connect, coolingmist, ebc, fail, injection, install, labonte, safe, smart, trimmer, water, zeitronix
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
