Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Dec 8, 2005, 10:51 AM   #1
Silver Sponsor
Personal Sales Rating: (5)
Drives: Citreon Xsara
Who's who and what and where...
********** Updated: 26th December 2006 **********
It is a good time to do a complete listing of current water/alky injection manufacturers and their product. Specifications, capabilities and price range. It is a copy post from EVOM a few months ago and have proved to be useful to most potential WIA users.
I will start and fill-in more manufacturers as more information is available:
Active
Capabilities: Adjustable manifold pressure activation
Pump: Shurflo
Electronic Controller option:: not mentioned on site
Chemical compatibility: Water, Alcohol
Failsafe: not mentioned on site
Price range: US$750.00
Warranty: Not mentioned on site
URL: http://activeautowerke.com/cooling/main.php
EMAIL: aatuning@activeautowerke.com
Alkycontrol
Capabilities: Progressive delivery proportional to MAP sensor. Inline filter, metal fittings, and stainless steel braided lines.
Pump: Shurflo
Electronic Controller::Based on PAC module controlling pump speed to vary pressure
Failsafe: Failsafe Bi-colored LED works of pressure sensing, inline filter, metal fittings, and stainless steel braided lines.
Price range: US$425-495
Warranty: 1 year unconditional and 100% methanol URL: http://www.alkycontrol.com/
EMAIL: Online form or phone
Aquamist
Capabilities: Static flow, mappable, fuel injection duty cycle tracking, ECU interface and map switching
Pump: Own design - magnetic piston type and 150W/125psi by-pass Shurflo pump NEW
Chemical compatibility: Water, Methanol. 100% methanol and 10 to 20% nitromethane withteflon seals: supply on request
Failsafe: Dash Flowmeter or fulltime monitoring via signal error comparator circuitry, boost control and map switching output.
Price range: US$585.00-3000.00+
Warranty: 12 months
URL: www.aquamist.co.uk
EMAIL: info@.aquamist.co.uk (sales enquiry), richard@aquamist.co.uk (technical)
Aquastealth
Capabilities: Static flow, Pressure switch activated inline solenoid.
Pump: Shurflo
Chemical compatibility: Water, Methanol, isopropyl and ethanol.
Failsafe: unspecified
Price range: US$239.00
URL: www.aquastealth.com
EMAIL: sales@aquastealth.com
Coolingmist
Capabilities: Progressive, Static flow – single or dual stage
Electronic Controller: Digital Programmable "progressive" style controller capable of 2d Maping. Optional Commander for datalog, digital display.1-30 psi sensor or 4-120 psi.
Pump: Custom Shurflo
Chemical compatibility: Water, 100% Methanol safe (EPDM Seals)
Failsafe: hi/lo system pressure switch to detect loss of pressure or clogged jet. Upcoming Vari-Safe Smart Injection
Price range: US$299.95 to $999.95
Warranty: 1 Year Warranty
URL: www.coolingmist.com
EMAIL: coolingmist@comcast.net
Devilsown
Capabilities: Static flow, PWM pump speed control option
Electronic controller option: 0-5v (selectable scales 2 bar,3 bar,voltage) – pump speed control . Price US$125.00
Failsafe: over-current sensing
Price range: US$205.00-305.00 + MAP sensor
Warranty: One Year Limited
www.alcohol-injection.com
EMAIL: sales@.alcohol-injection.com (sales inquiry), support@alcohol-injection.com (technical)
Hydramist by Element Tuning NEW
(Work with Hydra EMS only)
Capabilities: Full 3D hi-res mappable, inbuilt failsafe.
Electronic controller: Element Hydra stand-alone EMS.
Pump: Shurflo (150W), with 125psi internal by-pass
Chemical compatibility: Water, Methanol, Ethanol, Iso-propyl
Failsafe: DDS3 flow sensing system - auto map switching via DDS3 v7.
Price range: US$799.00 not including Hydra EMS
Warranty: Not yet specified
EMAIL: phil@elementtuning.com
URL: www.elementtuning.com
EngineRunup
Capabilities: Static flow and two stage. Solenoid controlled
Electronic Controller: Call
Pump: Shurflo
Failsafe: two pressure switches to detect clogged jet (250psi) and low tank level option
Price range: US$189.00-359.00
Warranty: 90days -Limited
URL: www.enginerunup.com
EMAIL:info@enginerunup.com
Gaseous Intercooling TM
Pump: Flojet
Failsafe: Flow switch
Price range: $395.00-540.00 basic to Standard Plus (with solenoid)
Electronic flow controller: US$195.00 sold as an optional extra
Warranty: 90 Days
URL: http://www.blowerworks.net
EMAIL: greg@blowerworks.net
Hyper-drive
Capabilities: Mappable pump speed controller
Pump: Shurflo
Failsafe: low water level sensor.
