Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Dec 28, 2005, 07:26 PM   #31
Personal Sales Rating: (0)
Drives: Heavily Modded Pt Cruiser
This should be a sticky.
Offline
Old Jan 4, 2006, 04:40 PM   #32
Personal Sales Rating: (8)
Drives: goggles and a speedo
Just got off the phone with the Snow people, from what they said, they do have Evo specific inj
Offline
Old Jan 4, 2006, 04:56 PM   #33
Silver Sponsor
Personal Sales Rating: (5)
Drives: Citreon Xsara
Thank you C6C6CH3, I have updated Snow's description.
Richard
Quote:
Offline
Old Jan 4, 2006, 09:15 PM   #34
Silver Sponsor +1
Personal Sales Rating: (445)
TTP Engineering's Avatar
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Send a message via AIM to TTP Engineering
TTP-Engineering's ONLY kit is custom tailored for the Evo only and is a rear mounted tank and pump. We could not care less about any other car but our beloved CT9A's.
Pic from the most recent install...
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Old Jan 12, 2006, 09:31 AM   #35
I just bought a kit from Devilsown, They are in oklahoma city ok. I saw somthing about a 1 year warrenty.
It has fault leds on it he said its the only controller that does this.
I copy pasted this. It will blink a steady rate when the unit is faulted..
Fault:
The controller will go into fault mode if
- excessive current draw
- fault in the pump circuit
- controller overheat
- pump wired incorrectly
He said I could also wire an option level sensor to it and it will light up a ligh on his controller.
his email was Suport@devilsownonline.com
Offline
Old Jan 13, 2006, 02:58 PM   #36
strikethree's Avatar
Drives: 92 Talon TSI AWD
sticky?
strike
Offline
Old Jan 13, 2006, 04:39 PM   #37
Silver Sponsor
Good information, thanks for posting.
I have updated Devilsown's "warranty" line
Richard
Fault:
Offline
Old Jan 13, 2006, 04:44 PM   #38
Silver Sponsor
Quote:
Originally Posted by strikethree
sticky?
strike
I agree
It would be nice if this thread can be made sticky - easily accessible for all those who wants to add more new information.
I have no say on making the thread sticky.
Richard
Offline
Old Jan 14, 2006, 12:27 PM   #39
bump for stickiness (please remove this bump once the thread is sticky. thanks)
strike
Offline
Old Apr 22, 2006, 03:29 AM   #40
Silver Sponsor
New kid on the block - This progressive kit was first shown at the 2004 SEMA show.
Richard
Offline
Old Apr 22, 2006, 08:28 AM   #41
Silver Sponsor +1
Is it made my turbonetics or aquamist?
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Old Apr 23, 2006, 03:35 AM   #42
Silver Sponsor
I believe the kit is a no thrill, plain and simple unit that meets all the usual requirement of a progressive kit.
little info on the kit here I copied from the st/ty site:
Applications and Features:
Charge-air cooling for force induction engines
Minimizing the onset of detonation
Suitable to run water and alcohol mixtures
"Plug and Play" controller for ease of installation
All components are properly engineered for reliable operation
Intermittent diaphragm pump- more reliable than the normal windshield washer pump
Built in Thermal-Cut in water pump
Enable "Meaner & Leaner" air / fuel ratio
Increase octane rating on low grade pump fuel
Dash controller allows real-time user flow control with status LEDs
Only three wires needed to be connected for total control
Can be used with any 0-5V load sensors
Inline 100 micron stainless steel filter
The system is comprised of a dash-mounted controller and a high-pressure diaphragm pump designed to receive a Pulse Width Modulation (PWM) signal from the controller.
The pump can be used with a high concentration of alcohol (75%) as well as just water alone; this is particularly useful for applications where alcohol can enhance the fuel octane or just asadditional fuel at high boost levels. It is recommended that alcohol be added for cold operating conditions.
The Dash controller only measures 2.3" x 1.4" x 0.6" tall, perfectly suited to fit into any small cockpit space. Although small in size, it contains all the necessary controls to enable the user to cover the'mid' to 'high' load range of any 0-5V output MAP sensor.
Injection triggering point is set by the 'THRESHOLD' potentiometer and is indicated by a blue LED on the controller. It is user adjustable between 1.5-4.5V. Adjustment to this potentiometer will determine the starting point of the water injection system. As shown in the chart below, 1.5V of a 2 bar MAP sensor represents approximately 0.4 bar below atmosphere (vacuum), while a 3 bar sensor represents almost atmospheric pressure.
The injection % range is set by the 'GAIN' potentiometer on the controller. As the red LED lights up, it indicates about 80% of full injection and will continue to get brighter until it approaches 100%. The gain potentiometer can be set to arrive at any level at any boost.
The water injection system can be switched off via an 'ON/OFF' push button, indicated by a green LED on the controller.
This latest 'Plug and Play' water injection from Turbonetics sets a new standard for the growing water injection market currently shared by many new water injection manufacturers.
Offline
Old May 9, 2006, 05:09 PM   #43
Silver Sponsor
Quote:
This kit is from Turbonetics - USA based turbo maker.
Richard
Offline
Old May 9, 2006, 05:11 PM   #44
Silver Sponsor
Quote:
I have requested but no response yet.
Offline
Old May 10, 2006, 06:23 PM   #45
Yaroslav's Avatar
Drives: Evo VIII ,LEXUS GX 470
Send a message via ICQ to Yaroslav
Question
Please Help to choose. I have set of 2xM15 nozzles and set of 2xM10 nozzles.
I have AMS KIT. Which set will be better for 35-37psi of boost on 93oct?
__________________
WRC G-METER showed 745hp on 93oct + AMS WI (methanol). Boost - 33psi AMS 2.3 +GT35
Tuned by Neil Broomhead WRC "MEM" TEAM
AMS GT37 installed,waiting for tune
Offline
Tags
22cc, 806075, accumulator, alcohol, aquamist, aquastealth, aquatune, devilsown, drive, evo, hydramist, hyper, injection, methanol
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
