Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 3, 2006, 02:45 AM   #1
Personal Sales Rating: (2)
gunzo's Avatar
Drives: Lancer Evolution SST
Send a message via ICQ to gunzo
Water injection and EGT
Anyone gotten any correlation or data with spraying water and the EGT they are getting ??
I would assume that you'd get lower temps when you spray given the fact that ignition is advanced quite a fair bit
I'm getting around 880-920degrees C at the manifold side with no ignition advance ..
I've also found out overspraying can put out the fire in your car (literally) .. so make sure you're running a good ignition system !!
300cc at 1.8bar at 6000rpms = BAD misfire !!
Also due to bad plugs .. that's one of the reasons why I can only see about 2-3 degrees advance only !! (hopefully)
Offline
Old Jan 3, 2006, 08:13 AM   #2
Personal Sales Rating: (4)
SlowCar's Avatar
Drives: a drunken IX
I never seen my egt rise above 900C with ~11 degrees at peak tq. Totally agree about the misfire! @17v/v% water to fuel. A ignition amplifier like the HKS DLI II or the COP(used by bishiboy) helps fix the problem. It helps to close down the spark gap too.
More timing advance-leaner burn(quicker burn), the combustion occurs within engine, not in the exhaust manifold.
__________________
6 injectors, 3 fuel tanks and 2 fuel pumps
Aquamist HFS-6 install: ......:)
Aquamist HFS-1 install: http://forums.evolutionm.net/water-a...n-project.html
Aquamist 2D/DDS3 install: http://forums.evolutionm.net/water-a...tion-pics.html
Offline
Old Jan 4, 2006, 02:06 AM   #3
gunzo's Avatar
well I'm running the DLi .. yet I get misfires
at peak torque I'm (around 4500rpms) I'm seeing about 800C .. but at 7500rpms I'm seeing 920C or so .. at 1.7bar 11.2AFR with 17-18degrees advance timing
Offline
Old Jan 4, 2006, 07:12 AM   #4
SlowCar's Avatar
Quote:
just curious....whats your spark gap?
__________________
Offline
Old Jan 5, 2006, 06:49 AM   #5
gunzo's Avatar
0.024 i think.. anyway it was the plugs lousy bpre8ix.. theres a lifespan to these buggers..
now with the new set of plugs i'm good
now trying to advance the timing to see if egts come down
Offline
Tags
egt, egts, exhaust, injection, misfire, temperature, water
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