Warranty: not mentioned on site
URL: http://www.hyp-drive.com/products/alcoholinj.htm
EMAIL: resolution@hyp-drive.com
Perrin NEW
Capabilities: IDC tracking - PPM pump control (progessive)
Pump: Electrionmagnetic piston pump
Failsafe: low water level sensor and real time flow tracking
Price range: US$749.99
Warranty: Terms and Conditions on Site
URL: http://www.perrinperformance.com
EMAIL: Sales@perrinperformance.com
RSR
Capabilities: Static flow, Port injection
Pump: Shurflo
Failsafe: water level switch
Price range: US$185.00-345.00 + MAP sensor
Warranty: call
URL: www.rbracing-rsr.com/waterinjection.html
SMC
Capabilities:Progressive controller
Electronics controller option: - control pump speed to vary flow.
Pump: Flojet/Rotary fuel pump
Chemical compatibility: Water, Ethanol, Methanol, and Isopropyl alcohol types (recently updated)
Failsafe: tank level sensor at present.
Price range: US$399.00-499.00
Warranty:90 Days
URL: www.smcenterprises.com
EMAIL:schlupsa31@mchsi.com
Snow Performance
Capabilities: Static flow, solenoid
Electronic controller option: Progressive pump speed controller +$129.00
Pump: Shurflo
Failsafe: flow switch based. $99.00
Price range: US$185.00-439.00 (MAF vs Pump speed)
Warranty: limited option by vendor
URL: http://snowperformance.net
EMAIL: mbsnow57@msn.com
Spearco Water Injection System
Location: Top-End Performance, N.Hollywood, California.USA.
Pump: Not specified
Failsafe: Not secified
Price range: US$219.00
Warranty: Call
URL: http://www.h2oinjection.com
EMAIL: topend@racetep.com
TTP Engineering
Capabilities: Static flow, Progressive controller –sold separately(PWM pump)
Pump: Shurflo Based
Control option: pressure switch, TPS or MAP (0-5v selectable)
Failsafe:upgrade path available
Price range: from US$299.00(base) + accessories
Electronic Controller: Variable injection rate controller now available
Warranty: Call
URL: http://www.ttp-engineering.com
EMAIL: online form filling
Underdog Racing Development NEW
Pump: 150W/125psi by-pass Shurflo pump
Failsafe: Dash Display Flowmeter, boost control and map switching output.
Price range: US899.00 ('till 31st Dec 06)
Warranty: 12 month? (please confirm URD)
URL: www.urdusa.com
EMAIL: Info@urdusa.com (sales enquiry)
I will update the list as more information becomes available. Please post on this thread if you have found any incorrect information, use the above information at your own risk.
Richard L
Offline
Old Dec 8, 2005, 10:54 AM   #2
Personal Sales Rating: (27)
dryad001's Avatar
Drives: 03 VIII
Send a message via AIM to dryad001
Wow what a great idea, this has got to be stickied.
What about Buschur, AMS...
Offline
Old Dec 8, 2005, 10:58 AM   #3
Silver Sponsor
Please send information,
I will update it - I believe SMC made some of them? Please confirm.
I need all your help to compile the entire list. It may looked biased since I have put Aquamist on the top - unless I call ourselves Zquamist.
Richard
Offline
Old Dec 8, 2005, 11:22 AM   #4
Silver Sponsor
I have just visited AMS and Buschur website and none are listing water/alky injection kit.
I am only listing manufacturers and not product re-labelled resellers.
Richard
Offline
Old Dec 8, 2005, 12:55 PM   #5
Personal Sales Rating: (4)
SlowCar's Avatar
Drives: a drunken IX
Aquamist is COOLER
Quote:
__________________
6 injectors, 3 fuel tanks and 2 fuel pumps
Aquamist HFS-6 install: ......:)
Aquamist HFS-1 install: http://forums.evolutionm.net/water-a...n-project.html
Aquamist 2D/DDS3 install: http://forums.evolutionm.net/water-a...tion-pics.html
Offline
Old Dec 8, 2005, 08:44 PM   #6
Silver Sponsor +1
Personal Sales Rating: (445)
TTP Engineering's Avatar
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Send a message via AIM to TTP Engineering
Not off to a good start... TTP-Engineering does not sell Snow Performance kits. You did not request this information from us and your misinformation is slanderous. This thread should be deleted if the information cannot be kept factual. We are located in Orlando, FL which is no where near Calardo or Colorado.
Where is the Truth Squad when you need them? LOL
Quote:
TTP Engineering
Pump: Shurflo Based
Failsafe: Not mentioned
Electronic Controller: not mentioned on site
I will update the list as more information becomes available. Please post on this thread if you have found any incorrect information – use the above information at your own risk.
Richard L
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Old Dec 8, 2005, 09:02 PM   #7
SlowCar's Avatar
hmmm......did you have some bad food for dinner? The nice dude is trying to summarize what is available out there...........and all i can see is the location is entered wrong...and you are all bent out of shape....slanderous?
Quote:
Originally Posted by TTP Engineering
Not off to a good start... TTP-Engineering does not sell Snow Performance kits. You did not request this information from us and your misinformation is slanderous. This thread should be deleted if the information cannot be kept factual. We are located in Orlando, FL which is no where near Colorado.
__________________
Offline
Old Dec 8, 2005, 09:03 PM   #8
Personal Sales Rating: (122)
Ultimate CC's Avatar
Drives: 1983 Chevrolet K10 Stepside Pickup
Send a message via AIM to Ultimate CC
Buschur uses SMC and AMS uses alkycontrol
Offline
Old Dec 8, 2005, 09:03 PM   #9
SlowCar's Avatar
had to dig this one out from a past post, barb fittings and vinyl hose.........any idea how it works?
http://www.aquatune.com/index.asp
__________________
Offline
Old Dec 8, 2005, 09:05 PM   #10
Offline
Old Dec 8, 2005, 09:05 PM   #11
EvoM Administrator
Personal Sales Rating: (0)
Speedlimit's Avatar
Drives: 2003 White Evolution VIII
TTP Engineering:
I don't understand your point. Why is it slanderous? Or vendor bashing? He ask for comments which you have given him. He made a mistake and I assume will fix it. If he doesn't, I'll remove it.
Speedlimit...
__________________
Why can't you post in the market place?
http://forums.evolutionm.net/faq.php...for_sale_forum
Offline
Old Dec 8, 2005, 09:19 PM   #12
Personal Sales Rating: (7)
No wonder the English think we are jackasses. Richard L has been the most helpful person I know in the water injection arena going as far as sending me parts from England free of charge. This truth squad BS is getting out of hand, everytime something happens on this forum somebody brings up that bull*hit. Shame on you Tom(smogrunner) for starting this crap. Funny he knows better than to try to start something like this on SoCal Evo.
Offline
Old Dec 8, 2005, 09:19 PM   #13
Silver Sponsor +1
Quote:
Originally Posted by Speedlimit
TTP Engineering:
Speedlimit...
I am certain Snow Performance would not like our company name paired with their address and location. Likewise, we do not sell their products and do not want to be associated with them. Everything from the location to company to the pricing is incorrect.
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Old Dec 8, 2005, 09:27 PM   #14
SlowCar's Avatar
at least...this is more civilised......just PM Richard or write the correct info here and it will be corrected once he sees it
__________________
Offline
Old Dec 9, 2005, 02:00 AM   #15
Personal Sales Rating: (17)
fromWRXtoEVO's Avatar
Drives: 09 MB C63 AMG, 07 VW GLI Turbo(DSG),06 Evo IX SE. 95 Eclipse GSX... Evos gone!
How about AMS alcohol kit?and how about the fancy water system from Works?
__________________
Celebrating my 5th anniversary on this forum. Also 5 years now since I first picked my first Evo (Evo 8 MR), 4 years since I picked my new (second) GG Evo 9 and now 5 years later enjoying my third Evo(Evo IX SE with only 14000 miles) ..again!
Offline
Tags
22cc, 806075, accumulator, alcohol, aquamist, aquastealth, aquatune, devilsown, drive, evo, hydramist, hyper, injection, methanol
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
